Old May 15, 2013, 11:26 PM
New Zealand, Waikato, Hamilton
Joined Jul 2011
Question
Switch Jacks Issue
I recently installed some switch jacks in my new gliders - bought them from a reputable supplier....
they work - as far as they cut power off when the jack is installled and swith on when removed - the issue i have is that I cant charge through the connection outside the fuse. my charger shows "low voltage" then "conncetion break" and shuts off
If I bypass the jack - the batteries charge fine.
I have other jacks the let me charge through them
Any ideas on what could be the issue - what I should check?
Wynn
gtrbaby is offline Find More Posts by gtrbaby
Old May 15, 2013, 11:54 PM
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
Yes..........use an ohm meter to verify that there is not a short between the center and outer connector of the switch jack..........
shhhhh! is offline Find More Posts by shhhhh!
Old May 16, 2013, 12:05 AM
Joined Jul 2011
I'm an electrics neophyte - how do I do that?
I have an ohm metre I think
Old May 16, 2013, 12:12 AM
Throw it like you hate it
RCPC's Avatar
United States, CA, Castro Valley
Joined Apr 2007
Is your switchjack wired directly to your battery or is there a regulator between the battery and the switchjack?
Paul
RCPC is offline Find More Posts by RCPC
Old May 16, 2013, 12:52 AM
Joined Jul 2011
Paul
Plugs directly to battery. 1s lipo
Old May 16, 2013, 03:21 AM
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
Is your charger set for 2S? That would shut it down.
BP
bbbp is offline Find More Posts by bbbp
Old May 16, 2013, 04:09 AM
Joined Jul 2011
Nope. 1s. Charges sweet if i bypass the jack
Old May 16, 2013, 05:01 AM
Dani123's Avatar
Israel
Joined Jan 2005
Just a suggestion here, What is the voltage measured on the jack when it is plugged in?
Maybe your SJ is designed to disconnect the circuit only...
Dani123 is offline Find More Posts by Dani123
Old May 16, 2013, 09:40 AM
ET
eteet's Avatar
United States, DE, Hockessin
Joined Apr 2006
Get your ohm meter and set if to ohms. Put the positive probe on the tip of the charging jack and the negative on the upper part of the jack. The reading should be zero. If the needle/display moves AT ALL you have a short and need to fix it. The short will slowly drain your lipo, which kills it.
Ask me how I know.
Eric
eteet is offline Find More Posts by eteet
Old May 16, 2013, 11:54 AM
Combat: You're doing it wrong.
chewbaccah's Avatar
United States, UT, Layton
Joined Sep 2009
Ask me how I know.
Eric
I am so glad you said that. I have been having that problem for a while. I can charge and fly, but the battery slowly drains. Time to check it over carefully...
chewbaccah is offline Find More Posts by chewbaccah
Old May 16, 2013, 03:03 PM
Joined Jul 2011
Ask me how I know.
Eric
oh - my meter is digital - and has about 5 settings on the ohm side - do I set it to the lowest ?
I'm a bit lost on it really - I will try and figure it out
Old May 16, 2013, 03:18 PM
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
Shouldn't matter, but the higher numbers will settle down quicker. On an Ohms setting, touch the probes together & it should read Zero, that is how the meter sees a short. Not touching it should be at 1.0
BP
Old May 16, 2013, 03:23 PM
Joined Jul 2011
sweet - so if it reading something - theres an issue - gotcha.
Old May 16, 2013, 03:37 PM
jbarnhardt's Avatar
United States, WA, Seattle
Joined May 2011
BP
Probes touching should indeed read zero, but probes not touching probably won't read 1.0 - depending on what range the meter is set to, that would indicate 1 Ohm, or 1 kiloOhm, etc. resistance which is not what you'll have with the probes not touching (you should have infinite resistance). It should read something like "OF" or "out of range" or similar depending on your meter with the probes not touching each other.
-John
jbarnhardt is offline Find More Posts by jbarnhardt
Latest blog entry: Latest creation...
Old May 16, 2013, 03:43 PM
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
I just have one of those freebie Harbor Freight $4 meters!
BP
Wanted PLD switch jack isobar Aircraft - Sailplanes (FS/W) 0 Mar 09, 2013 02:35 PM
For Sale MPI Heavy Duty Integrated Switch Charge Switch with Charge Jack "JR/Hitec" mcoccia Aircraft - General - Miscellaneous (FS/W) 1 Sep 20, 2012 08:53 PM
Discussion Jack plug charge jack/switch MCarlton DIY Electronics 4 Jul 08, 2009 01:01 PM
Switch-Jack: WAY COOL on/off switch! CactusJackSlade Foamies (Kits) 4 Oct 11, 2002 12:27 PM
Switch-jack: WAY COOL on/off charge switch! CactusJackSlade Hand Launch 0 Oct 11, 2002 04:13 AM
