Old Feb 29, 2012, 03:51 PM
I make bad look so good.
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Originally Posted by DerekB View Post
Well, it was not so hard. One C clip, then pull the core out. One more beautiful thing about brushless motors. To push the bearings out, I used a small diameter rod from the opposite end and pushed on the inner race.
It's tough to photograph those little bearings!
However, the bearings "feel" fine. But who's to say at 35k rpm.
Like I mentioned, I had the fan balanced pretty well on the bench, then the next run it had a vibration, a bit worse than before I started balancing. I checked everything was tight. So my only suspect is the bearings.
If these motors work out, I have no problem replacing the bearings. This was simple.
However, how do you identify / measure bearings and where to buy good replacements at a reasonable price, considering this is a sub $13 motor?
Derek,
If you have a digital caliper you just measure the width and diameter of those bearings. Since it's a 4mm shaft the I.D. is already known. I'd be interested to know those measuerments if you ever measured them.
SteveC68 is offline Find More Posts by SteveC68
Old Feb 29, 2012, 06:31 PM
Joined Feb 2006
okay here are the numbers for the cs10 blade fan
So i bought a pair of hobbypartz. edf specials. They had motor/fan/ esc with 4 servos for 70mm edf jet for $47 bucks. The motor is 3000kv Detrum brand.
On 4s with the cs10blade fan its about 60amps forgot the watts. ON 5s using gen ace 3800mah 25c pack it put 99amps down and over 1700watts. My speed control is rated at 60amps with im sure 70amp burst, So did not hold the throttle too much just few seconds. It sounds really nice and crazy amount of power. I think on 4s its a safe set up with the motor and esc I have, I really liked the way it sounded and pulled on 5s though but im sure its going to blow up eventually. Anyone have a opinion on rated esc?? THis one says 60amp but I ran it and pulled 99amps, Im sure its not a good idea.
sherlockshah is online now Find More Posts by sherlockshah
Old Feb 29, 2012, 07:16 PM
Joined Nov 2005
It's not, usually the FETs can't shave enough heat at that wattage or the PC board conductors might not be able to go that high even if FETs are fine. Prolly a lot of head room in the specs something more expensive ESC's don't have IMHO.
erh7771 is online now Find More Posts by erh7771
Old Feb 29, 2012, 07:43 PM
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally Posted by SteveC68 View Post
Derek,
Sorry, I didn't think to fully measure the bearings before I put all 4 motors back together. I painted the shafts with clear dope so the bearings seat real nice. But it's a one shot deal on assembly. On first assembly, the inner race shaves off the dope just perfect. If I put them on a few times, they just shave it all off. So now I have all 4 assembled and don't really want to take apart again.
DerekB is offline Find More Posts by DerekB
Old Feb 29, 2012, 07:57 PM
Joined Oct 2011
This is the stock meteor motor. Several folks here have burned them up on 4S when installed in a plane. I would find another alternative motor if you want to run the cs70/10 fan. Just an FYI.
901racer is offline Find More Posts by 901racer
Joined Feb 2006
IM pulling 60amps on 4s with this 3000kv motor
NOt sure how much thrust its making, sounds good though, ON 5s its really lighting things up but as I mention its almost 100amps. I just did a quick burst check to see the watts and amps, I dont think it would hold if i had it punched for a while.
Old Feb 29, 2012, 07:59 PM
Joined Oct 2011
Originally Posted by manuel v View Post
Take 901racer excel and add the weight of the motor parameters and watts per gram of weight.
so that we can see that using some of these motors above 10 watts per gram, would not last long, in fact the efficiency and % NLS of these results should be low.
to give us an idea of ​​the mark which are useful colors.
I hope your opinion to make adjustments.
Manuel V.
Thanks !! I will add the color coding indicator to the spreadsheet.
Old Feb 29, 2012, 08:14 PM
United States, FL, Orange Park
Joined Jul 2010
I tested the CS fan with that motor and esc on a Sky lipo 4s 2650 40c and it toasted the esc when I held for around 10seconds, so be careful. I have since switched to the Hobby Wing 80 amp pentium pro and Het 2w-20 have had no problems. She hasn't made into the sky yet, hopefully this weekend. One more thing, I tried those servos in ailerons and elevator and found they had too much play for elevator use in my Lander F-16! OK in the ailerons just seemed like excessive slop for a flying elevator and I may have gotten a couple low qc servos?
3rd-dem is offline Find More Posts by 3rd-dem
Old Feb 29, 2012, 10:50 PM
therealhiphop's Avatar
USA, UT, Springville
Joined Dec 2005
What kind of numbers are you getting with the 2W-20?
Thanks.
therealhiphop is offline Find More Posts by therealhiphop
Old Feb 29, 2012, 11:19 PM
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Neat add on to the chart guys! Me likes colors. Like the old threat colors.
Ok What does Optime stand for though?
Glacier Girl is offline Find More Posts by Glacier Girl
Old Feb 29, 2012, 11:27 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
optime = runtime before the smoke came out LOL!!!!
jcdfrd is online now Find More Posts by jcdfrd
Old Mar 01, 2012, 12:01 AM
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
The 2W20 is too high a Kv and too small a can to be efficient in this fan on 4 cells. Look for a much longer can motor with more mass and torque.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Mar 01, 2012, 12:18 AM
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
Originally Posted by anlucas View Post
My thoughts are that it's over the top. If you need more poke then go with a 2800kv or 3000kv max. You will still get respectable power without the risks.
It's just too easy to floor the trottle and watch 1 of the 2 motors die mid air. You will be lucky if you are high up to cut throttle and glide down.
if you must then go with Cyclone Power 2500kv on 5S.....
Just to refresh (this thread is active, so I lose track!!) we are talking about the Turnigy SK3 Fandrive 3516-3300kv on 4S. I agree that a lower Kv would be better, but I can only find a 3300. Is there a 2800 of the SK3? That would be a good choice, but I can't find it.
anlucas, your 3300 is dead, correct? But you did run it on 4S and the numbers were great. What do you think about trying 3S ???? Do you think it would be better all around than the L2855-2300 on 4S ?? Considering both sound at all throttle levels and thrust.
So if we scale your 4S results:
Turnigy SK3 Fandrive - 3516-3300kv
4S 3000 40C
13.59Vm
87.5Ap
1215.0Wp
1.75Kg Thrust
by .75 to do a "rough" conversion to 3S, it would be around (rough prediction, I know, but just for discussion).
3S 3000 40C
65.6Ap
911Wp
1.31Kg Thrust
This is still way better than the L2855-2300 on 4S, at least for Amps and Watts, so the thrust should be more. The L2855's have poor balance issues. If the SK3 sounds very smooth like you say, I'm up for a try. But I need to buy 2, so committing $50 plus shipping, I kinda need some reassurance.
Please keep in mind, I am not after MAX performance, just "airliner" performance.
Old Mar 01, 2012, 12:56 AM
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
MY estimation is:
3s, 11 volts, 58A, 636 watts.
For Turnigy SK3 Fandrive - 3516-3300kv
Maybe is a good motor for rewind.
Manuel V.
manuel v is online now Find More Posts by manuel v
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
4S 3000 40C
13.59Vm
87.5Ap
1215.0Wp
1.75Kg Thrust
3S 3000 40C
65.6Ap
911Wp
1.31Kg Thrust
Derek,
The SK3 3300kv is not for a low-maintenance 4S setup. On 3S, there is no question that it will operate the CS10blade without burning up.
Assuming that your 3S batteries can keep 11.1volts under load then you can get 36k rpm.
The L2855-2300kv on 4S at 14.8volts gives 34k rpm. (1.2-1.3Kg of thrust)
The above is in theory though and subject to the kv ratings being correct.
anlucas is online now Find More Posts by anlucas
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7102 Nov 21, 2014 06:33 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 08:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 07:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 02:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 10:36 AM
