Old Oct 30, 2010, 04:14 PM
Vini Vidi Vici!
BadassJohnny's Avatar
Denver
Joined Jun 2008
I need advice on a pusher prop plane
OK, I'm building a trainer type plane, similar to the Hawk Sky
I've never built a pusher like this, so my question is, do I need to add any down or right angle to the motor?
Thanks in advance for any help!
BadassJohnny is offline Find More Posts by BadassJohnny
Old Oct 30, 2010, 04:23 PM
Joined Jul 2006
That all depends, unfortunately. Funny things start happening when you start playing with motor sizes and power levels on pushers. Planes like the MultiPlex Easy Star do very well with stock motors and medium power motors by using the built in down thrust that comes stock. There are tons of posts in the Easy Star forum, however, in which lots of owners had to give it left thrust when using powerful combos.
The best bet is to simply make the motor mount so it is adjustable, relative to thrust lines, and then experiment with it to give you the flight characteristics you are after.
Pushers can sometimes be a real pain in the rear to dial in correctly.
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Oct 30, 2010, 04:49 PM
Vini Vidi Vici!
Denver
Joined Jun 2008
OK, thanks. My best idea was to just epoxy it in and if it wasnt right to just cut it out and re-epoxy at a new angle.
Do you have suggestions for making an adjustable mount?
Old Oct 30, 2010, 04:57 PM
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
What worked well for me, was to assigh two mixers to the throttle channel, that act on the rudder and the elevator. After a little adjusting of the mixing value, my Easy Star now flies straight at any power level.
Julez is offline Find More Posts by Julez
Old Oct 30, 2010, 06:48 PM
Team Hitec
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
Thrust angles remain the same no matter where the prop is positioned on the plane, and as long as everything operates in a counter clockwise operation (looking towards the tail).
This does not mean a pusher will be down and to the right, it should be up and to the left with all the rotational directions the same.
Xpress.. is online now Find More Posts by Xpress..
Old Oct 30, 2010, 06:49 PM
Vini Vidi Vici!
Denver
Joined Jun 2008
OK, thanks, but I really dont know what you mean by assigning mixers to the throttle.
Old Oct 30, 2010, 06:53 PM
Vini Vidi Vici!
Denver
Joined Jun 2008
So if I'm using the same prop and motor as I would for a normal "puller" plane, except rigged up as a pusher setup like with the hawk sky, I need a little up and left angle?
Is that correct?
Discussion Need Advice on a New DLE 55 burke757 Fuel Plane Talk 4 Nov 05, 2010 10:00 AM
Discussion Need advice on my 120SR problem jaysb4 Micro Helis 11 Oct 22, 2010 02:13 PM
Discussion Need advice on my fpv project Goofy68 FPV Talk 4 Oct 16, 2010 07:22 PM
Discussion Need Advice on Electrostik Control Throws dollardad Electric Plane Talk 5 Sep 02, 2010 05:12 AM
Question Need advice on retracts for pusher jet greenseaships Pusher Prop Jet Models 4 Jan 12, 2009 11:29 PM
