Old Mar 16, 2010, 05:37 PM
Joined Mar 2010
Flight time
Hey,
about how long of a flight time would I get with
4x http://www.hobbycity.com/hobbycity/s...00mAh_2S1P_20C
4x http://www.hobbycity.com/hobbycity/s...idproduct=5686
and 4x 18amp ESC's? Props for the quadrocopter will be SF 9x4.7.
Seem like a good system? It needs to carry a beagleboard, arduino, GPS, and an IMU. payload capacity would be great.
rp181 is offline Find More Posts by rp181
Old Mar 16, 2010, 07:28 PM
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hello,
I don't mean to be rude, but most of the info you are asking for in your multiple threads you are starting can be found with some reading and study: Quadrocopter and Tricopter Mega Link Index
The missing info in your request is the AUW, the flying weight which limits that flight time. Also there are no 9" CW and CCW props sold that quads require. With your set and payload requirements and the lipo you are choosing I would guess that you will end up about 1.2kg AUW. At that weight with a 1800mah 20c lipo expect about 5 minutes with a 2 minute landing reserve. You never want to land without a reserve with a heli. A lower Kv motor in the 700-800Kv range would work better with the quad too. I would recommend the APC1047 SF CW and CCW props from www.quadroufo.com and the motors there too. In the Index there is a link to OMM's motor tests. That would be worth your time to review as well.
Hope that helps!
Cheers,
Jim
Originally Posted by rp181 View Post
Hey,
jesolins is offline Find More Posts by jesolins
Old Mar 16, 2010, 08:05 PM
Redfox74
Joined Apr 2009
Hey,
See my project
http://code.google.com/p/lnmultipilot10/
you can evaluate different kind of platform.
Regards
Roberto
redfox74 is offline Find More Posts by redfox74
Old Mar 16, 2010, 09:16 PM
Joined Mar 2010
Thanks.
The fact that the props need to be opposite totally left me.
Can you recommend motors from the website? The information given is very little, and Im not quite sure what will work best.
@red: thanks ,will check it out!
EDIT: found what you meant by OMM's motor review. Do 4x of these: http://www.quadroufo.com/product_inf...d4af25a19d059a look good, with the props you mentioned?
As for frame, I can design/make one my self, laser cut.
Old Mar 17, 2010, 02:09 AM
Redfox74
Joined Apr 2009
Thanks.
To obtain 30 minute of time of flight you need to use a hexa platform with propeller of 10'' and battery around 10000 ma . The payload will be very low around 50 - 100 gr. in the FOX project I tested also radial hexa version.
Regards
Roberto
Old Mar 17, 2010, 08:12 AM
A man with too many toys
United States
Joined Feb 2001
For estimating flight times I use 60 watts per pound. That will give you a ballpark number. If you have very efficient motors then flight times will be longer.
Hear is an example of how to compute the battery size required for 2 lb total weight, a 3s LiPo (11.1v) for a 10 minute flight:
2lb * 60W/lb = 120 watts total
120 / 11.1 volts = 10.8 amps total current draw
10.8 amps * 100 / 10 minutes / 6 = 1800 MAH
Applying the 80% LiPo rule 1800 / 0.8 = 2250 MAH battery for a 10 minute flight
RC Man is online now Find More Posts by RC Man
Old Mar 17, 2010, 08:20 AM
Joined Feb 2007
RP,
Yes, those motors work fine with APC1047 props. You can use the newly formulated EPP1045 props on the www.quadroufo.com site reliably if your AUW is under 1kg. What kind of Laser set are you using and what material are you planning to use?
Cheers,
Jim
Thanks.
Old Mar 17, 2010, 08:38 AM
Joined Mar 2010
Thanks guys.
The frame will probably be nylon or ABS right now, I can't afford carbon fiber in the sixes needed (Ile look around some more to see what I can find).
The laser is a 40W (I think) from Universal Laser systems, that my school bought (said it costs ~$35,000 O.O).
Im going to create a CAD model of the frame today, and post it up for you guys to judge.
RCMan: Thanks!
Help! Silverlit Gyrotor Short flight time Malharri Micro Helis 2 Mar 17, 2010 02:17 AM
Discussion C123 1st flight (not quite ready for prime time) Dennis A Scratchbuilt Indoor and Micro Models 4 Mar 14, 2010 03:58 PM
Discussion C123 1st flight (not quite redy for prime time) Dennis A Scratchbuilt Indoor and Micro Models 0 Mar 14, 2010 01:26 PM
Discussion First Time: AV & AP Same Flight /Time / Bird guyg Aerial Photography 4 Feb 17, 2010 11:57 AM
Discussion OPTIMUM BATTERY FOR EXCEED RC F-35 increased flight time ecfarr Foamy EDFs 2 Sep 08, 2009 01:48 AM
