Old Feb 18, 2013, 01:09 AM
Manufacturer
IceManPro's Avatar
Joined Sep 2012
New Product
BL-3GRC Gyro
I would like to announce our new ICE-MAN BL-3GRC Gyro for fixed wing and multi-copter aircraft: Unprecedented set up and configuration options with in-built USB.
See here
I fly fast and want fast gyro response but my RC Tx only outputs pulses at 15ms. Would be good to increase to say 6ms to support my fast digital servos
-with the BL-3GRC YOU CAN
Would be good to fly my delta wing slowly on landing to save on runway length
- With the BL-3GRC YOU CAN add flaperon function even for delta wing
I have a big aircraft which needs lots of runway to land. Some sort of speed brake would be good
- with the BL-3GRC YOU CAN with two stage flaps, third stage ailerons up for air-brake / ‘crow’ function
I have a big beast of a plane with dual wing servos, even two opposing servos for the rudder. Would be good to have just one controller
- With the BL-3GRC YOU CAN with two configurable outputs per axis
I like to teach my novice friend how to fly but he has a habit of veering off to the side of the runway on take-off. Would be good to have very large gyro rudder gain just at take off
Would be good not to have to re-trim my aircraft after a long time or remember which RC Tx has the trim saved. Great if the gyro can automatically save the trim settings
- with the BL-3GRC YOU CAN just pick up any RC transmitter and set all trims to zero
I like to fly fast but want good stability during slow landings with flaps or flaperons
- with the BL-3GRC YOU CAN set real time two gain switch for fast / slow flying
I am a bit of a novice and only have a small area to fly in, would be good to find a way to keep the turns tight and stop flying away so far. I’m still a bit nervous about using the rudder myself, would be good if some rudder could be applied during my turns
I have a foamie flying wing aircraft would be good to hide a controller inside the wing
- with the BL-3GMod YOU CAN. The MOD version is a small 35mm square, thin PCB, you can cut off or de-solder the pins, connect (solder) only the inputs and outputs you want, and have a flying wing with controller/flaperon function/gyro buried inside.
Such a low price too, talk about a game changer! I work for Bluelight so don’t take my word for it, check out the user manual and PC set up s/w before you buy. www.bluelight-tech.com
IceManPro is offline Find More Posts by IceManPro
Old Feb 22, 2013, 06:59 AM
United States, CA, San Marino
Joined Jun 2003
Very interesting gyro. I skimmed through the manual. From what I gleaned, it would be possible to setup a fixed wing aircraft that has both separate aileron servos & separate elevator servos by using the extra outputs- is that correct?
gauchers is offline Find More Posts by gauchers
Old Mar 04, 2013, 10:27 PM
Manufacturer
IceManPro's Avatar
Joined Sep 2012
Hi gauchers, yes that's correct, you can have two servos for each. ie two for ailerons, two for elevator, and two for rudder. Each output 'direction' can be set up individually so the servos don't need to be mounted the same way.
Old Mar 05, 2013, 05:32 AM
Joined Jun 2003
Excellent. I already ordered a unit & am looking forward to testing it out!
Old Mar 11, 2013, 10:29 PM
Manufacturer
IceManPro's Avatar
Joined Sep 2012
Cool, thanks..
Sold 3 x New E-Flite/PZ BL 15; 1 x New E-Flite/PZ 480; 1 x used BL 15 jgalexander Aircraft - Electric - Power Systems (FS/W) 3 May 24, 2013 03:00 PM
Discussion BL-3GRC Amazing new Gyro / Controller for airplane and multi-copter IceManPro Beginner Training Area (Aircraft-Electric) 0 Sep 27, 2012 01:49 AM
Discussion BL-3GRC Amazing new Gyro / Controller with Delta and V-tail support IceManPro Flying Wings 0 Sep 27, 2012 01:45 AM
Discussion BL-3GRC Gyro for multi-copter and airplane IceManPro Multirotor Electronics 0 Sep 03, 2012 06:48 AM
Sold 1 Parkzone 480 BL Motor, 1 Skysurfer BL Motor and 1 NIB Assan GA250 Gyro gent96 Aircraft - Electric - Power Systems (FS/W) 4 Jun 06, 2011 11:45 AM
