Old Apr 30, 2014, 01:47 AM
Turkey, Ankara
Joined Jun 2010
Angel Interceptor. Need your opinions
I have decided to build Angel interceptor for my next project.
I want to use Depron and 2x70 mm edf inside with single outlet.
I only found serious drawings of Kevin 64's drawings, shown here.
I really need your opinions and guidance in every aspect of plane.
Thanks in advance.
selšuk is online now Find More Posts by selšuk
Old Apr 30, 2014, 05:29 AM
USA
Joined Apr 2007
don't forget wing loading look's like small wing for two fans
space 1 is offline Find More Posts by space 1
Old Apr 30, 2014, 08:56 AM
Turkey, Ankara
Joined Jun 2010
For two 70mm CS fans in a single outlet, the outlet diameter should be 2x5,75 cm.
Not sure about it.
If I am right than the plane would be about 3,5 m long for scaling.
So I think single fan would be better???
Old May 01, 2014, 03:18 AM
United Kingdom, England, Hindhead
Joined May 2004
yes, the real one only has a single jet pipe not two. aso its going to save a lot of weight. you might need to over size the wing and canards
desmo is offline Find More Posts by desmo
Old May 05, 2014, 04:48 AM
Turkey, Ankara
Joined Jun 2010
Thanks.
I began to build.
As the fan outlet area is small, I got the copy of drawings 7cm.
Size comparision with freewing f 16.
I added about 2 cm length aft and wingspan.
Recent progress.
Old May 05, 2014, 05:24 AM
USA
Joined Apr 2007
you going run 3s or 4s
Old May 05, 2014, 06:40 AM
Turkey, Ankara
Joined Jun 2010
4s (about 3000-3500 ma)
Old May 07, 2014, 06:01 AM
Turkey, Ankara
Joined Jun 2010
Installed e-flite's 70 mm fan from a spare habu and 100A esc from HK.
I used 2 metal digital servos for elevators. The question is whether these servos interfere each otheror not.
Old May 09, 2014, 05:41 AM
Turkey, Ankara
Joined Jun 2010
Finished the main section.
First mate with the aft section (while drying).
Old May 11, 2014, 04:17 AM
Turkey, Ankara
Joined Jun 2010
Mostly completed.
Waiting for filling the gaps and fine sanding.
How will I find a cockpit , I do not know.
Weight is about 900 grams (without battery).
100 grams more weight than Fw 's F 16
Old May 11, 2014, 04:27 AM
Joined May 2004
this is so cool !!!! SIG!!!
oh beware the mysterons........
Old May 11, 2014, 05:33 AM
USA
Joined Apr 2007
only problem I see is vertical stab air may not pass through . ck bi wing for ref
Old May 11, 2014, 09:19 AM
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Very cool build. Best of luck with the maiden.
regards,
Jeff
jhspring is offline Find More Posts by jhspring
Old May 18, 2014, 02:40 PM
Turkey, Ankara
Joined Jun 2010
Interceptor building is completed with a temporary kokpit.
Waiting for maiden.
Old May 20, 2014, 06:50 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice work. and good luck with the maiden
Question If your own one, what's your opinion of Gaui Hexa 840 ? BenHayat Multirotor Talk 5 Apr 22, 2014 01:22 AM
Question I need your opinions.... MadMonkey572 Multirotor Talk 0 Dec 09, 2013 04:10 AM
Discussion Heli Checklists - Your opinion needed trent73 Large Electric Helis 1 Oct 28, 2013 09:23 PM
Discussion Captain Scarlet Angel Interceptor alfoot Foamies (Scratchbuilt) 7 Jul 06, 2011 03:05 AM
JDC II Microfan Angel Interceptor keven64 Electric Ducted Fan Jet Talk 41 Mar 05, 2006 07:09 PM
