Old Jan 06, 2011, 03:28 AM
Precise and powerful
AEORC's Avatar
P.R.China
Joined Aug 2008
The various and complete ducted fans:27,30,35,40,45,50,64,70mm !!!
Hi all,
Look at the attached pictures about the various and complete 8 or 7 blades rotors
We extended the range of ducted fans such as 27mm,35mm,45mm,50mm,70mm.
Except 27mm ducted fan comes with the 7 blades rotor,the other are 8 blades rotors.
The thrust is increased not less than 20% comparing to the old 6 blades rotor version. For example,ADF30,C10 13000kv,2S,thrust is about 140g.
We hope this will meet your needs
All the new ducted fans will be ok in 1-2 month:27mm(7 blades rotor),30mm,35mm,40mm,45mm,50mm,64mm,70mm.
Hu
AEORC is offline Find More Posts by AEORC
Old Jan 06, 2011, 03:41 AM
AEORC's Avatar
P.R.China
Joined Aug 2008
New fan housing and spinner
Not only the 7 or 8 blades rotor but also the new fan housing and spinner make the ducted fans more powerful than before,the preliminary testing results shocked us . Not less than 20% thrust was increased !!!
New fan housing and spinner were designed according to aerodynamics and reducing the resistance and increasing the thrust furthest.Especially,there is a hole in the shore so that we can make the cables of motor across it.It can protect the cables from clash and rub.and,reduce the air resistance.
Old Jan 06, 2011, 01:22 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Are these push-on rotors or do they use adapters... if so, do you have adapters for all popular sizes of motor shafts.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 06, 2011, 02:47 PM
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Sigh............
Looks like a copy of the GWS housing. Even if it isn't - you still screwed up the design by using 3 stators. Fan housings need at least 4 or else you end up warping the housing when installed, and the fan rubs.
skyhawk is offline Find More Posts by skyhawk
Old Jan 06, 2011, 02:51 PM
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, OH, Columbus
Joined Jul 2010
Are they balanced? If so I would love to try one.
mikes68charger is offline Find More Posts by mikes68charger
Old Jan 06, 2011, 05:34 PM
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Skyhawk, AEO cases are far more stronger than GWS cases. They are really hard to warp. The material used is much stronger. Using 3 stator vanes is exactly what you will need for the 8 blade rotors. The AEO motor mount is much more adaptable to various motors than the GWS cases (for the smaller sizes).
Great stuff Hu! I gotta try me one of those new 7 bladers! It looks like the hub is `12mm?
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 06, 2011, 06:40 PM
Hampton, VA
Joined Mar 2009
I can second that. While getting data on an earlier version 30mm/6 blade, I had to hold on to the DF unit very tightly. I was afraid it would jump out of my grasp, it was putting out over 100g thrust. I could not have done that with the GWS, the DF unit would have distorted.
If they're getting >20% more thrust and on 2S, that's awesome. I'd like to know if the amp draw is down over the earlier verson though. I'd like to be able to keep bat size down as much as possible. Small light planes, with relatively heavy bats, don't last long.
Ksqm
ksqm is offline Find More Posts by ksqm
Old Jan 06, 2011, 07:16 PM
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Wow, really cool! What motors are available for the 30mm? Just how much thrust can you get? Do you need to resort to ultra micro gear, ie like the Parkzone "brick", or can you use really small servos and mini 2.4GHz Rx's? How about an esc? I'd really love to make a stick and tissue type (like the old rubber scale models I used to make as a kid) super micro size jet to fly in my front yard.
Stu.
stumax is offline Find More Posts by stumax
Old Jan 06, 2011, 07:35 PM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Yea, with an even number of blades, you would need either 3 or 5 stators. HET 6904 uses 3. Works OK by me.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Jan 06, 2011, 07:55 PM
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Hope these parts show up in the marketplace so we can order some, and find them in stock, on a regular basis.
Freddie B is offline Find More Posts by Freddie B
Canada
Joined Nov 2000
Interesting Video here of the 30mm and a? c10? (hard to be sure but it's the right colour at least :-)
AEO 30 MM EDF 8000KV
2S 400MAH ESC 12A
http://v.youku.com/v_show/id_XMjI5NDA3MDE2.html
2S 800MAH ESC 12A
http://v.youku.com/v_show/id_XMjI5NDA2NjIw.html
Note the 50 and 60 gm thrusts :-)
Gotta love AEO's traditionally 'optimistic' claims, which in the not too distant past were acknowledged to be generated by blowing eflux onto a scale. Wonder If they've recently improved their methodology.
Bare is offline Find More Posts by Bare
Old Jan 06, 2011, 08:10 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Bare, I couldn't read anything about the specs on the pages.
Where is it or can you cut-n-paste please?
Old Jan 06, 2011, 08:25 PM
AEORC's Avatar
P.R.China
Joined Aug 2008
Thanks,David.
Yes, you are right.Our cases are very strong and hard to warp.3 stator vanes desgin reduced the air resistance.And you can also make the motor cables through the tube in one of the stator vanes ,it can also reduced the air resistance and protect the cables from rub and shake during the flight.
Which hub is 12mm you said,David?
Hu
Old Jan 06, 2011, 08:43 PM
Hampton, VA
Joined Mar 2009
Bare,
Check out my video in the AEO 30mm 8000Kv thread (http://www.rcgroups.com/forums/showt...2#post17027219), it shows the actual readings for 3S from my Watts Up meter. I'll have to mount the DF unit in a plane to get thrust readings, but I could barely keep the little sucker in my hand during the run up. It's an early 6 Blade version. Short of having to press on the rotor, I'd say it's the real deal.
Ksqm
Old Jan 06, 2011, 09:00 PM
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
How many rpm's have you safely spun the 70mm to? I would hope it will hold together to at least 50,000, preferably 60,000.
IIRC most 70mm edf's spin in the mid to upper 40,000 rpm range.
ex-racr is offline Find More Posts by ex-racr
Yippee! Extreme RC's CNC Alloy 64-127mm Ducted Fans & Jet models discussion thread Extreme_RC Electric Ducted Fan Jet Talk 145 Jul 23, 2011 04:14 AM
Discussion New Metal Ducted Fans for 70mm to 90mm EDF Jets! nitroplanes Nitro Planes 1 Jun 15, 2009 09:59 AM
Sold Mega 16/15/2 EDF Motor for Wemotec 480, HET 6904, and similar 64~70mm fans shschon Aircraft - Electric - Jets (FS/W) 0 Oct 05, 2008 02:01 AM
