Old Jan 18, 2012, 05:02 PM
Joined Jan 2012
Crawlers controls work in reverse
Hey folks,
I own a maxstone 1/8 crawler. When i go forward the truck will reverse, when i steer right it will go left and left will go right. It will also go full speed reverse when i turn the power off on the transmitter.
I have tried all the switches on the transmitter and changed all the batteries.
It seems like an issue with the transmitter, but im pretty new to the field.
Thanks a lot
Jess
cvette is offline Find More Posts by cvette
Old Jan 18, 2012, 07:39 PM
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
you need to reverse the switches on the inside of the cover it will say st nor/rev then thro norm/ rev simply switch them the other way from what they are .
rcphreak is offline Find More Posts by rcphreak
Old Jan 18, 2012, 08:13 PM
Joined Jan 2012
Thanks for taking the time to help me out. I tried reversing the switches and i still have the same outcome. The switches worked fine before all of this started happening.
Jess
Old Jan 18, 2012, 08:22 PM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
not sure try and rebind the truck i also have a max stone but the switches were in the correct position when it was new.
Old Jan 18, 2012, 09:46 PM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Turn the body around
And don't turn the transmitter off while the truck is still on.
1320fastback is online now Find More Posts by 1320fastback
Old Jan 20, 2012, 05:17 PM
Canada, BC, Victoria
Joined Mar 2004
I was going to say basically the same thing - you're holding the transmitter upside down! Sorry, couldn't resist.
I'm not clear - did the truck ever work properly?
It sounds like the "failsafe" has been set to full reverse. Check the manual, and re-bind with the thottle at neutral. The forwards/reverse mix up may just be the motor wires reversed, but I don't know why the steering wouldn't respond to changing the reversing switches.
Colin
ColinB is offline Find More Posts by ColinB
Old Jan 20, 2012, 05:24 PM
Joined Jan 2012
Thanks, yes the truck worked fine for a month, but i forgot to mention i used it at approx -20 degree temperature. I will look for the manual and try to rebind it.
Jess
Old Jan 21, 2012, 12:53 PM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
i do know water and electronics do not mix if you used it outside then took it inside while using it may have dammaged the reciver due to condensation .
also when rebinding switch the switches to norm. then rebind .
Discussion How Does Reverse Work on Car ESCs? r691175002 Electric Power Cars 1 May 25, 2011 10:12 AM
Discussion Why do brakes work way better in reverse?! Junglemaxx Motorcycles 3 May 19, 2007 09:25 PM
Will airplane radio work in boat w/ reverse? Mike B944 Dock Talk 6 Sep 15, 2005 04:45 PM
EDF-50 Will it work in reverse? rustydog Electric Ducted Fan Jet Talk 12 Mar 11, 2002 02:38 AM
