Old Sep 15, 2005, 11:45 PM
wac
Joined Jun 2005
At 9000 feet Will it fly ???
I live in Winter Park, Colorad. 9000 feet above sea level, I have a Humming bird 3d pro with a Mini Motor 1215/20 and a 3s 1250 E-tech hp. I would think i have enough power but at full collective and full thottle it will only get about 2 feet above the ground
CAN YOU HELP
I just want to fly
Take Care
William Clary
wac is offline Find More Posts by wac
Old Sep 16, 2005, 12:25 AM
hihptsi's Avatar
Illinois
Joined Apr 2005
are you sure you have enough pitch dialed in? should be about +10
hihptsi is offline Find More Posts by hihptsi
Old Sep 16, 2005, 12:50 AM
wac
Joined Jun 2005
Pitch curve
From what i can tell i have about +12 to -12, so i guessing that its right. Let me know
wac
Old Sep 16, 2005, 12:52 AM
Cautrell05's Avatar
Winside Nebraska
Joined Jan 2004
More head speed?
Cautrell05 is offline Find More Posts by Cautrell05
Old Sep 16, 2005, 01:12 AM
cameron park calif
Joined Jun 2005
i had the same prob with my cp blade. i screwed around with the pitch . it worked great after that! ps try both pos and neg and see if that helps. take care......john
john v is offline Find More Posts by john v
Old Sep 16, 2005, 01:13 AM
wac
Joined Jun 2005
how
and how sould i do that. I can make the throttle curve 0-35%-75%-100%-100%,,, will this work ??
let me know
wac
Old Sep 16, 2005, 06:59 AM
Crewdogg998's Avatar
Battle Creek Mi
Joined Jan 2005
Yes, 75% is a good mid stick hover starting point. Set the tx so you have good head speed and then adjust the pitch curve to get the performance you want. Good luck, Crewdogg
Crewdogg998 is offline Find More Posts by Crewdogg998
EDF that will fly at 5200'--Denver, CO. Lee W Electric Ducted Fan Jet Talk 8 Dec 09, 2005 06:45 PM
flying at 9000 feet asl enrico74ec Scratchbuilt Indoor and Micro Models 12 Apr 02, 2004 10:06 AM
will it fly? Shawn Palmer Electric Plane Talk 2 Dec 17, 2001 02:06 PM
Eagle II, MM or EP, 6:1, 10-2400mah cells, big prop, will it fly???? mrtim Power Systems 0 Sep 07, 2001 08:49 AM
New HERR Speed 280 Planes that will fly in wind. Looooeeee! Electric Plane Talk 5 May 08, 2001 02:51 PM
