Old Jul 18, 2011, 04:47 PM
bigflankster
In the Soo.......
Joined Nov 2007
SC10 Tranny Issue
I have a SC10 that is only had 8-5000 mah LIPO's run through it and there is a ratcheting sound coming from it on acceleration out of the turns... I pulled it apart and the pinion and spur gears looked fine, all the diff. gears appear to be in good shape, I cleaned out the grease and filled her up with diff lube and the ratcheting is still there................. any advice would be appreciated, Thanks, Hank
bigflankster16 is offline Find More Posts by bigflankster16
Old Jul 19, 2011, 06:51 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
How do the dogbones look? Is the slipper clutch tight enough?
wparsons is offline Find More Posts by wparsons
Old Jul 21, 2011, 07:42 PM
Joined Jan 2009
From Donn at Associated:
OKGUYS AND GALS, here is what I found out from our R&D department.
The material that the diff gears was to be made up off was changed to beige type material we have in the kits and in the RTR's to come.
And the different material cools differently, and sometimes when the gear cools after being molded it could have an extra hundred thousand of more space inside where the large spider gear are placed. So in some of the gears when you take of you hear a click.
Not all of them will have this, but some do and the ones that do should get me your info.
We have the shims that it takes to correct this and just need you to fax or mail me your address with the notation of SC10 Shims on it and I will send you out the shims to correct the spacing problem.
NitroVette is offline Find More Posts by NitroVette
Discussion futaba j6 tranny dave walsh Batteries and Chargers 10 Dec 27, 2011 03:52 PM
Question 2.5 Revo tranny ratio? sledge21 Off-road Cars 0 Jul 07, 2011 01:08 AM
Rant Terry the Tranny Mark Wood Site Chat 29 May 17, 2011 02:02 PM
Wanted tmaxx 3.3 tranny k_ogre Cars - Trucks and Parts (FS/W) 0 Apr 07, 2011 04:48 AM
For Sale HPI 2 speed Tranny (new unused) & 3 Speed Tranny (2 tanks new) Timmahh Cars - Cars and Parts (FS/W) 8 Oct 05, 2007 11:22 PM
