Old Dec 20, 2013, 10:47 PM
Joined Dec 2013
Is flying a Tricopter "backwards" more efficient?
Hello, all! This is my first time posting on these boards
My interest in tricopters has just been piqued the other day, and while I don't currently have one, I've been trying to stuff my brain with knowledge about them ever since.
At any rate, one thing I've been wondering is if flying a tricopter with the yaw motor out front might be more efficient in forward flight than the more common configuration of steering from the rear. The logic is that when it's out back, it needs to produce more thrust (vs hover) to tilt the craft forwards, whereas when it's leading, it need to produce less thrust (vs hover) to tilt it forwards. While the difference might be negligible on common crafts, I'm wondering if it would be more noticeable on larger ones.
Anyone have any thoughts about this?
Cheers,
Mark
markaeric is offline Find More Posts by markaeric
Old Dec 20, 2013, 11:25 PM
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
Welcome to RCGroups.
Not sure about efficiency but many tricopter pilots seem to prefer the "tail authority" a tricopter gives you.
Check out David Windestål's website, he knows his way around a tricopter
http://rcexplorer.se
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Dec 20, 2013, 11:26 PM
Wedding Photographer
CG Photo's Avatar
United States, CA, Fresno
Joined Feb 2013
No, that's not how it works. Your thinking too hard.
CG Photo is offline Find More Posts by CG Photo
Old Dec 20, 2013, 11:54 PM
Joined Dec 2013
Thanks. David's site was on of the first I came across when I started looking into them. I'll go ahead and ask him as well.
Could you elaborate on this a little? If the yaw rotor was in front, would the rear rotors need to pick up the slack during forward flight?
I wouldn't say I'm thinking too hard about it, but I'm legitimately curious.
Old Dec 21, 2013, 12:11 AM
1sq
1sq's Avatar
United States, CA, Imperial Beach
Joined Mar 2013
You'll be the first and post your observation.
1sq is offline Find More Posts by 1sq
Old Dec 21, 2013, 12:33 AM
Canada, BC, Surrey
Joined Jul 2002
Sweet tri.
Mine is a bit different: two motors are 80 degrees apart in stead of 120, the yaw motor is pivoted just below the prop instead of on the bottom of the motor giving better balance.
The yaw prop is 1 inch longer and 1 inch greater pitch. Oh, and the pointy end goes first.
Flies beautifully.
Lyle.
Lyle is offline Find More Posts by Lyle
Old Dec 21, 2013, 11:16 PM
Joined Dec 2013
I just might have to be
Flies beautifully.
Lyle.
Hey Lyle. I tried doing a forum search to find your tri, but I didn't come across anything
If you've posted it before, could you link me to it?
What was your logic behind using a larger prop on the yaw motor? I didn't note the user's name, but the other day on this forum I saw a tri with a smaller tail rotor than the other two, which I presume had the CG closer to them.
With my first build (T frame and motors 120 degrees apart), I'm planning on having the yaw prop pivot along the horizontal plane of the prop disk (also level with the other two).
Cheers,
Mark
Old Dec 22, 2013, 11:11 PM
Joined Dec 2013
I had a feeling something was wrong, so after researching a bit more on how multi-rotors fly, I've found the flaws in my reasoning. I thought thrust inequalities between rotors were responsible for translational movements, when in fact they only change the pitch/roll of the craft. That throws the whole premise of efficiency gains depending on what rotors are in front completely out the window.
Nothing more to see here.
-Mark
Old Dec 24, 2013, 10:00 AM
rimshotcopter's Avatar
Joined Aug 2009
The Truth in my opinion is, you can get anything to fly with the right motor mixing. Just have to invest sometime figuring that out because, the standards mixing may not work to expectation.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jan 10, 2014, 03:40 PM
Joined Nov 2013
No, you were right the first time. In a traditional Tri as the rear motor is turned (creating yaw) the tail drops. This makes for an ugly turn, so you have to increase thrust to the tail to compensate. It would be more ideal if the turning motor was in the front, so as you yaw the nose digs into the turn.
quaDR is offline Find More Posts by quaDR
Old Jan 10, 2014, 05:26 PM
Yep, Naza-controlled Tricopter
tonyestep's Avatar
St. Louis
Joined Apr 2002
Where are you gonna put the camera?
tonyestep is offline Find More Posts by tonyestep
Old Jan 13, 2014, 08:01 PM
Joined Dec 2013
My understanding is that even if the motor was in front, you would still have to increase thrust to it while turning to offset the thrust needed to turn (and more in one direction than another). Regardless, that's not what I thought in my initial posts; I though that in translational flight, some of the motors are constantly providing more thrust than others which isn't correct - differential thrust is used only to provide the initial change in pitch/roll.
Discussion Xoar Props more efficient at any size? ChiTownFlyer Electric Plane Talk 22 Jun 14, 2014 02:12 AM
Question parallel vs series charging - more efficient bajinuk Batteries and Chargers 6 Dec 12, 2013 07:42 AM
Discussion More efficient Quad - Y4 ver2go Multirotor Talk 1 Nov 23, 2013 12:43 PM
Discussion Backwards flying cub, cub flying backwards, or some odd thing. Rusty-Gunn Foamies (Scratchbuilt) 14 Jan 28, 2009 11:28 AM
which more difficult: flying backwards or flying inverted forward ? Kraeuterbutter Electric Heli Talk 18 Jun 15, 2005 03:34 AM
