Old Dec 19, 2010, 07:17 AM
Joined Dec 2007
Relative importance of airfoil at 350+
If say a K100 is doing 400mph on a particular day and we could somehow push a button and change the airfoil section to a 'regular' non-DS optimized airfoil - say one of the F3F HN airfoils - how much slower would it go? (every other variable the same as far as possible)
Want to understand the relative importance of an airfoil optimised for DS at these high Re's.. are we talking 5% difference, 1% difference or 20%?
The only F3F model to even approach the speeds of the dedicated DS-designed machines is the Compact Wizard - is that down to the SD2030 section - or the fact that no other F3F model has been built sufficiently strong?
Slippery Slope is offline Find More Posts by Slippery Slope
Old Dec 19, 2010, 11:23 AM
sll914's Avatar
Joined Oct 2003
I think it's considerable if all else is held constant. There are certainly alot of variables but it you compare airfoils in XFOIL at likely operating points, you can see 20-40% reductions in cd. Figuring that cd amounts to roughly half the drag picture along with induced, fuselage, and interference+other drag, that nets in a 10-20% difference overall. The other thing is that the F3F airfoils are typically thinner making it hard to get them strong.
sll914 is offline Find More Posts by sll914
Old Dec 19, 2010, 01:06 PM
Foamaholic
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
The fast compacts were both very strong and heavy compared to any F3F plane I have seen. The compacts are easily double the stiffness of an MCT. The extra mass and strength permits the plane fly to much faster. The only limiting structural factor in a compact appears to be the joiner. The thin airfoil won't ever be able to accept a meaty joiner, but other than that the plane is a great example of how building heavy equates to more speed.
Aerogance is online now Find More Posts by Aerogance
Old Dec 20, 2010, 12:50 AM
Just chillin @ 403 MPH
Jantar2A's Avatar
Boulder Colorado
Joined Nov 2005
Hunh??
There has never been a failure with the wizard compact DSX joiners so I don't understand why you think there is a limiting factor there
Here is a link to a pic of the Joiner system
http://www.rcgroups.com/forums/attac...mentid=2070633
Nick
Jantar2A is offline Find More Posts by Jantar2A
Old Dec 20, 2010, 04:54 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
346mph off angle to the gun turning 2 - 2 1/2 second laps. Don't see a joiner problem there at 50+ Gs.
346mph - Wizard wound up tight (0 min 33 sec)
The K100, TT, Wiz DSX and K130 all flew within an hour of each other on the last
WR morning at Weldon, but the wind speed was highest for the first flight of the K100 and
dropped off as time passed so we never got a totally apples to apples comparison.
My subjective impression though, is that at these speeds the Kinetic is significantly
slipperier than the Wiz, and it carries its energy through bigger laps.
ian
Daemon is offline Find More Posts by Daemon
Old Dec 22, 2010, 12:09 PM
Joined Dec 2007
Thanks for replies guys.
I have recently downloaded XFLR5. The attached shows one of DPs DS sections DP2,06-8,67_DS vs the Compact Wizard's SD2030 section. Both similar thicknesses.
Ran the foils at Re 1.5e06 to 2.0e06 and interestingly the Cd's arent greatly different though Cl much higher on the Wiz.
For contrast, I also ran DP section against MH32 at the same Re - and this time the Cd was about 15-20% lower for DP.
I am a newbie at aerodynamics so some of the default assumptions might not be applicable at these higher Re's - and no idea what the margin of error is for the calculations..
Old Dec 22, 2010, 07:04 PM
launch low, fly high
New Zealand, Hawke's Bay, Havelock North
Joined Dec 2004
Slip,
the mach number is zero in our calcs. put in 0.5 or 0.6 for mach and see if your answers change any.
Joe W is offline Find More Posts by Joe W
Discussion Which foamy for a relative NEWB asat 3D Foamies 10 Oct 21, 2010 01:18 PM
Discussion Airfoil Performance at Very Low Reynolds Numbers Yak 52 Modeling Science 8 Oct 05, 2010 03:47 PM
Discussion Relative Newbie to R/C boating shipshape49 Dock Talk 5 Sep 23, 2010 04:05 PM
