Sub 1.5 gram Actuator Drive Spread Spectrum is here...
Hi Folks,
OK that got your attention A few days ago Dave (small.planes) posed the question 'how does the Spektrum AR6200 talk to the Remote Receiver' [SPM9545] http://www.spektrumrc.com/Products/D...ProdID=SPM9545. Well, as there are only 3 wires, how hard can it be The answer - the interface is very simple!! Dave bought an AR6200 with remote receiver and after a bit of probing with the scope and lashing in a MAX232 chip we now have the data on a PC The communication is predominantly one way, SPM9545 to AR6200 (see binding below). It is a serial link similar to RS232 but with 3V logic levels running at 115K2 baud 1 start bit, one stop bit no parity. The idle state for the line is logic 1 (3V). Packets are sent approx every 22ms and consist of 16 consecutive bytes. Each Channel item is two bytes long with the least significant byte send first. Packets for the DX7 and the DX6i are in a different channel order We suspect that as part of the bind the RX learns which sort of Tx it is bound to, otherwise the wrong servos would move!Both formats use a sync word of 0x0301 then the DX7 has: Aileron Flaps Gear Elevator Aux2 Throttle Rudder For example a centre stick packet from a DX7 is (HEX values): 0301 0601 1600 10AA 0A00 18AB 015F 0DFC The DX6i has a different channel order: Aileron Flaps Elevator Rudder Throttle Gear Aux2 - fixed value Ranges for the values are (DX7) Aileron: left 0x5507 (21767)Flaps: up 0x5617 (22039)Gear: up 0x5613 (22035)Elevator: up 0x560B (22027)Aux2: up 0x571B (22299)Throttle: up 0x5503 (21763)Rudder: left 0x530F (21263)Ranges for the values are (DX6i) Aileron: left 0x6007 (21263)Flaps: up 0x6517 (25879)Elevator: up 0x540B (21515)Rudder: left 0x4F0F (20239)Throttle: up 0x6103 (24835)Gear: up 0x6513 (25875)Aux2: always 0018 These reading are from a new airplane model with no mixes on both TX's The DX6i gives similar values except Aux 2 remains at 0x0018 since it is not (we presume) transmitted, or it is transmitted at a fixed value. (note: possible 'hack' on a DX6i for a 7th channel?) The DX7 has 3 position Flaps, as opposed to the DX6i 2 position. The values are nice simple 2s compliment numbers. The remote receiver stops sending frames if the transmitter is turned off (and presumably if it loses the connection as well). Binding ------- There is some conjecture here but we suspect this is pretty close to what happens: At power up the remote receiver [SPM9545] samples the data line, if it is high it waits for a bind request. When in bind mode the main receiver performs the following actions: It sets that data line to the remote receiver to high, waits 100ms and then send the following: 120µS Low 120µS High 120µS Low 120µS High 120µS Low 120µS High 120µS Low then remains High At some point the main receiver then redefines the data line as an input. The remote receiver does not reply to this but enters into bind mode. Once it is bound it then transmits the data frames as described above. Note the bind information is stored in the remote receiver, it is not sent from the main receiver to the remote receiver. The main receiver only requests that the remote receiver goes into bind mode - This is much simpler than it could have been!!!! This is proven by first binding both receivers to one TX, and then rebinding just the Main receiver to a second TX. With both TX's on both receivers have a solid LED, with just 1 only the correct receiver is lit. The suspicion that the main receiver knows which TX it is connected to is that the channel ordering changes in the packets on the link, The remote receiver appears to be 'dumb' and just send the channels in the order it receives them, leaving the main receiver to sort it out. So what does this mean? The SPM9545 remote receiver is about £20, $25, somewhat less than a AR6300 The SPM9545 remote receiver weights about 1 gram with no case. So a 1.3 gram DSM2 actuator drive system should be possible More exotic solutions such a brushed twin steering system are possible. Or three actuators and a brushless ESC....... It is possible that SPM9545 will work off 1 cell. Note it runs on 3V provided from the main receiver and has noregulator so an external regulator is needed for more than 1S. I suspect it will be safe to run at 5V from an ESC regulator but we havent tested this. The main problem we see is the high data rate which may require a higher end processor. suggestion: https://www.silabs.com/products/mcu/...s/default.aspx something like the C8051F31x range has loads of pins in a tiny package So over to you folks, who's volunteering for an open source solution Best regards, Andy and Dave. |
This is cool stuff. Do check into my DSM2 transmitter project using the LP5DSM or similar tx board(same board a remote receiver uses more or less) The data looks pretty similar.
I think a simple receiver could be whipped up pretty quick using an Atmel AVR. Depending on what hardware is in a remote receiver less then 3 volts might be ok. The RF chip should be ok to somewhere around 2.6volts. Any Cypress CPUs though all need 3 volts. I already have a receiver that works using a Maxstream xbee, it converts serial to PWM to drive servos and has failsafe integrated. A few minor changes and it should work with the Spektrum remote receiver. The nice thing about using the remote receiver is there should be no FCC issues. The various types of receivers may need to be sampled to see if the bind data is different. The data also needs to be looked at from a 2048 bit transmitter. |
Loughborough Leics England
Joined Sep 2002
did a bit more probing this lunch.
Was thinking, as the 6100 and the main 6200 are the same PCB it makes no sense for them to have different firmware. So i checked, and lo and behold a 6100 puts the same bind signal out of the 3 pin header as the 6200 ![]() This isnt a lot of use, unless you have a 6100 but really need a 6200, in which case you can just add the remote RX, but its interesting anyway. Steve, I dont understand the concern for a processor that runs at under 3V? If you are single Lipo cell then less than 3V is a bad thing anyway. Or have I misunderstood? Dave |
I've been told that the AR6100 does indeed have different firmware and it will not work. Guess I need to go back and solder a connection onto one and try. It would be a lot easier to add a connector to an ar6100e than it would be to change to the right angle servo connectors on the ar6200.
I have been thinking about this further and realized binding with just a satellite receiver will likely not be possible. During binding the main receiver sends a packet to the transmitter to ID the type/specs of the receiver. While the satellite also goes into binding mode I don't believe it transmits anything to the transmitter, only the main receiver does. If a DSM2 receiver doesn't send a packet during binding the DX7/x9303/12x etc will assume the receiver is DSM and not DSM2. Of course it would be fine if we used a regular receiver to bind with and then unplugged it to use with out decoder module. So whats the preferred hardware? I was thinking a tiny board with an Atmel AVR that had 3 actuator outputs and one PWM output. What kind of current does the average actuator require? An ESC can be included but brushless might be more fun anyway. |
I would offer both a brushed and a brushless version of the board. Also an act and a servo version. That would make 4 different designs. Also would be nice if it had a buck/boost that could do 1, 2, or 3 cells and probably need to regulate for the servos at that point. Maybe only 1 and 2 cells
For the DM8/DM9 module users like myself, it should be easy enough to pull the TX ID out of the air and just load it into the receiver (maybe use an AVR Butterfly with RF6936 chip for this task). If you use a Butterfly, then you could also use it for programming failsafe features, and anything else that needed a cheap interface. Maybe you could trick a normal receiver into being a slave binding device for the Spektrum/JR transmitters. Maybe tap the data between the rf chip and the MCU on an AR6100 and pull the ID code into the Butterfly. That way you would still have model match, but you would lose the 2048 resolution (does anyone really need more than 1024 for an indoor model???). Sure wish I was as good with developing this stuff as I am with the ideas of how to implement it. |
Heh, I think you need to work on developing some more, then continue the dreaming.
![]() ![]() ![]() I can't see anyone wanting to develop a bunch of different versions. If I did one it would be as small, light and simple as possible. Binding would be handled by the stock main receiver, 3 acts, pwm or esc for the motor drive. |
Joined Sep 2002
Ok, I hadnt considered the reboot issue... I tend to stop when my cells are about 3.2 - 3.4V, as with helis I find I cant concentrate any longer than about 6 to 8 mins...
Ill try and bind a remote RX on monday, when Im at work with the scope etc. I guess Ill force it into bind mode then unpower the main RX and see if I can bind it. I dont think having to plug into the main RX to bind would be that much of an issue, its not like you bind eveytime you fly, I have to partially disassemble my Gaui 200 to get the bind plug onto the RX for instance Andy B is the man to ask about actuator drive, he has some code which is already open sourced for doing it. basically you drive a pair of outputs, pull one to ground and waggle the other one depending on the control throw, and for going the other way you pull the other one down and waggle the previously gnd one. Dave |
Joined Sep 2002
Hmm, scope and soldering iron out and Im (more) confused now...
The remote RX does indeed not work with the AR6100, the signals look ok, but there is a slight glitch, like the 6100 CPU not turning a pin round to input. could be that spektrum does have different firmware for the 2 RX's, tho that doenst make sense from a version control, bug fix etc POV The remote RX is 5V proof (well 4.8V RX pack anyway). Good thing, as I forgot it was 3V til after Id connected it but it doesnt just run without being connected to the 6200... ![]() Even with the 6200 bound to a different model (IE it hasnt initialised the link from the TX) the remote RX runs when the correct model is selected in the TX. Im not sure why it wont run 'standalone', I cant find any 'please go' commands coming from the Main RX, it 'just' starts sending frames when it links to the TX (led goes solid). Dave |
I would consider a PWM signal for a small brushed motor maybe a 6A FET which would be OK for most pagers under stall. I would still include a servo style pulse to go to a brushless controller driven at the same time, small brushless is becomng very popular Of course a simple starting point may be to emulate the 6300 in the AVR providing a slightly cheaper alternative to buying the 6300 Actuator coils are usually 50R or more say 30R worst case this gives 140mA so they are usually driven by a h-bridge or other driver. Here are some popular ones: A3901 0.4A RDS(ON) = 1.2R DFN package so hardest to solder but the smallest! One IC does one coil. FDG6332C 0.6A RDS(ON) = 0.3R SC70-6 pretty small and still has legs! You need two per actuator. NDC7001C 0.35A RDS(ON) = 7.5R SOT-6 easiest to solder, again you need two. There are at least two schools of thought on driving actuators either standard PWM altering the mark space ration between full on and full off and Pulse Frequency Modulation, altering the frequency to the coil (I've never tried this but many people say its better!). In both cases one output is held steady as the other is driven. To drive the coil the other way you hold the other output steady while driving the other output. Dave and I are totally puzzled as to why the remote receiver won't start up without the 6200 connected, We cannot see any exchange of data on the scope (other when binding) we've tried pulling the data line high and low via 20K and leaving it unconnected but not a squeak from the remote RX (It normally blips its LED at start up). I think this need to be cracked before going any further Andy |
| Thread Tools | |
| Video 1.5 Gram Living Room Flyer! | micromad | Electric Plane Talk | 2 | Jul 29, 2008 09:29 PM |
| Yippee! 1.5 gram 3ch plane | david_dewit | Indoor and Micro Models | 169 | Apr 25, 2008 07:14 PM |
| Sub 1.5 gr 3 Channel Biplane from Lad (St.Petersburg, Russia) | Lad | Indoor and Micro Models | 46 | May 03, 2005 01:46 AM |
| FS: Omega 1.5 and Kontronik Drive 200 | NickW | Aircraft - Electric - Airplanes (FS/W) | 4 | Apr 21, 2003 04:59 PM |
