Old Aug 26, 2013, 01:59 PM
Afton VA
Joined Sep 2002
If it is just a skin de-lamination and the surface underneath is not compromised, just some thinned epoxy poured in under the skin and squeegeed/pushed out might be best. The foam will work, but you need to be sure to use a small amount and after it expands a bit and before it sets, to push all you can out the open area. It is a great adhesive and much lighter than the epoxy, but you have to stay with it and make sure the area is kept flat while it sets. That's about 5 min of working with it. You do NOT want to let it set up expanded.
The foam is good if you fill the inside and want a nice solid (but no weight) area.
tbroeski is offline Find More Posts by tbroeski
For Sale Urethane Foam -- Repair Kit, Etc. tbroeski Aircraft - General - Miscellaneous (FS/W) 5 Jan 24, 2013 03:11 PM
Sold Urethane Foam -- Wing Repair Kit tbroeski Aircraft - Sailplanes (FS/W) 20 Dec 06, 2012 12:25 PM
Discussion Molding foam: Thermaforming vs. liquid urethane spencer6891 Foamies (Scratchbuilt) 7 Jun 28, 2012 05:29 PM
Discussion Anyone play with this Liquid Urethane Expanding Pour Foam videorov Composites Fabrication 1 Mar 31, 2012 02:15 AM
Discussion How to repair dents on solid core molded wings GaryO Hand Launch 5 Mar 20, 2012 09:15 PM
