Old Jan 23, 2013, 01:50 PM
Letchworth, Great Britain (UK)
Joined Jul 2004
Question
Can someone help me with Benedini sound system, please?
I've just bought a Benedini sound system -- TBS Mini sound board, 2x40W amplifier, and 2x 4" speaker. The system is pre-loaded with a Fokker D7 engine sound, as requested.
My problem is I can't get it to run, and I'm confused by some of the instructions. When I try to teach the sound unit my throttle stick positions, as per the instruction leaflet, it seems to go through the correct process, except the green light reverts to fast flashing after I've done the full-throttle position and got the three beeps.
What I've done is connect it up exactly as shown in the leaflet that came with it -- sound board LS plug to amplifier, sound board PROP1 plug to receiver throttle channel, sound board second PROP1 plug to ESC, and amplifier powered by its own 3S A123 pack.
I want to have engine noise activated by throttle stick, and machine gun activated by a switch. The leaflet says my sound board is in "direct soundselection (Prop2)" mode. Does that mean, in fact, that my throttle connection should be in PROP2 to make it work? (The other options in the leaflet, unchecked in my case, are "encoder (Prop3)" and "indirect soundselection (Prop3)"; no mention of Prop1, where the leaflet shows the receiver throttle connection.)
I've emailed the vendor, but no reply yet, even though he was very quick to reply when I was ordering
So, can anyone give me a step-by-step guide how they've got their system working, please?
abenn is offline Find More Posts by abenn
Old Jan 25, 2013, 08:08 AM
Joined Jul 2004
To be fair to Thomas Benedini, he's responded to my email today. Seems like I have to connect a 3-position switched channel from my receiver to PROP2, as well as the throttle channel to PROP1. I'll be trying it out tomorrow when I can get into the workshop.
Old Jan 25, 2013, 08:21 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I found a fairly big thread on the Benedini if it helps with any other problems -
Any advice on installing Benedini TBS Mini in 1.4m warbirds would be great
eflightray is offline Find More Posts by eflightray
Old Jan 25, 2013, 11:32 AM
Joined Jul 2004
Thanks, eflightray. I don't know why I didn't find that when I searched on "benedini". Having read it, all the posts relate to systems that are already working -- most of the discussion is about speakers and their installation.
Anyway, the thread is reasonably current, so I'll post a question on it if I have no luck tomorrow.
Old Jan 26, 2013, 01:51 PM
Joined Jul 2004
The system is working -- magnificent Fokker sound
The solution was simple. I had to connect a receiver switched channel to the sound unit, in addition to the throttle channel, to activate the sound ... even though the manual says the second connection is "optional".
Old Feb 03, 2013, 06:49 AM
Bond, Hotglue Bond
Tartago's Avatar
Joined Apr 2006
I lost all sound when trying to modify the volume on the "parameters" tab of the provided software. I'm really puzzled.
I just get 4 beeps and the led keeps flashing fast
Tartago is offline Find More Posts by Tartago
Old Feb 03, 2013, 01:20 PM
Joined Jul 2004
Sorry, I can't help you. I don't have the PC interface cable so I'm just using the sound that was programmed in when I ordered it.
Maybe you should check out the long thread that eflightray referenced in post #3
Old Feb 05, 2013, 07:44 AM
Bond, Hotglue Bond
Tartago's Avatar
Joined Apr 2006
Don't worry. Thomas sent me a new set of parameters to upload. Hopefully it will solve it.
Discussion Does someone here makes (or can point someone who can) custom Composite Airframes? Reginak UAV - Unmanned Aerial Vehicles 7 Jan 21, 2013 06:29 AM
Discussion Does someone here makes or can point someone who can, custom Composite Airframes? Reginak Composites Fabrication 4 Jan 15, 2013 06:00 AM
Help! My push rods arent working in my champ can someone help me. joeIII Electric Plane Talk 5 Jan 04, 2013 07:12 PM
Discussion I need help with the Icharger 3010b, can someone call me or can I call them sherlockshah Batteries and Chargers 1 Oct 19, 2010 09:44 PM
