Old Aug 15, 2013, 02:30 PM
United States, FL, Stuart
Joined Apr 2012
Question
Binding problem
I wanted to switch my plane over from a DX5e to my new DX6i.
Put in the binding plug and tried - Nothing.
After several attempts I swapped out receivers (same type) - and No problem. Bound right away.
The "original" receiver is still bound to the "original" Dx5e.
I would like to "clear" the original receiver for use with my new transmitter.
Your input would be appreciated.
Electrofish is offline Find More Posts by Electrofish
Old Aug 15, 2013, 03:01 PM
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Put the binding plug in and power it up and the lights flash.
What receiver is it?
barracudahockey is online now Find More Posts by barracudahockey
Old Aug 15, 2013, 03:30 PM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Make sure that the Tx is at least 6ft away from thr Rx when you attempt to bind.
Any Spektrum receiver should work with the DX6i except, if the DX6i is the DSMX version, it wont work with the old AR6000 Rx. But AR6000 Rx's are pretty rare these days so I doubt you have one.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Aug 16, 2013, 10:54 AM
Joined Apr 2012
Orange R615
replaced it with the same which had no trouble binding.
Old Aug 16, 2013, 11:18 AM
billisfree's Avatar
Joined Oct 2012
And you are holding the trainer switch on when turning on the Xmitter? Just checking.
billisfree is offline Find More Posts by billisfree
Help! Problem binding WLtoys V929 to stock transmitter JMounty Multirotor Talk 7 Nov 12, 2014 09:35 AM
Discussion Frsky bind problem (before worked fine) nuki Radios 20 Jul 12, 2014 02:28 AM
Discussion FrSky Binding Problem - RX wont go into bind mode squishio2 Radios 6 May 11, 2014 10:26 AM
Discussion HK-T6A V2 Tx binding problem midelic Radios 40 Apr 08, 2014 10:16 AM
Help! Binding problems with a DX8 and AR8000 problem wc_wickedclown Electric Heli Talk 0 Jul 05, 2013 03:48 PM
