Old May 04, 2013, 07:35 PM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
90mm Sport Jet --5th Generation Fighter Style FINALLY A GOOD VID
I`ve been kicking around building a 90mm size Sport Jet that combines the features that I like from some of the 5th gen fighters and prototypes (F-22, YF-23, F-35).
I did some sketches the other day and decided it had enough promise to build a 30mm sized edf to test the concept and to see it in 3D.
Today I sat down with some 3mm depron and threw something together. It`s a flyable rough prototype. Nothing fancy.
I`m going to look it over for a while and see what changes would help the looks.
I`d also welcome suggestions and opinions. Positive and negitive input is welcome, but if you don`t like something try to tell me why, and what you`d suggest to fix it.
Anyway, here it is. Fire away.
Knife Liddle is online now Find More Posts by Knife Liddle
Old May 04, 2013, 07:39 PM
2014 EDF JET JAM We be Jamming
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Nice Lee!!
Kevin Cox is offline Find More Posts by Kevin Cox
Old May 05, 2013, 06:31 AM
michigan jet guy
mrshea's Avatar
USA, MI, Caledonia
Joined Jul 2007
I like it. It's different. I hope it flies well. Phil
mrshea is online now Find More Posts by mrshea
Old May 05, 2013, 01:38 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Thanks for the input guys. I`m thinking that the wing is bigger than it needs to be and that the fuselage could be a little larger. It will need to be deeper to hold a 90mm.
Getting some gear in it. I`m just going with elevons on this to keep it simple. A 90mm would have ailerons and rudder-vators on the V-tail. Then mix in flaperons if it needs some help on landing.
If the wind lays down some this PM I`ll see if I can get some flight vid.
Old May 05, 2013, 02:18 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Nice work.
I came across one several months back you might like.
It is called the Mig49 'Frostbite'.
http://sketchup.google.com/3dwarehou...84&prevstart=0
Eric B.
AirX is offline Find More Posts by AirX
Old May 05, 2013, 03:50 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Yeah, that`s a nice looking concept. Thanks for the link Eric.
Got her RTF. The AUW with a 450mah 3s is 110g and it has about 90% t/wt ratio. I may cut a cheater hole in the bottom to boost thrust a little. The wing isn`t strong enough for a bunch of speed, so I`m more interested in thrust.
With a 3s 950mah the weight goes up to 138g but the flight time would be 6min or so. But at the higher weight th/wt drops quite a bit of course. I`ll try it at 110g first and see how it goes.
Old May 05, 2013, 04:11 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Cheater hole helped some. Now it`ll just support its weight at 110g.
Old May 05, 2013, 04:12 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
Looks cool lee! Should fly good!
corsair nut is offline Find More Posts by corsair nut
Old May 05, 2013, 04:42 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Thanks Brent. I was looking at this thing at HK, for a 90mm starting point, but it was just too far off. Would probably be way too nose heavy too judging by the fan location.
Old May 05, 2013, 05:51 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I did a maiden and it flew well. CG was dead on (I did glide tests when it was just depron and 1oz). The roll was pretty hot at first so I went to low rate and that fixed it. Pitch was good. It was pretty fast so the wings were flapping some in the gusty wind. So I added a carbon spar that is flat and wide, so I just sliced the wing and glued it in vertically. I should be able to throw it around a little better now. Will get some vid on the next flight.
Old May 05, 2013, 06:12 PM
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
They don't fly worth a darn either.
Several models were tested here in AZ by big names (Bob Ruff, Mike Donovan, etc.) and each one proved very unflyable. Not their fault at all... the design is sketch, inherently unstable, etc.
Yours looks more thought out and proportional. Good luck with this one, looks fun!
AceMigKiller is offline Find More Posts by AceMigKiller
Old May 05, 2013, 06:37 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Thanks Vic. I put some gray paint on it and got some video. It`s very gusty and there is a very strong roller right were I`m flying so it looks crazy, but for a 4oz jet it`s doing very well. Should be a blast when the wind is decent.
I`m uploading to You Tube now and when I edit my ugly face out of the vid, i`ll post it. LOL
Old May 05, 2013, 07:38 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I took this video down because it was so lame. The other one is passable, but I`m going to try another video when I get some good conditions.
Old May 05, 2013, 07:47 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I splattered some paint on it. It was a fun weekend project that worked out. Now I have another backyard flier and maybe sometime I`ll make a big one.
Old May 06, 2013, 09:01 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Got to fly it in calm conditions this morning. Much more fun to fly. It needs somefine ttuning on cg and some aileron differential to straighten out the roll axis, but over all it flies great.
It has much better performance at 110g than it does at 140g. I'm surprised at the difference, but it's very obvious.
I'll get some better video soon. It looks very much the part of a 5th gen fighter in the air. I think that most people would swear that they are seeing a scale F-22.
Build Log 200% 90mm EDF Jetset44 Super Bandit sport jet build Keenan smith Scratchbuilt EDFs 27 May 14, 2013 12:59 PM
Fighter Jet - Art-Tech F-14 5-CH 2.4GHz Ducted Fan RC Model Fighter - Transmitter dealextremefan DealExtreme RC 0 Apr 09, 2013 10:19 PM
Wanted EJF Sport Jet 90mm CARL SCHIMNOWSKI Aircraft - Electric - Jets (FS/W) 0 Jan 15, 2013 12:23 AM
