Old Feb 08, 2005, 01:01 PM
DS
DS's Avatar
Belgium
Joined Sep 2001
Easystar with ailerons anyone ?
Has anyone tried cutting ailerons in the EasyStar ?
I was wondering if it would be possible to convert it to ailerons ?
Any thoughts anyone ?
DS is offline Find More Posts by DS
Old Feb 08, 2005, 02:51 PM
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
I have done it for my slope club's training plane (together with other mods, specially extended wings). My main advice is cut out the Elapor and put in balsa ailerons. Elapor ailerons are not stiff enough.
If I did it today I would have installed the aileron servos on top of the wing, not under it.
The result when flying is that the EasyStar becomes more responsive with power off, rudder is not needed except if you catch a thermal. However, the wing will still not allow axial rolls and it does not even allow a half roll to inverted. The final result is precisely the same as extending the rudder...
I would wait for the EasyGlider from Multiplex, the profile may make it easier...
jcosta is offline Find More Posts by jcosta
Old Feb 08, 2005, 04:17 PM
DS
DS's Avatar
Belgium
Joined Sep 2001
Thanks for the info jcosta.
The whole point of converting it to ailerons was a trainer for my pupil. He needs to start practising solo landings ... hence a pusher aileron ship. The easyglider has the motor in the nose.
We learned on a aileron-modified Terry and all went well, except for the landings. The nose is really fragile on the Terry.
I guess you used dual servos for the ailerons ? Don't know if a single servo setup could be possible in the Easystar (it was on the Terry).
Old Feb 08, 2005, 04:23 PM
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
The motor in the nose with a folding prop is no more prone to damage than a pusher. And it's impossible to have the EasyStar ailerons with a single servo.
But the EasyStar is not the ideal model for learning how to land, it lands by itself... My 9 year old daughter landed it on her first flight, by simply aligning it with the landing area and leaving the sticks alone...
Old Feb 08, 2005, 06:01 PM
EDF addict
-PaX-'s Avatar
Friedrichshafen, Germany
Joined Jan 2005
Hi
You should find some inspiration on this fine site: http://easystar.detract-online.de/
Just click on modifications and you'll find some examples.
HTH
cu Steffen
-PaX- is online now Find More Posts by -PaX-
Old Feb 08, 2005, 10:25 PM
Cincinnati
Joined Jul 2004
I have modified my EasyStar with ailerons that are 14 inches wide (each) and made from 1 1/2 balsa aileron stock. A Hitec HS-55 servo drives each one. On high rates, I can do axial rolls, but they are fairly slow. With a bit of down elevator through the mid part of the roll, altitude stays fairly constant. The roll rate is still quite slow, considering the size and deflection of the ailerons! They make inverted flight a LOT easier, and control response is fairly constant, rather than being linked strongly to throttle position (due to airflow over the tail surfaces). I also replaced the stock rudder with a piece of the same balsa aileron material, and it helps rudder functionality too. Next step is to consider a motor upgrade....
Mike H.
Cincy, OH
Dynomike is offline Find More Posts by Dynomike
Discussion EasyStar with Ailerons IamLegend Foamies (Kits) 15 Jul 08, 2007 01:17 AM
Slow Stick with Ailerons, anyone? jasoncy2k Parkflyers 14 Sep 21, 2005 01:16 AM
Soarstar/Wingo with ailerons...anyone do it? Danny Troy Foamies (Kits) 11 Aug 06, 2005 11:35 AM
Easystar with ailerons. IloveFLIGHT! Foamies (Kits) 5 Aug 17, 2004 02:05 PM
Slow Stick with ailerons / flaps anyone? Fredrik W Electric Plane Talk 1 Jan 07, 2003 09:23 AM
