Old Yesterday, 02:41 PM
altitude adjustment
thumbhead's Avatar
USA, CA, Irvine
Joined Mar 2005
Pull/Spring on 2.5m
I've had a pull/spring setup for rudder and elevator control on a few DLGs and was wondering if anyone has used this setup on something larger.
I have a Pulsar Pro 2.5 RES that I plan on building without a motor and was thinking pull/spring would save a good amount of weight. I was thinking of using a pair of HS65 MGs and should be able to use a pretty beefy spring compared to what is usually used in DLGs.
Mark
thumbhead is offline Find More Posts by thumbhead
Old Yesterday, 02:59 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Yes.
Bob McGowan used to do that on his lightest Supras, with a built up custom rudder before the non molded ones were out.
Another thought is spring/pushrod assist.
A spring in the surface, but then use a very light CF rod in place of the string. Sort of a bit of insurance and able to push if needed. A .040 cf rod with bondable teflon tube doesn't weigh much.
R,
Target
target is offline Find More Posts by target
Old Yesterday, 03:27 PM
Mark:
I built a 2-meter Pures ("Pure RES") and used pull/spring for the V-tail. Between removing push rods, and having to remove ballast to maintain CG, I saved almost an exact ounce. I had originally installed the manufacturer's push rods in plastic tubes. I simply used the existing tubes as string guides, but still saved an ounce. A second Pures got pull/springs right off the bat, also using the plastic tubes.
I also use pull/spring as you do, on DLGs. I will be using it on more larger airplanes.
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Yesterday, 03:36 PM
altitude adjustment
thumbhead's Avatar
USA, CA, Irvine
Joined Mar 2005
Exactly the responses I was hoping for. Thanks guys.
Mark
Old Yesterday, 03:37 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Its been my experience that the tubes also weigh quite a bit, depending on what ones they are...
That is why I am a fan of the bondable teflon. Its very light.
R,
Target
Old Yesterday, 03:41 PM
altitude adjustment
thumbhead's Avatar
USA, CA, Irvine
Joined Mar 2005
I plan on using glass beads at the exit holes with no tubes.
Mark
Old Yesterday, 03:55 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Obviously that will be very light.
The only issue, if it is one, is getting the pull string threaded down the fuselage, and making sure they aren't rubbing or somehow twisted....
That's where having the tubing is an advantage, even if only the ends are secured. Makes a handy guide.
Once it's installed though, I think you are home free.
I'm looking at Beadalon wire for dlg's and other pull string installs. They have differing sizes.
R
Target
Old Yesterday, 06:43 PM
United States, NY, Buffalo
Joined May 2013
Mark
Hey, did you get that idea from me?
My Art Hobby Sky-V 2-meter has a V-tail with string/spring. In my build thread I show the installation with the glass beads and small pieces of teflon tubing at the fuse exit near the tail.
I had no problems at all with the performance. The plane has good control even at high speeds.
DrewV is offline Find More Posts by DrewV
Old Yesterday, 06:50 PM
altitude adjustment
thumbhead's Avatar
USA, CA, Irvine
Joined Mar 2005
I did Drew. Glad to hear it works well.
Mark
Discussion Pull Spring vs Pull Pull vs Push Rod for rudder elevator hog2soar Hand Launch 113 Mar 05, 2013 07:07 AM
Discussion pull/spring spring size? txg8gxp Hand Launch 13 Sep 01, 2012 09:29 PM
Discussion pull/pull or pull/spring help txg8gxp Hand Launch 22 Aug 29, 2012 11:03 PM
Discussion Pull-Pull / Spring-Pull / .8mm CF Pushrods in stretched, etched teflon tubing Dale Thompson Hand Launch 12 Oct 03, 2010 08:53 PM
Discussion alternative to pull-pull ///spring inserts soarluck Hand Launch 22 Jul 06, 2009 11:05 AM
