Old Mar 15, 2012, 01:04 AM
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Originally Posted by solentlife View Post
All due respect - I know how and where to connect servos ... been doing it for nigh on 40 yrs. What my question was - where / how to connect the gyro, as on 450 heli - it goes between tail servo (rudder) and Rx., with sense lead to aux ch. But here we have two servos to control elevons ... so how to connect gyro ?
I agree that ideally use without ... I didn't use Expo until this baby - I just learnt to be careful with stick movements. But this baby as I see it needes all the help it can get, like my 450 heli. I propose to use the gyro to launch then switch it of in flight ... which in mind is no worse than you guys using expo !!
which I now use !
My PKJ is grossly overpowered ....... I mean GROSSLY ... and the launch problem is huge. I'm fed up with it and want a 10 out of 10 solution ... I've tried all the tricks mentioned and still having trouble ... and I regard myself as an experienced RC'r.
Sorry bud i misunderstood your question.never meant to question your ability.i use 25% EXPO on mine
chop stiX is offline Find More Posts by chop stiX
Old Mar 15, 2012, 01:05 AM
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
Before and after the canopy went through the prop.
Brian Courtice is online now Find More Posts by Brian Courtice
Site Sponsor
Old Mar 15, 2012, 04:55 AM
Finlande
Joined Dec 2007
Did you try to align the motor with the wing ?
I don't see any other reason why I seem to be the only one who doesn't have any launching problems. I would even dare to say that this is probably my easiest plane for handlaunching .
I am pretty curious to know if anyone who has lowered the motor to the very wing level would still be experiencing launching problems ?
Jpette is offline Find More Posts by Jpette
Old Mar 15, 2012, 05:25 AM
chop stiX's Avatar
Joined May 2011
Well I used the std stickmount and I dont have launch problems.sure i have the torque effect,but not once have I hit the deck on launch,
Old Mar 15, 2012, 06:54 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
The line of thrust I cannot see solves the torque problem ... with my 3700kv motor and 5x5 prop - the torque is huge along with over 500W. When bench testing you can see the prop flex even though it's a stiff correct APC type for the job, you can also see the body flex and I've stiffened it. If you hold the model and open the throttle you can feel the torque.
I have a lighter 3800kv motor on its way and will be reducing down in props as well ... I have a record speed of 222kph with the machine and I'm happy with that until someone beats it. Till that time - I will want to just fly the machine even if it means going down in power / torque to get her going.
The side discus throw is about best bet at moment ....
solentlife is online now Find More Posts by solentlife
Old Mar 15, 2012, 07:11 AM
Finlande
Joined Dec 2007
I agree that this could be the key . Mine is following the stock one and motor is slightly pointing on the side .
I thought that you still had some pitch problems on top of the torque .
Old Mar 15, 2012, 07:52 AM
solentlife's Avatar
Joined Jan 2010
Nope - its a pure death roll that's faster than a witches *** ... and very hard to catch with the sticks.
Some of the launches ... she seems to be fine for a second and then BHAM over she goes and in ... it's as if the launcher has given it enough to fly, but once speed drops and prop takes over - BHAM !
Old Mar 15, 2012, 07:58 AM
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
The statement says it all......anger and pure frustration. LMAO...
Andy
Aero Andy is offline Find More Posts by Aero Andy
Old Mar 15, 2012, 02:02 PM
Joined May 2002
I have had that happen once or twice myself. In my case, I'm sure it was caused by using too much throttle too soon. I found that the trick is to give it just enough throttle to feel the plane start to want to pull out of my hand, and to launch the plane at a fairly steep up angle. It will gain a few feet of altitude before it begins to nose over towards level flight.
It's also not until about that point that I can actually get my thumb on the right stick. (I launch right handed.) At this point I begin to slowly advance the throttle, while watching out for the left wing to drop. If the plane starts to roll over I have enough altitude to get it level, and by then the plane starts moving fast enough to briskly climb out under full control.
Site Sponsor
Old Mar 15, 2012, 08:04 PM
Australia, New South Wales, Sydney
Joined Jan 2011
Maybe program some clicks of right-roll into a toggle switch you can turn off once up and running?
graeme_robinson is offline Find More Posts by graeme_robinson
Old Mar 16, 2012, 02:54 AM
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
maybe yall could try to use a dolly with wheels to take off with. modify a small car with wheels to set your parkjet on, throttle up, let it start rolling, when you have enough speed, just pull back on the stick and leave the dolly on the ground.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Mar 16, 2012, 03:23 AM
solentlife's Avatar
Joined Jan 2010
I don't launch this beast ... all other planes of mine yes ... even the EDF. But this one is a helper launched job and even then she's over and in so bl*** fast it's incredible.
Last launch - she went about 20ft total. ET speed sensor already had 74kph on it.
I wish I had soft ground but as it's only just coming out of winmter, all ground and short grass is still hard frozen. I can't do test glides to find best balance of glide / throttle. Each launch because of the hard ground causes damage.
This baby is really making me feel like a newcomer to RC ! And I've been at it for 40 yrs ...scale, aerobatics, display work etc.
The gyro via V-tail mixer is an attempt to tame this hairy machine. Mixer on order now.
Old Mar 16, 2012, 04:42 AM
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Well after flying my low powered parkjet on last weekend I have now put in a 3500kv 45gram motor and a 4.1x4.1 prop and static tests results around 25 amps.
Looking to give it a shot tomorrow.
aeromaniac is offline Find More Posts by aeromaniac
Old Mar 16, 2012, 08:13 AM
Joined May 2002
Solentlife, have you tried the sidearm launch? You could have your assistant do it for you. I'm finding that the real secret is to launch with minimal throttle, but you still have to anticipate a sudden roll. The gyro might be the ticket for preventing the roll. Let us know how it works out.
Site Sponsor
Old Mar 16, 2012, 10:36 AM
solentlife's Avatar
Joined Jan 2010
It's one I will try ... but the wing even with CF in bends because of the heavy motor I have ...
But all worth a try.
Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF smasher41 Foamy EDFs 1034 Jan 24, 2015 04:52 PM
Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s stuart warne Electric Warbirds 12 Jun 14, 2011 03:47 AM
For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly WRXronald Aircraft - Electric - Airplanes (FS/W) 3 Aug 04, 2010 11:03 PM
New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly CrashingDutchman Foamy EDFs 13 Jul 02, 2010 12:15 AM
Discussion HK's EPO F-16 WRXronald Foamy EDFs 5 Apr 11, 2010 03:47 PM
