Old Jul 12, 2012, 12:45 PM
Tim K's Avatar
Woodland Park, CO
Joined Jul 2000
Re-mapping AR6400L Rudder to Aileron?
I have an AR6400L (Elevator, Rudder, Throttle) brick I'd like to use in a R/E/T application. The manual doesn't seem to indicate that there is any way of mapping the rudder over to ailerons so it will be on the right hand stick. Anyone know of a work around?
Tim K is offline Find More Posts by Tim K
Old Jul 12, 2012, 03:39 PM
Minneapolis, Minnesota
Joined Jul 2007
Do you have a DX6i or greater transmitter? If so, the mixing can be accomplished at the TX.
Jay
Faethor is offline Find More Posts by Faethor
Old Jul 12, 2012, 03:49 PM
Tim K's Avatar
Woodland Park, CO
Joined Jul 2000
I just read a good solution. I can mix rudder to ailerons 100%. Brilliant. DX7, BTW.
Old Jul 12, 2012, 04:16 PM
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Then you can mix Rudder to Rudder -100% x -100% to cancel any rudder movement with the left stick.
TODD
I R Irv is online now Find More Posts by I R Irv
Old Jul 12, 2012, 05:35 PM
Tim K's Avatar
Woodland Park, CO
Joined Jul 2000
More brilliance!
TODD
Old Jul 12, 2012, 06:07 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
I left the rudder alone and now it works on both sticks.
Glenn
glewis is online now Find More Posts by glewis
Discussion YardBird Modifications: Ailerons/Rudders/KF2 Airfoil knight2hug Foamies (Kits) 19 Aug 11, 2014 12:33 PM
Discussion Rudder Vs. Aileron SMackaay Beginner Training Area (Aircraft-Electric) 156 Aug 10, 2012 10:55 PM
Discussion Aileron rudder mix experiment Steve Bailey Multi Task F3X 11 Jun 24, 2012 08:19 PM
Discussion Coupling rudder and ailerons? Yellow Baron Scratchbuilt Indoor and Micro Models 6 Jun 19, 2012 07:36 PM
Sold SukhoiXP brick and aileron servo - AR6400L + aileron servo. Stall'n_N_Haulin Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jan 24, 2011 04:21 PM
