Old Nov 24, 2012, 11:31 AM
Joined Jul 2010
Mini-HowTo
Aileron hinging
I use a "S" type hinge for my ailerons. Here is what I do:
first I make 12 small strips of strapping tape
http://imageshack.us/a/img443/8462/img0591f.jpg
then i over lap 2 strips 1/4" and stick together sticky side to sticky side
http://imageshack.us/a/img821/1471/img0592zd.jpg
then i tape one to the bottom of the wing and one to the top right next to each other, I do this at 3 spots on each aileron
http://imageshack.us/a/img38/3371/img0593h.jpg
http://imageshack.us/a/img850/8743/img0594pkg.jpg
lastly I set the aileron inbetween and press the tape down
http://imageshack.us/a/img266/6161/img0596ls.jpg
and there you have a nice never come loose aileron hinge!
now how do you do your hinges?
p.fawcett is offline Find More Posts by p.fawcett
Old Nov 24, 2012, 04:03 PM
Joined Nov 2006
I use basically the same technique. I don't put all the tape on the wing and have to fuss with sliding the the aileron in bewteen the "fingers."
Masking tape was used for illustration only!!! Use Bi-Directional Tape or Regular Strapping Tape. I personally use 1.5 inch Bi-Di for the hinges.
Take 2 pieces and put the sticky sides together overlapping a quarter inch. Each hinge requires two of these. 3 hinges per aileron are recommended. One on each tip of the aileron and one in the middle. 3 hinges are good for SSC, Limited B and Scale 2948. I would go with at least 4 for Open B.
http://www.rccombat.net/gallery/main...2_itemId=11275
Line up the tape so that the overlap will be at the trailing edge. Note one piece on top of wing and the other on top of aileron. Do this for all the hinges on the aileron.
http://www.rccombat.net/gallery/main...2_itemId=11279
Lay aileron upside down on wing and line up the hinges.
http://www.rccombat.net/gallery/main...2_itemId=11282
Fold over all of the pieces of tape onto the aileron.
http://www.rccombat.net/gallery/main...2_itemId=11285
Fold over all of the pieces of tape onto the wing.
http://www.rccombat.net/gallery/main...2_itemId=11288
With the aileron at a 30 degree angle downward, add a strip of tape over the top of each hinge, making sure you keep the aileron tight to the wing. This helps keep it really tight.
http://www.rccombat.net/gallery/main...2_itemId=11291
CLICK TO DOWNLOAD 2 PAGE PDF
midair72 is offline Find More Posts by midair72
Old Nov 24, 2012, 05:25 PM
Sho Nuff Combat Pilot
Dane McGee's Avatar
United States, TX, Greenville
Joined Mar 2008
Paul,thanks for posting this very important construction tip.
The over-under method is exactly what I use.
Very strong, very tight and zero flutter...............the aileron will fail before the hinge.
Dane McGee is offline Find More Posts by Dane McGee
Old Nov 30, 2012, 04:01 AM
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
This picture is an elevator, not an aileron, but I've come to really like sewn hinges since I learned to do it. Lots of different methods, bu this one is about 3 loops of thread in the over-under fashion.
Description: Name: SAM_2006.jpg
Description:
They are very limber with zero slop. It's self-gapping as you sew too.
RknRusty is offline Find More Posts by RknRusty
Old Nov 30, 2012, 04:08 AM
RknRusty's Avatar
Joined May 2010
Originally Posted by midair72 View Post
I use basically the same technique. I don't put all the tape on the wing and have to fuss with sliding the the aileron in bewteen the "fingers." ...
One post in 6 years, Midair! I'm glad you finally broke the silence. Welcome to RCG.
Rusty
Found Need help fixing aileron hinge whirl10 Aircraft - Electric - Airplanes (FS/W) 2 Nov 23, 2012 12:33 AM
Discussion Binary 900 V2 Aileron hinge sterob Hand Launch 11 Nov 22, 2012 08:04 PM
Discussion Securing aileron hinge wire? packardpursuit Giant Scale Airplanes 9 Nov 13, 2012 08:21 AM
Discussion Scale aileron hinge, how would you make this better? kenh3497 Balsa Builders 10 Nov 08, 2012 09:39 AM
Discussion Aileron Hinges rogcox The Builders Workshop 2 May 08, 2012 09:27 AM
