Old Jul 02, 2013, 07:09 PM
Joined Jun 2009
Snap on/Clip on Spreaders
I am looking to buy or fabricate a set of spreaders that I can clip onto a flat sided aluminum mast. I want to be able to clip it on the mast for sailing, but be able to remove it quickly for transport. Does something like this exist? If not, how about some suggestions as to how to make one. I would think that some type of plastic or thin metal clip device with integral spreader arms or short posts for spreader bar mounting would work. Any input?
Rider/Writer is offline Find More Posts by Rider/Writer
Old Jul 02, 2013, 09:20 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Not sure what class boat we are discussing, but on my 36/600 and my one meter, I use a solid brass rod through the mast, with brass tubes that slip over each side. I do need to loosen my diamond wires slightly to provide the ability to slip the wires out of the slots at end of spreader, and then remove the spreader tubes. The solid rod though the mast only sticks out about 3/4 of an inch on each side and is used primarily to position the tube spreaders. This allows me to put the mast inside a 2 inch PVC tube to prevent breaking.
Dick L. is offline Find More Posts by Dick L.
Old Jul 02, 2013, 09:39 PM
Joined Jan 2007
More for round masts
http://radiosailingshop.com.au/index...products_id=35
waboats is offline Find More Posts by waboats
Reply With Quote  (Disabled)
Old Jul 03, 2013, 12:17 AM
thorsail's Avatar
Chicago , Illinois
Joined Jul 2008
yep,what they said...
I just redid my spreaders on a 58" hull, I put a piece of 4/40 threaded rod thru
the wood mast,slipped the stay tangs over that,put a nut on each side .
the spreaders themselves are 5/32'' alum tube from K&S
why? because I had all that in stock to use.
brass tube over rod or threaded rod is good also.
to keep the stays at the end of the spreader I use a cotter pin, opens up to
go over the stay wire, then into the alum tube. I used a half teardrop of JB
Weld to hold the cotter pin into the tube end.
Allan
thorsail is offline Find More Posts by thorsail
Old Jul 14, 2013, 09:50 AM
Still showing up for breakfast
lilleyen's Avatar
Ontario Canada
Joined Mar 2009
Pictures please
lilleyen is offline Find More Posts by lilleyen
Sold Traxxas 1/10 Erevo brushless - Snap on edition Canada shipping only hs748 Cars - Trucks and Parts (FS/W) 1 Apr 04, 2013 12:54 PM
Sold E-Revo Snap On Brushless Edition RTR with 2 3s lipos TQI jmscard Cars - Cars and Parts (FS/W) 4 Jan 28, 2013 11:57 AM
Sold Snap On Floor Jack - Local Pick Up Kmot Non R/C Items (FS/W) 1 Jan 09, 2013 01:55 PM
Discussion Those Pesky Snap Rings (E-clips) Chatenever Power Systems 12 Nov 29, 2012 04:31 AM
For Sale 3mm E-clips, circlips, snap rings, etc. mmmatthew Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 02, 2012 09:41 AM
