Old Feb 16, 2013, 07:56 PM
darn you, kakka carrot cake.
derpron's Avatar
Australia, WA, Perth
Joined Aug 2012
grey depron + hotglue
i know everyone glues their depron together with hotglue but does anyone think the grey depron doesn't stick to hot glue that good? i mean, even a mild crash on a plane, im always having to reglue parts of the plane because the hot glue just seems to peel away from the depron...
i have a ozito 170c-190c hot glue gun and i cant let it heat up to that temp because it burns through the foam...
and i only buy grey depron because its cheaper
derpron is offline Find More Posts by derpron
Old Feb 17, 2013, 12:49 AM
micka80ella's Avatar
Australia, QLD
Joined Apr 2012
http://www.micronwings.com/Products/UHUPor/index.shtml
or try ebay for uhu por, it is a bit pricey but with depron and its vital joints this is what you need, hot glue is quick and easy, but nowhere near as strong as this. Hobbyking used to sell chinese magic glue which i have - very good but not as easy to use as uhu por.
Hot glue works good as fillet glue - fill the gaps (use sparingly) but someone on here might explain how to use hot glue properly to form a strong joint, i have tried and still go back to the contact adhesive style for depron.
micka80ella is offline Find More Posts by micka80ella
Old Feb 17, 2013, 06:02 AM
PowerTower
RWData's Avatar
United Kingdom, England, Bristol
Joined Aug 2009
Yes, UHU Por is the way to go. It remains flexible but strong in joint. The problem with hot-glue is it's too hard, and it does tend to sit on the joint as opposed to penetrate. It's also somewhat heavier especially the amount you need to use. The ideal adhesion point is 'in' the joint, but the moment you deploy the hot-glue it's already cooling to harden off before you can make the joint. It's okay to use like a fillet joint and really the best way I found is to lay a stitch along both sides of the joining part. This is clearly not always possible, so better use UHU-Por, and perhaps change your design to incorporate slot/peg in critical joints.
RWData is offline Find More Posts by RWData
Old Feb 17, 2013, 06:53 AM
derpron's Avatar
Joined Aug 2012
ah okay thanks for the responses
Sold Grey depron foam plane. the_only_kris_20 Aircraft - Electric - Airplanes (FS/W) 4 Sep 17, 2008 01:07 PM
Discussion Grey Depron Dennis C Indoor Pattern/F3P 6 May 09, 2008 11:42 PM
Sold 6mm grey depron sheets - 39"x15" - 9 sheets total whitty7628 Aircraft - General - Miscellaneous (FS/W) 1 May 09, 2007 12:00 AM
A Question on grey depronů TGK Foamies (Kits) 6 Mar 01, 2005 02:02 AM
white vs. grey depron Baron Johnson Foamies (Kits) 3 Dec 11, 2003 08:16 PM
