Old Nov 13, 2012, 07:11 PM
Actively makin humans obsolete
Razor_Racer's Avatar
Northern Virginia
Joined Jul 2007
Revell or Midwest plywood?
I'm looking for some 1/8" plywood and I can get Revell birch plywood and Midwest craft plywood for about the same cost.
Any ideas on which one is better, or the differences between them? Thanks!
Razor_Racer is offline Find More Posts by Razor_Racer
Old Nov 13, 2012, 09:01 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I just saw some Revell ply for the first time a couple of weeks ago. It looked fine to me. It probably came off the same say in the same factory. One stack is Midwest the other stack is Revell.
Ken
If you have a Michaels craft store near you check their wood selection. I think you can use a store coupon for a percentage off here>>>> http://weeklyad.michaels.com/coupons...ichaels-121111
kenh3497 is online now Find More Posts by kenh3497
Old Nov 13, 2012, 10:54 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Check the look of the grain and the number of plies. 1/8 aircraft birch plywood will have 7 layers. Cheaper paneling will have 3 or maybe 5.
As it happens I was in a Micheal's store just today where I bought a box of popsicle sticks and happily found the section for modeling clay (I'm all out of Pasticene for small model nose weight ). I checked out the balsa, bass and plywood and didn't stay long enough to evaluate the grades once I saw the prices. It made my Scottish side gasp in pain! ! ! !
BMatthews is offline Find More Posts by BMatthews
Old Nov 14, 2012, 02:46 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
I just checked on some 1/8" ply myself. A 12"x24"x1/8" 6-ply was a hair over $17.00 This is from Bud Nosen Models.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Nov 14, 2012, 03:19 AM
God - Family - R/C
United States, CA, Bloomington
Joined Jul 2004
The cheapest 1/8 x 12 x 24 birch plywood (3-ply) I've seen $4.59
and 1/8 x 12 x 24 birch ply (6-ply) $10.27.http://www.nationalbalsa.com/category_s/139.htm
gsnflyt is offline Find More Posts by gsnflyt
Old Nov 14, 2012, 03:41 PM
Joined Dec 2008
gsnflyt Good prices! But tell me, have you ordered from them, and if so, where the sheets "flat"? Seen to many sheets, even at my LHS that were not acceptable. Twisted, warped.
Old Nov 15, 2012, 03:50 PM
kenh3497's Avatar
Joined Jul 2011
Ya have to use the 40% coupon. Good to get you out of a pinch, but not for a large order.
Ken
Old Nov 15, 2012, 06:21 PM
bullseye000's Avatar
Aurora Municipal, Illinois, United States
Joined Jul 2002
At one time Midwest had 2 grades of plywood, aircraft and hobby. As mentioned above the aircraft grade had 7 layers and the craft grade had 3 IIRC. They used to mark the craft grade stuff with "Not for aircraft use".
bullseye000 is online now Find More Posts by bullseye000
Old Nov 16, 2012, 12:37 AM
unclecrash's Avatar
white lake michigan
If you can use the 3 ply hobblinc sells in bulk. I picked up a bundle of 6 sheets of 1/8x12x24 for around 30 bucks. Its revelle and it is really nice at least the stuff I bought was.
unclecrash is offline Find More Posts by unclecrash
Wanted Hull for Midwest Liberty Tug or Patriot Fireboat rblubaugh Boats (FS/W) 6 Aug 02, 2012 02:59 PM
Question Midwest Plywood “Not for Models Airplanes” why? Tommy D The Builders Workshop 13 Aug 02, 2007 03:06 PM
Question Midwest craft plywood "no aircraft use" wattsup_kz The Builders Workshop 9 Aug 23, 2006 04:38 PM
Discussion what tools do you guys use to cut balsa or plywood ?? xrbeast The Builders Workshop 6 May 28, 2006 05:34 AM
Question Plywood sheeting: epoxy or polyurethane and reinforcements Protocooler The Builders Workshop 6 Mar 01, 2004 05:53 PM
