Old Nov 29, 2013, 03:37 PM
Joined May 2013
Vehicle Lost Control !
Hey guys have a problem,
Basically like 5 months ago I was in the park using my 1/5 scale buggy and suddenly the buggy just shot out of my hand at full speed luckily i reacted quickly and applied the brake on the transmitter which stopped it. Now I want to know why this happened so basically whenever I switch on my transmitter the vehicles throttle doesn't stay in neutral position put goes into acceleration and the vehicle only reacts when I apply the brakes but when i apply the acceleration it won't go. Also the steering is really glitchy sometimes the front wheels turn and sometimes they not.
So im wondering whats the issue I have on my hands
younge is offline Find More Posts by younge
Old Nov 30, 2013, 07:17 PM
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
may be the tx or rx giving up i would suggest to not run it unless on a stand and make sure you find the issues .
cost effictive works well .. http://www.nitrorcx.com/79p-gt3b-carradio-lcd.html
rcphreak is offline Find More Posts by rcphreak
Old Dec 01, 2013, 09:47 AM
Joined Apr 2008
Yuu have bad servos or a complete bad radio system. Buy a new radio system with large scale servos. RTR really means ready to replace.
txt killer is offline Find More Posts by txt killer
Old Dec 04, 2013, 02:54 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Does it glitch all the time, or only when the engine is running?
wparsons is offline Find More Posts by wparsons
Old Dec 23, 2013, 12:13 PM
Fledgling Modeller
Arkitekt's Avatar
Kelowna, B.C., Canada
Joined May 2010
What radio are you using? Might need to re-calibrate neutral position.
Arkitekt is offline Find More Posts by Arkitekt
Old Jan 01, 2014, 12:55 AM
GLMS
mav913's Avatar
Michigan
Joined Jan 2007
First I'd rebind radio if a 2.4 system, see if that helps the intermittent signal issue. If that helps then check if somehow the throttle channel got reversed. I have seen it happen before.
mav913 is offline Find More Posts by mav913
Old Jan 01, 2014, 10:28 PM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
seems the op has either found his problem or is un able to reply to help us help him ..
Old Jan 05, 2014, 10:59 PM
Joined May 2013
Its really strange sometimes the fronts wheels turn left and right when i use the transmitter but they move really glitchy. Also the throttle goes to max whenever i turn on the transmitter and that causes the buggy to fly off road. Dont know what this is as im a total noob when it comes to RC.
Old Jan 06, 2014, 09:29 AM
Joined Apr 2008
Check the spark plug. Make sure you're using a resistor type? If that checks out trash the radio system and get a new one. RTR really means ready to replace.
Old Jan 06, 2014, 06:42 PM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
your first step is to read and give us answers to the questions asked . remember we are blind we cant see or hear it so you must give us as much information as possable otherwise we are all just stabbing into the wind ..
Old Jan 11, 2014, 05:14 AM
Radian, Polaris, Mistaken ID.
Baseman's Avatar
Japan (Military)
Joined Nov 2010
Let's go back to simple..... Is the throttle channel reversed?
Baseman is offline Find More Posts by Baseman
News SPEKTRUM AVC (Active Vehicle Control) Technology Paul Onorato Car Talk 6 May 07, 2014 02:17 PM
Help! Lost control, almost lost a plane - Help!! sgomes Power Systems 3 Jan 09, 2011 09:53 AM
Discussion What's available for finding a lost vehicle? anderson12 Coaxial Helicopters 5 Nov 25, 2009 02:46 PM
Discussion Control r/c vehicle or robot from pc Endurance Robotics 1 Apr 23, 2009 07:08 PM
Discussion Control aircraft from inside my vehicle highwinger Radios 3 Jun 10, 2006 01:31 AM
