Old Feb 19, 2012, 10:03 PM
Joined Jan 2012
need help with primary gain and autolevel Mode gain
Hi, I read through the hoverfly pro manual. Have Hoverfly pro, Spectrum 8 radio, In the illustration, figure 13, it shows -25 and +25 for the two gains. However, in the description below it says, "when the channel 5 gain switch in the the negative mode then auto leveling is diabled and a Primary Gain of 25 is used by the Hovercore Algorithm. When the primary swith is in the positive position the Auto-Level Mode is enabled and a Primary gain of 25 is used." The illistration shows - 25. The description does not say whether it is positive or negative.
Thanks Roman
rkenosha is offline Find More Posts by rkenosha
Old Feb 20, 2012, 05:59 AM
A man with too many toys
United States
Joined Feb 2001
25 is just a starting point. After tuning most of us have a much higher gain. A gain of 80-100 is not unusual. The setup client tells you want mode you are in and the actual board gain. Don’t rely on transmitter numbers always set the gain using the setup client. If the AL box is checked than you are setting AL gain. If it’s not checked than you are setting the main board gain.
RC Man is online now Find More Posts by RC Man
Old Feb 20, 2012, 07:32 AM
Joined Jan 2012
That Part I understand. I am just trying to get the + and - figures correct of setting intial gain. Thanks Roman
Old Feb 20, 2012, 03:42 PM
I'll fly anything...
Efliernz's Avatar
Hamilton, New Zealand
Joined Jan 2007
To follow on from "RC Man"... I'm sorry if I start sounding repetitive
The + and - are just indications on your radio of the end points in relation to 0% - the middle. Some radios have 0% at low stick, 50% at middle and 100% at high stick. For them, I would start with 25% one way and 75% the other...
Try not to analyze your settings on the TX too much. It isn't important - what is important is how the board (and client software) see the gain channel.
The switching from normal gain to AL gain is done by switching from "+" one way to "-" the other way. On the client software - just check the AL box is ticked when you have the switch set in the direction you want for AL. If it is reversed to what you would like, reverse the channel on your TX.
The client software also shows you the "gain" as a number. I start with "30" on the screen and go from there. When you switch to AL, the client will show your new AL gain as a normal number (like 30) without any "-" symbol. You know it is AL as the AL box is ticked.
Pete
Efliernz is online now Find More Posts by Efliernz
Old Feb 20, 2012, 04:41 PM
Joined Jan 2012
Thanks. That was helpful reply. I was stuck a little on the + and - side of things.
Roman
Old Feb 20, 2012, 04:57 PM
Efliernz's Avatar
Joined Jan 2007
No worries. We have all been there...
As for "how much gain". It really is a "personal preference" type of thing! I decrease my gain on my hex when flying in wind (15mph+) as I find the board is over-controlling a little. The basic HFP boards fly really well.
Stacky and I did a video shoot last month that required carrying a couple small cameras on small quads - but because the brief included some intentional carnage, we used CC boards (when we really wanted to use HF boards). I have only flown HF for the last 5 weeks - daily - but I gave one of the CC quads a fly last Friday. Even in perfect weather... it sucked really badly compared to the HF board! The HF boards quite simply fly really well. It is a bonus that you don't need a computing degree to set them up or to adjust gains!
Good luck.
Pete
Help! multiwii-audrino-gps-autolevel help!! kremecheze Multirotor Talk 7 Nov 03, 2011 10:42 AM
Help! Help with my TX settings vs Main Gain df60532 Hoverfly Technologies 1 Oct 03, 2011 02:48 PM
Help! DX8 duel elevator mode. I need help with it please! TMAC4123 Radios 3 May 02, 2011 12:49 PM
Question I need help with X9503!! ( I am in panic mode ) nicoyenny Radios 12 Aug 28, 2010 08:35 PM
Question Need help in governor mode with my Hacker jeti master B 40 H esc. HAL1 Electric Heli Talk 0 Mar 29, 2007 05:49 PM
