Old Aug 28, 2013, 12:55 AM
Blenheim, NZ
Joined Dec 2007
Can antone help with SZD30 PIRAT Data?
Hi,
I'm interested in scratch buildingan SZD Pirat. There is not much on the net although I did find a very low res image of what I suspect is a detailed factory drawing. Can anyone help me with a good 3 view or electronic set of plans? The attached 3 view is available but really I would like something a bit higher res and with some fuselage cross sections. The kind of thing you find in Martin Simon's books would be great. I really should buy these.
Thanks in anticipation
Allan
AllanK1 is offline Find More Posts by AllanK1
Old Aug 28, 2013, 03:43 AM
Czech Republic, South Bohemian Region
Joined Feb 2009
Allan,
have you seen this?
http://richard.ferriere.free.fr/3vue...0_pirat_3v.jpg
Or best 7 Euro ever spend..
http://www.model-plan.com/offer/40
no limitz is offline Find More Posts by no limitz
Old Aug 28, 2013, 05:27 AM
SB-28 UK Display Pilot
GeeW's Avatar
ENGLAND
Joined Jul 2001
Be warned all Pirats had a mandatory rudder change. Most 3 views show the original rudder where as most images show the later rudder!
The retrofitted rudder was narrower in chord at the top and wider chord at the bottom to reduce torque on the fuselage.
Still have my original rudder.
http://www.kitcutters.com/RCM/RCMSail/RCMSZD30Pirat.htm
http://www.trapletshop.com/gb/p/11862/szd-30-pirat The colour scheme shown on the thumbnail is my old Pirat.
GeeW is offline Find More Posts by GeeW
Old Aug 28, 2013, 10:31 AM
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
https://www.google.dk/search?q=pirat...40%3B600%3B433
Good luck
S
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old Aug 28, 2013, 04:28 PM
Blenheim, NZ
Joined Dec 2007
Some times I wonder why I look for my self. Much better just to ask you guys. No Limits, the 3 view is exactly what I need for now. That image off Google images is tantelizing too. There is a heap of info on it but it can't be read at this resolution.
Allan
Old Aug 31, 2013, 05:27 AM
Aerotow and sloping Holland
MaartenX's Avatar
Joined Mar 2012
Good Luck with you project.
Yesterday I saw a 1:1 Pirat on the winch at Hilversum in the Netherlands together with no less than 2 Alsema Sagittas.
The Pirat is a beautiful glider.
Regards, Maarten
MaartenX is offline Find More Posts by MaartenX
Old Aug 31, 2013, 06:32 PM
Blenheim, NZ
Joined Dec 2007
Thanks Maarten,
I'm not sure about beautiful but it is an unusual model. I like the wide chord. Plenty of area at a modest span and a great tip stall resistant wing plan form. It is this or a Pillatus B4 as my next scale build. The B4 is a much more common model build so I thought the Pirat would be a more interesting build. It will be a composite build like my SHK although I'm tempted to do a veneer and glass skin the cut out the open areas to better replicate the real one. I've loaded up the design in Plane Geometry and it has good proportions to fly well. I'm looking at 170 inch span and 1800 sq inches to get a scale that will let the fuselage fit my car.
Well that's the plan for now. Who knows what I'll b keen on when i next make a start.
I'll probably take a couple of evenings and built a little 900 mm span model to get a feel for the shape. This is a great way to see the machine in 3D and it can hang in the workshop for inspiration.
Cheers
Allan
Allan
Question Help with fy606 data radio&fy31ap Jengaleng FPV Talk 1 Jun 29, 2013 02:24 PM
Help! Hay SW pro's can you help with this? Artful Owl CAD/CAM 16 Jun 20, 2013 11:14 PM
Question Motor data sheet. Who can explain these sheets? What does these motor datas mean? CyberCrash Multirotor Power Systems 1 Jun 07, 2013 07:26 PM
Discussion HELP! Problem with OSD (No data on screen) brujacra FPV Equipment 0 Mar 24, 2013 11:53 AM
Question Can someone help me with Benedini sound system, please? abenn Electric Plane Talk 7 Feb 05, 2013 08:44 AM
