Old Dec 08, 2013, 02:15 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
With a lot of washout the tips can end up lifting downwards when flying at higher speeds. But in that case you've got more than enough available lift from the main portion of the wings so it's not really noticeable. It would add some drag though so if high speeds are a goal then limiting the amount of washout is a good idea.
On models where the size is suitable for adding flaps there is much to be gained. And not just from the idea of adding lift and/or drag. When you lower the inboard located flaps you increase the angle of incidence for that portion of the wing. And that has the effect of twisting the wing into a highly washed out sort of shape. So using flaps greatly reduces the risk of tip stalling during takeoff and landing along with all the other more usual flap effects.
BMatthews is offline Find More Posts by BMatthews
Old Dec 08, 2013, 09:33 PM
Su-27's Rule!
Su-33's Avatar
Philippines, NCR, Pasig City
Joined Nov 2012
thanks BMatthews!
Su-33 is online now Find More Posts by Su-33
Latest blog entry: A cheap way to measure Kv
Discussion washout, root stall and other gadgets Oldog Modeling Science 45 Apr 16, 2013 11:41 PM
Question washout verse increase camber rayd60 Sailplane Talk 8 Nov 05, 2010 10:39 AM
Discussion To camber or not to camber, and more importantly when to camber??? Edwinzea Sailplane Talk 7 Aug 19, 2010 12:28 PM
Discussion Washout...? What a washout...! chris williams Scale Sailplanes 13 May 15, 2010 01:14 PM
Discussion higher camber, lower camber, and thinning at the tips atjurhs Sailplane Talk 14 May 01, 2008 03:02 AM
