Old Nov 12, 2014, 12:29 PM
tibyy17's Avatar
Hungary, Gyr-Moson-Sopron, Győr
Joined Oct 2014
Thank you. I do have both, and Im not 100% sure i did everything right, I will get back to you, I just tried to rebind the transmitter to the receiver and transmitter come up with the Esky sickness: dont want to send the binding signal to the reciever. Just great. S2 still flashing yellow. I just read on another post somewhere, does the S2 need a dsm2 satelit on first set up?
tibyy17 is offline Find More Posts by tibyy17
Old Nov 12, 2014, 12:56 PM
United States, CA, Signal Hill
Joined Aug 2009
no not if you are using a standard rx
if its not connected properly to the rx could also cause flashing light
wc_wickedclown is offline Find More Posts by wc_wickedclown
Old Nov 12, 2014, 04:47 PM
tibyy17's Avatar
Joined Oct 2014
Wicked I will get back to you as soon as my skyartec receiver arrive. My esky transmitter got bricked in pc mode somehow. Thank you for offering your help with the zxy s2.
Old Nov 24, 2014, 04:43 AM
Atomic Skull's Avatar
Joined Dec 2011
Does the ZYX-S2 have a built in governor or does it still need the expansion module like the original ZYX?
Can you use combined PPM to connect to the receiver or does it only support sbus for single line connection?
Atomic Skull is offline Find More Posts by Atomic Skull
Old Nov 25, 2014, 08:29 PM
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
No, zyx-s2 has no internal governor and original zyx expansion module does not work with zyx-s2.
Not sure about ppm support. Expansion module can support 2 Sbus and 2 Satellite Rxs.
lcc014 is offline Find More Posts by lcc014
Old Dec 10, 2014, 07:36 AM
tibyy17's Avatar
Joined Oct 2014
Hello again.
My receiver arrived yesterday after sitting 2 weeks at the customs (hooray). Zxy-S2 recognise it and LEDs turning constant red or blue depend on gyro setting (hooray). But I got another issue: 1.1 Pc software doesnt recognise transmitter input at monitor tab . So i cant adjust travel what would be a disater as i got from -19degrees to +22degrees pitch so servo limit adjusment would be necessary. Did someone had this issue and managed the transmitter recognised by pc software? Should the transmitter connceted to the pc via trainer cable as well and after sofware recognise the transmitter inputs or the inputs should go trough the ZXY-S2 connection cable?
Old Jan 20, 2015, 12:03 PM
Joined Sep 2013
Hi guys,
I 'm eyeing the post and can not find much information about the zyx S2 , I read the post of Dr.M , these explanations apply to zyx S2 ?
Could put the advanced settings of a pro Trex450 to contrast .
Thanks , Greetings
escurxo is offline Find More Posts by escurxo
Old Jan 20, 2015, 07:52 PM
Joined May 2011
Did Tarot fix the ZYX-2S? I have two old ZYX-S and they perform flawlessly. I had two hk 250s, one with a yellow mini k bar and the other with the ZYX-S, the one with the mini k bar had a tail wag that wouldn't go away no matter what advanced settings I put into it, the one with the ZYX-S flew great. So, I decided to replace the mini k bar with a second old ZYX-S (I had laying around), with out changing any, and it flew perfectly right off the bat! I also have a hk 450pro fbl with a black mini k bar, which had a slight tail wag and a bounce, I replaced the clone Fitec S9357 tail servo with a Futaba S9257 and the wag and bounce pretty much went away. I was thinking maybe I'll replace the black mini k bar with a ZYX-S2 because I don't think I can find another ZYX-S, but I heard a lot of people were having problems with this fbl gyro.
mugen 1 is offline Find More Posts by mugen 1
Discussion New ALZRC 3GYS Flybarless System beenflying Mini Helis 644 Dec 07, 2012 05:44 AM
Found Tarot 450 or like, long flybarless feather shafts TubeBarHeli Aircraft - Electric - Helis (FS/W) 2 Jul 25, 2011 02:13 PM
For Sale New Align 3G Flybarless System V2.1 ptt81 Aircraft - Electric - Helis (FS/W) 1 Jun 06, 2011 05:55 PM
For Sale New 2 cell esc &motor FBL 4g6 spektromized DSM2 spektrum Sat URondo Flybarless system blueindian Aircraft - Electric - Helis (FS/W) 0 May 31, 2011 07:09 PM
Discussion Tarot Flybarless avengedkevinfold Electric Heli Talk 1 May 04, 2011 05:46 AM
