Old Apr 03, 2014, 10:01 PM
dealextremefan's Avatar
China, Guangdong, Shenzhen
Joined Oct 2012
New Quadcopter
DFD F180 Rechargeable 2.4GHz Wireless 4-CH R/C Aircraft w/ Gyro - Black + Red
Added on 3/28/2014
$36.76 + Free Shipping
360 degree roll; After pressing the switch button, hit any rudders, aircraft will roll in that direction, back to normal mode to press again; There are two LED RGB light in the front two eyes, pointing the directions in the dark; Each of four axis with one LED RGB light, controlled by remote
General
  • Brand: DFD
  • Model: F180
  • Color: Black + Red
  • Material: ABS
  • Quantity: 1 Piece
Specification
  • Gyroscope: Yes
  • Channels Quanlity: 4 Channels
  • Function: Up , Down , Left , Right , Forward , Backward , Hovering , Sideward flight
  • Remote control frequency: 2.4GHzfps
  • Remote Type: Radio Control
  • Remote Control Range: 100m
  • Indoor/Outdoor: Outdoor
  • Suitable Age: 12-15 Years , Grownups
Battery
  • Battery Capacity: 250mAh
  • Battery Type: Li-polymer battery
  • Charging Time: 50minutes
  • Working Time: 7~8minutes
Controller
  • Model: Mode2
  • Remote Control Type: Included
  • Remote Controller Battery Type: AA
  • Remote Controller Battery Number: 4 (not included)
Other Features
  • Certification: CE
Dimensions & Weight
  • Dimensions: 5.31 in x 5.31 in x 1.54 in (13.5 cm x 13.5 cm x 3.9 cm)
  • Weight: 21.45 oz (608 g)
Packing List
  • 1 x R/C aircraft
  • 1 x Protective frame
  • 1 x Remote controller (1.5'' LCD)
  • 1 x Chinese / English use manual
  • 1 x Charging cable (60cm)
  • 5 x Foot pins
  • 4 x Blades
  • 1 x Blade replacement tool
dealextremefan is offline Find More Posts by dealextremefan
Old Apr 09, 2014, 01:57 AM
Joined Oct 2012
HJ 2-Axis Camera Brushless Gimbal PTZ w/ BGC3.1 2-Axis Gimbal Controller for Gopro 1/
HJ 2-Axis Camera Brushless Gimbal PTZ w/ BGC3.1 2-Axis Gimbal Controller for Gopro 1/2/3 FPV
BLACKor WHITE
New April 2014
65.99 + Free Shipping
General
  • Brand: HJ
  • Model: 2-Axis
  • Color: BLACK or WHITE
  • Material: plastic and aluminum plate, simple structure and light weight.
  • Quantity: 1 Piece
Specification
  • Compatible Model: Gopro Hero 1/2/3
  • With 2 pcs 2208 90KV motors and BGC3.1 brushless gimbal controller, sensor.
  • Brushless motor direct drive.
  • With anti-vibration rubber balls, easy to adjust.
  • With motor protector which can help heat dissipation.
  • The latest design, and the best choice for FPV.
Dimensions & Weight
  • Dimensions: 3.94 in x 3.94 in x 5.91 in (10 cm x 10 cm x 15 cm)
  • Weight: 11.39 oz (323 g)
Packing List
  • 1 x 2-Axis brushless gimbal in black (disassembled)
  • 2 x 2208 90KV motor
  • 1 x BGC3.1 2-Axis brushless gimbals controller with sensor and connecting wires (25cm)
  • 1 x Pack screws and nuts
  • 4 x Anti-vibration rubber balls
Old Apr 11, 2014, 04:39 AM
Joined Oct 2012
New Quadcopter
JJRC 310B Mini Wireless Remote Control 4-CH 6 Axis Aircraft - Black + White
Added on 4/9/2014
$45.81 + Free Shipping
General
  • Brand: JJRC
  • Model: 310B
  • Color: Black + White
  • Material: ABS
  • Quantity: 1Piece
Specification
  • Gyroscope : Yes
  • Channels Quantity: 4Channels
  • Remote control frequency: 2.4GHzGHz
  • Remote Control Range: 50m
Battery
  • Battery Capacity: 350mAh
  • Charging Time: 45minutes
  • Working Time: 7minutes
Controller
  • Model: Mode2
  • Remote Controller Battery Type: AAA
Other Features
  • Certification: CE
Dimensions & Weight
  • Dimensions: 4.76 in x 4.76 in x 1.34 in (12.1 cm x 12.1 cm x 3.4 cm)
  • Weight: 22.5 oz (638 g)
Packing List
  • 1 x Aircraft
  • 1 x Manual
  • 1 x Battery
  • 1 x USB cable (60cm)
  • 4 x Main fan blade
Old Dec 15, 2014, 12:47 AM
Joined Oct 2012
FY550 R/C Quadcopter
FY550 2.4GHz 4-CH IR Outdoor R/C Quadcopter w / Gyroscope / Lamp - White
-Added on 2014/11/26
$74.20+Free Shipping
http://www.dx.com/p/fy550-2-4ghz-4-ch-ir-outdoor-r-c-quadcopter-w-gyroscope-lamp-white-364058#.VI5yDtKUcjc
General
-Model: FY550
-Color:White
-Material:Plastic
-Shade Of Color:White
Specification
-Gyroscope:Yes
-Channels Quanlity:4Channels
-Function:Up , Down , Left , Right , Forward , Backward , Hovering , Sideward flight
-Remote control frequency:2.4GHz
-Remote Type :IR
-Remote Control Range:50m
-Indoor/Outdoor:Outdoor
-Camera:No
-Lamp:Yes
Battery
-Battery Capacity :650mAh
-Battery Type :Li-ion battery
-Charging Time:30minutes
-Working Time:8~10minutes
Controller
-Model :Others
-Remote Control Type:Included
-Remote Controller Battery Type:AA
-Remote Controller Battery Number :6
Dimensions & Weight
-Dimensions:15.75 in x 12.6 in x 3.54 in (40 cm x 32 cm x 9 cm)
-Weight:3.35 oz (95 g)
Old Dec 15, 2014, 09:45 PM
Joined Oct 2012
Ehang Ghost-L Cell Phone Controlled 4-CH Quadcopter
Ehang Ghost-L Cell Phone Controlled 4-CH Quadcopter w/ GPS / Wi-Fi / 1080P HD Camera
Added on 2014/12/9
$850+Free Shipping
$50 Coupon Code:GHOSTAERIAL
Only 50 available for $50 coupon. Please Hurry! Coupons are valid from Dec.15 2014 to Dec.29 2014
Ehang Ghost Smartphone Controlled Quadcopter Makes Your Aerial Flying Dreams Come True! -- DX.COM (4 min 5 sec)
Camera Features:
- Screen: 1.5LTPS
- Language: Simplified Chinese / Traditional Chinese / English / French / Spanish / Italian / Portuguese / Ruassian / Japanese
- Video: 1080P (1920 x 1080) 30fps, 720P (1280 x 720) 60fps, VGA (848 x 480) 60fps, QVGA (640 x 480) 60fps
- Video format: MOV
- Compression format: H.264
- Resolution: 12M / 8M / 5M
- Supports micro SD / TF card
- Camera mode: Single, Timing Selfie, 2s / 5s / 10s, Continuous shot
- Light source frequency: 50Hz / 60Hz
- USB interface: USB 2.0
- Battery capacity: 900mAh
- Power consumption: 4.2V / 400mA
- Camcording time: 1080P / 70 minutes
- Charge time: About 3 hours
- OS supported: Windows XP / Win 7, Mac, Vista or above
- Appearance size: 59.27 x 41.13 x 29.28
Old Dec 17, 2014, 01:41 AM
Joined Oct 2012
Ehang Ghost Cell Phone Controlled R/C Quadcopter
Ehang Ghost Cell Phone Controlled 2.4GHz 4-CH R/C Quadcopter w/ GPS / Wi-Fi / Gyro
Added on 2014/12/9
$600 + Free Shipping
$30 Coupon Code: GHOSTSTANDARD
Only 50 available for $30 coupon. Please Hurry! Coupons are valid from Dec.15 2014 to Dec.29 2014
http://c.dx.com/collection/201412/Qu.../en/index.html
General
-Model :Ghost
-Color:Black
-Material:Plastic
-Shade Of Color:Black
Specification
-Gyroscope:Yes
-Function:Up , Down , Left , Right , Forward , Backward , Stop , Hovering , Sideward flight
-Remote Control Range:1000m
Battery
-Battery Capacity :5400mAh
-Charging Time:4Hour
-Working Time:13~18minutes
Controller
-Remote Controller Battery Type:Others
-Remote Control Type:IPHONE or IPAD or IPOD , Android Phones
-Model Mode1 , Mode2
Dimensions & Weight
-Dimensions:18.11 in x 18.11 in x 7.48 in (46 cm x 46 cm x 19 cm)
-Weight:53.9 oz (1528 g)
Old Yesterday, 01:44 AM
Joined Oct 2012
F183 2.4GHz 4-CH R/C Quadcopter
F183 2.4GHz 4-CH R/C Quadcopter w/ Gyro / 2.0MP Camera / LED Display - White + Black + Multi-Color
Added on 2014/12/12
$83.84 + Free Shipping
General
-Model :F183
-Color:White + Black + Multi-Colored
-Material:ABS
Specification
-Gyroscope:Yes
-Function:Up , Down , Left , Right , Forward , Backward , Stop , Hovering , --- Sideward flight
-Remote Type :Radio Control
-Remote Control Range:300m
-Camera:Yes
-Camera Pixel :2.0MP
-Lamp:Yes
Battery
-Battery Capacity: 450mAhmAh
-Charging Time:100minutes
-Working Time:10minutes
Controller
-Remote Controller Battery Number :4
-Remote Control Type:Wireless
-Model :Mode1 , Mode2
For Sale Weekend 10% discount on ALL of our products ClmPro Aircraft - Sailplanes (FS/W) 3 Oct 09, 2013 07:28 AM
Cool This product might be useful in our collective hobbies. SSgt Baloo Life, The Universe, and Politics 24 Oct 02, 2013 10:45 PM
New Product New Products / Stock Arrivals / Product Updates thread Extreme_RC Extreme RC AUSTRALIA 6 Oct 05, 2011 02:53 AM
Discussion Yellow Aircraft New Product Arrival YellowAircraft Electric Ducted Fan Jet Talk 17 Jan 08, 2009 05:33 AM
