Old Jun 28, 2007, 06:18 AM
Baton Rouge, Louisiana
Joined Apr 2007
Help!
thunder power LiPo balancer tp210V
I just received my new TP 210V balancer. When I ordere it I thought thayt I could just plug in my 6S2P main and my 7.4V servo battery. Not the case though. What connector, adapters etc needed to use it??
Are these adapter cords already out there or do I make them up. Could someone give me a description and maybe part numbers , and a supplier ?
S Trex
Southern T Rex is offline Find More Posts by Southern T Rex
Old Jun 28, 2007, 06:33 AM
A man with too many toys
United States
Joined Feb 2001
SO, you must hot have TP batteries. You need to know the type of connector on your battery. You may have to contact the battery manufacture.
Hear are some links that may help:
http://www.espritmodel.com/index.asp...TS&Category=58
http://www.rctoys.com/rc-products-ca...RS-WIRING.html
http://www.rctoys.com/rc-products-ca...ERS-POWER.html
RC Man is online now Find More Posts by RC Man
Old Jun 28, 2007, 07:54 AM
Joined Apr 2007
Balancer Issues TP210 to Falcon balancer leads
No, not running TP. I have Falcon (Predator) batterys. I will contact them
S Trex
Old Jun 28, 2007, 12:34 PM
volts x amps = watts.
Wheelhaus's Avatar
Denver
Joined Sep 2006
See if anyone makes adapters for those packs, or get a set of appropriate plugs and wire your own adapters.
If you do make your own, be sure to find the proper cell pattern or you'll fry the balancer and potentially the pack too. TP's pattern is easy to find, each cell is in order. Use a voltmeter and check each pin from the first, if the voltages go up on each pin by the same voltage, you've found the right order.
TP balancers use the cell 1 negative first, then each subsequent positive after that. They offer 6 pin and 4 pin taps. 6 pins handle up to 5 cells, 4 pins handle up to 3 cells. TP will use a combination of 4pin/6pin or 6pin/6pin to use more than 5 cells.
If you're using 6 cells:
wire the first 3 cells into a TP 4 pin plug...
Wire pin#
c1- 1
c1+ 2
c2+ 3
c3+ 4
wire the second 3 cells into a 6 pin plug...
Wire pin#
c4- 1
c4+ 2
c5+ 3
c6+ 4
na 5 (remove)
na 6 (remove)
Plug both sets of pins into the bank1 side of the balancer. Plug the grounded cell in last, so plug in Group B, then Group A. Once group A is plugged in, it will initialize and start balancing. You can balance/charge at the same time with the TP210.
(my 10s pack uses the same idea, but two 6 pins for the forst and second sets of 5 cells).
Wheelhaus is offline Find More Posts by Wheelhaus
Old Jun 28, 2007, 08:13 PM
Joined Apr 2007
Wheelhaus
Wheelhaus,
How long have you been doing this Helicopter thing ? I am very impressed with your complete knowledge !! Can I have a phone number where I can reach you
I am a newbie at this, I have so many questions. thanks for the advice so far!!
Southern T rex
Don Olano 225 776 2818
Old Jun 28, 2007, 09:33 PM
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
If you are just getting into this heli thing, the EHBG will help you alot.
Hands on is the best so posting your location helps alot to.
FB
Fred Bronk is offline Find More Posts by Fred Bronk
Discussion Help needed with Thunder Power lipo balancer rossdogarr Mini Helis 7 Jul 22, 2007 02:21 PM
Discussion Do I NEED a balancer for my thunder power lipo? caseym Batteries and Chargers 10 Feb 19, 2007 12:09 AM
For Sale Thunder Power LiPo charger and balancer Tay611-8 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 28, 2006 08:40 PM
Discussion thunder power lipo and apache balancer help!!!! Lee_newbie Batteries and Chargers 5 Jul 15, 2006 01:23 AM
Discussion How to run a Thunder Power Lipo Balancer? skip63 Micro Helis 11 Feb 03, 2006 10:19 AM
