Old Aug 08, 2012, 03:54 AM
Australia, NSW, Harrington Park
Joined Apr 2008
Australian source of spay paint for the Fun Cub
I am keen to avoid the all white finish of the Fun Cub.
Can anyone suggest a source of spray paint in AUSTRALIA.
My local hobby shops only stock TAMIYA spray paint which I believe is not compatible with Elapor.
Posts on this thread have suggested Dupli-Color Plasticoat.
Also suggested is Krylon Fusion with a coat of Future Acrylic for a shine.
Is that Krylon Fusion FOR PLASTIC?
Any information gratefully received,
Tony
aerotony is offline Find More Posts by aerotony
Old Aug 08, 2012, 05:47 AM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by wayfaringdreamer View Post
My funcub got the dreaded shakes which split the fuse in half. I fixed with glass but proceeded to crash it.
I really didn't like the motor mount so I took this as an opportunity to rebuild it with balsa/ply. I also decided to move the rudder/elevator servos back because I really didn't like the thin wire and tube design.
Here are some pics.
Impressive. Consider adding some air flow to the motor.
Prof100 is offline Find More Posts by Prof100
Old Aug 08, 2012, 07:17 AM
Thermal Seeker
electrich's Avatar
United States, GA, Atlanta
Joined Feb 2011
Tony
I use Krylon h2o latex in a spray can. Lots of light coats yield great results. Not available everywhere.
electrich is offline Find More Posts by electrich
Old Aug 08, 2012, 07:31 AM
Joined Apr 2008
Elapor Compatible Spray Paints in Australia
Originally Posted by concord12 View Post
Does anyone in Australia stock this paint?
I notice that world Hobbies in Australia stock the Elapor Primer but no spray paints are listed.
Changing the subject slightly I also note that they seem to stock two sizes of |EPP wheels for the Fun Cub, 45mm and 120 mm.
Has anyone any experience of using the smaller wheels?
Tony
Old Aug 08, 2012, 07:34 AM
Joined Apr 2008
electrch,
Thanks for the information.
I am still searching for a Krylon paint stockist in Australia,
Tony
Old Aug 08, 2012, 08:12 AM
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
There is a gap below the motor for air to get in to the esc. I don't want to perforate the motor mount so I've been thinking about putting in a hood scoop since the motor is so close to the top of the fuse.
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Aug 08, 2012, 08:16 AM
Prof100's Avatar
Joined Jul 2007
Good, I didn't see that in the picture. Well done.
How did you achieve the down and side thrust?
Old Aug 08, 2012, 09:03 AM
Joined Sep 2011
Because they were so well stuck I didn't want to dig out the plastic mounts that glue into the sides of the fuse so I kept them. I also was a bit worried about keeping the thrust angle.
Many in my club that fly the FC don't bother with the down thrust screws so I left that out and just screwed the ply motor mount to the plastic mount and also glued it to the balsa lining the fuse.
I've had 6 flights so far and it tracks beautifully!
I'm running:
Hacker A30-16M V2
Hacker X40 esc
Thunder Power 2100 3s ( I am getting about 9 minute flight time)
APC 12x10
At WOT I measured about 360 watts at 37 amps.
In the air it has great power and cruises at less then 1/2 throttle.
Old Aug 08, 2012, 12:26 PM
Fastflydan
Joined Jul 2012
Very good airplane lot of funnn!!!!!
Funcub cam on board!!!
http://www.matterhorns.org/pages/vid...sion-2012.html
www.matterhorns.ch/
Killadan is offline Find More Posts by Killadan
Old Aug 08, 2012, 06:57 PM
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Tony
I use krylon "short cuts" on my MPX planes.... several light coats and never a problem.
(not a funcub, but you get the idea. I had an instance of not being able to tell if a plane was upside down or rightside up, I mentaly flipped a coin and guessed right side up, but it was upside down and didnt end well, so the entire bottom of this one is orange,..)
dacaur is offline Find More Posts by dacaur
Old Aug 09, 2012, 01:18 AM
Joined Apr 2008
dacaur,
I am still looking for a krylon distributor in Australia,
Tony
Old Aug 09, 2012, 04:52 AM
Agricultural flyer
mixer421's Avatar
United Kingdom, England, Kent
Joined Aug 2007
electrch,
Tony
I've used Plasti-kote fast dry enamel on my Fun Cub. It gives a good hard wearing gloss finish with only 2 coats. If you have any doubts try a test on the inside of the hatch cover. Apply the first from between 10 and 12". Others have reported satisfactory results with normal 'rattle can' car paints. Elapor foam is far less susceptible to attack than other foams.
mixer421 is offline Find More Posts by mixer421
Old Aug 09, 2012, 07:28 AM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
Ron
Keep me posted on how it works in funcub; I was pondering doing the same for Airial video
Originally Posted by A Rdnek View Post
Mee too. I have one of these OrangeRX 3-Axis Flight Stabilizers coming.
http://www.hobbyking.com/hobbyking/s...dProduct=25448
I hope it will allow me to slow a bit more.
Rn
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Aug 09, 2012, 09:45 AM
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
I had a little too much fun with the Fun Cub the other day.
Doing some tight loops, seems like the spar let go and then the wing snapped in two.
Pretty loud c-r-a-c-k as it broke in two and the Fun Cub fell to earth like a shot duck.
For the fall that it took, the damage was not bad. Other than the broken wing the nose compressed some and bent a motor shaft.
I think I can fix the wing, but I'm unsure of the boiling water process for expanding the compressed foam. Do I boil the water, turn off the heat and immerse the foam for a little while to heat up? Does it expand on it's own or do I need to stretch it?
To be honest, I've had a fun run with the FC, but am thinking maybe time to move on.
Is there any value to the nose damaged fuse with a broken wing, 6 tower-pro MG servos, Trexxler tires and Sullivan tail wheel?
Maybe someone nearby might be interested in giving it a new home? (Around St. Louis area)
Thanks!
Woody_99 is offline Find More Posts by Woody_99
Old Aug 09, 2012, 09:51 AM
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
I painted mine with plain old Rustoleum. Several light coats, don't get to close when spraying. Holds up great and is available everywhere.
greedyg76 is offline Find More Posts by greedyg76
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
