Old Nov 12, 2012, 12:38 PM
What just flew off the plane?
United States, OK, Broken Arrow
Joined Aug 2012
Evolution .46 motor problems
Ok, just finished my first kit build about a month ago. The plane is a sig four star 40. It flies like a dream but I am having problems with the motor. (Evo .46). I can only get full rpm at about 1/2 throttle. And the carburetor isn't even fully open. When I get to 3/4 it starts blubbering. Anywhere above that it dies. I can fly it this way, just not sure I'm getting full performance. What could be wrong? I have the alpha 40 and the same motor runs very nice.
CJ Jet20 is offline Find More Posts by CJ Jet20
Old Nov 12, 2012, 01:25 PM
YAY the tourists are GONE
United States, MA, Sandwich
Joined Feb 2010
have you ever tuned an engine before?
check list. below 1/2 throttle you low speed needle controls mixture, make sure you tank height is set correctly, and check the fuel lines for tears.
the engine forum would be better place to post this as there is a sticky on how to tune a engine you should read that will give you a good place to start.
Kit_Builder is offline Find More Posts by Kit_Builder
Old Nov 12, 2012, 01:47 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Sounds like it is running too rich and/or the low speed needle adjustment is too rich.
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: Fly Models Sbach 30cc
Old Nov 12, 2012, 02:30 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
If you are very new to glow engines, find a local club and see if somebody will help you tune the engine. I'll bet a dozen donuts somebody will.
If you get help there, join the club and receive more help than you can imagine.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Nov 12, 2012, 02:46 PM
Joined Aug 2012
Yes I tuned my alpha's motor. But I had a guy at the field tune this one for me. Also when I am in the air, it will start pulsing then rpm will drop. Too rich?
Old Nov 12, 2012, 06:03 PM
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
That to me sounds lean in the air
scrub monkey is offline Find More Posts by scrub monkey
Old Nov 12, 2012, 06:37 PM
exf3bguy's Avatar
Joined Oct 2011
What fuel, plug and prop are you running?
exf3bguy is offline Find More Posts by exf3bguy
Old Nov 12, 2012, 10:14 PM
Joined Aug 2012
Cool power 15% nitro, evolution super plug, and 10x6 prop.
Old Nov 12, 2012, 10:24 PM
Joined Sep 2012
Swap out the plug. I generally have a basic distrust of plugs that come with motors. 8 bucks for a plug on top of what you paid for the motor is usually more than worth it.
Old Nov 12, 2012, 10:31 PM
Joined Aug 2012
Btw, This may not even be an issue, but when I spin the prop, it seems like its rubbing against something. With my alpha, I can turn the prop and it feels smooth. I can not only feel but hear it too.
Old Nov 13, 2012, 09:11 AM
United States, SD
Joined Aug 2010
Do you have that "flywheel" off. When I decited to put a two blade prop on I didn't take the flywheel off, the dubro spinner was different then the evo one and the spinner was rubbing on the engine housing. To make a long story short, I had a problem like yours and I took off the flywheel and it works now. Just make sure nothing is rubbing on the engine housing.
Kyler1 is offline Find More Posts by Kyler1
Old Nov 13, 2012, 10:38 AM
Joined Aug 2012
No the flywheel is still on. I tried taking it off, but no matter how much I tightened the prop, it wouldn't stay on. It only stays on with the flywheel. I have taken the prop off and flywheel and have turned the shaft with my hand and still get the same rubbing sound and feel.
Old Nov 13, 2012, 06:54 PM
Joined Aug 2012
Thanks for the replies. Is there a way I could move this thread to the engine forum?
Old Nov 13, 2012, 07:49 PM
United States, SD
Joined Aug 2010
I think you just have to repost it, just ignore the people that give you grief.
Old Dec 07, 2012, 08:57 AM
Joined Jun 2012
WOOOOOOOOOOOOOW,It's very useful
bluecat1997 is offline Find More Posts by bluecat1997
Sold Evolution .46 Alpha trainer engine, $40 wing881 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 07, 2012 05:09 PM
For Sale *Price Reduced* Evolution .46 TPS sscherin Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 23, 2012 02:22 AM
Help! Evolution .46 engine problems trobinson3003 Fuel Plane Talk 9 Feb 25, 2010 04:36 PM
Discussion .46 Evolution Problems. Hobbyzoneflyer Fuel Plane Talk 10 Oct 28, 2009 12:12 PM
Evolution 46 problems DaWizard Engines 6 Nov 01, 2004 09:02 AM
