Old Jan 19, 2011, 10:22 AM
Joined May 2003
Need Help with correct CG Location on my New EDF Jet
[IMG][/IMG] Hi Guys:
I am told that there are experts available on this site who might be able to help me. i just built a scratch jet (that is, from plans) jet called a Force 10, designed by a fellow named Dan Marlowe. I am unable to locate Mr Marlowe for his assistance in this matter, so i am turning to you guys ( and/or gals). I was told that you can locate the proper CG from the photo of the plan view, so I took the picture today and here it is:
Wingspan 55.5 inches
distance from LE wing to LE stab= 25 inches
wing root chord = 17.75 inches
wing tip chord = 6.5 inches
Wing sweep distance = 8.25 inches
Stab root chord = 9.25 inches
Stab tip chord = 3 inches
Stab sweep distance = 5.25 inches
Stab span = 22.25 inches
If it matters, AUW is 14.5 pounds.
I have inputted all this data into the CG calculators available online. My primary issue is that these plans are not very accurate in other areas and I am terrified to trust what is shown on the plans for CG.The blue tape shows the plan's suggestion for CG location. If what you guys say coincides with what I calculate, then the plans CG is too far aft. I will have a much higher level of confidence if your suggestions are in accord with the calculations I have done.
Thanks for any help. I do appreciate it. As far as I have been able to determine in my emails with Bob Ruff, this may be the only one of this particular design ever built. Obviously if that is true, none have ever flown, so I need all the input I can find prior to attempting the first flight.
I was quite surprised when Bob indicated that there are folks who can simply use the planform view and determine the correct CG for most planes. COOL!!! I anxiuosly await your responses.
bonefishfool is offline Find More Posts by bonefishfool
Old Jan 19, 2011, 10:48 AM
High Altitude Specialist
snivilous's Avatar
Joined Jan 2010
go here: http://www.geistware.com/rcmodeling/cg_calc.htm
it explains what dimensions to plug in and then where your CG should be. I usually choose 30% of the mean aerodynamic chord (MAC) for my CG, but 1/4-1/3 back works.
snivilous is offline Find More Posts by snivilous
Old Jan 19, 2011, 11:29 AM
Joined May 2003
Thanks, snivilous. I appreciate your help. Actually I have already used the available online calculators, at those I could find. I am hoping that someone or ones will have an alternate method of calculation in order to confirm waht these calculators say.
Thanks again!
Old Jan 19, 2011, 11:32 AM
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Greetings, one of the guys will give it a shot. Jet looks good!
Bob
bruff is offline Find More Posts by bruff
Old Jan 19, 2011, 11:33 AM
snivilous's Avatar
Joined Jan 2010
Thanks again!
yeah, I saw what you said above and how to verify the results. You could do a long hand method, but it should yield the same thing as your doing the same calculations. Or if you just want to be quick you could measure 35% back from your root chord and that would probably give you a rather generic ball-park figure as well.
Old Jan 19, 2011, 11:35 AM
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
Not an expert but I would want to error on the side of caution. Im thinking that 1" in front of the pic cg may be a good place to start.
Great looking jet by the way...
Ben
Ben-Rod is offline Find More Posts by Ben-Rod
Old Jan 19, 2011, 12:08 PM
"...certainty is absurd."
kcaldwel's Avatar
Joined Jan 2007
kcaldwel is offline Find More Posts by kcaldwel
Old Jan 19, 2011, 12:23 PM
life is an oyster. shuck it!
istandalone's Avatar
bennington, VT
Joined Mar 2008
wow, that came out nice!
looks like a sniper/f20 hybrid. very sweet.
istandalone is offline Find More Posts by istandalone
Old Jan 19, 2011, 12:46 PM
Joined May 2003
Thanks everyone! i appreciate your input. kcaldwel, my calculations put it about the same- 7 inches back from wing root LE. that makes me feel more confident. Hopefully others will confirm as well.
The jet did come out nice. Most of the credit should go to my brother. He did the hard stuff. It looks really nice. i decided to defer the detailing until after the maiden. It has the new XPS fan and I am trying the new Eflite large retracts. It was a very tough build- most everything required complete re-engineering, which is why I am suspicious of the plans recommended CG
Old Jan 19, 2011, 01:01 PM
Joined May 2003
Guys:
Herer is another photo of the jet in my brother's shop. Still considering details such as decals, art, etc. Better wait to see how the first flight turns out. i love the air intake he put in the forward part of the stab base fairing.
What do you guys think??
Old Jan 19, 2011, 04:29 PM
Joined May 2003
Kevin
I measured the jet. The actual numbres are-
nose to wing leading edge at the centerline of the aircraft = 25 inches
fuselage measures 6.5 inches wide, but flares as at the inlets to 9 inches. I am not certain if ths makes any difference. I am trying to plug these numbers into the spreadsheet you sent but am trouble understanding exactly how to do it.
Thanks again for your assistance.
James
Old Jan 19, 2011, 05:47 PM
kcaldwel's Avatar
Joined Jan 2007
Old Jan 19, 2011, 06:32 PM
Joined May 2003
Thanks, Kevin!!! You are the man. i truly appreciate it. I feel so much better about giving it a go. Forward bests aft every time, but I will need to have an effective elevator to rotate.
I'll keep working with the spreadsheet. i did actually read the accompanying instructions, but math is not my strong suit.
It is nice to have folks like you available to help the rest of us.
James
Old Jan 20, 2011, 03:36 AM
Joined Jan 2010
I would say 1cm in front of your marker will be spot on, good luck with maiden, Joe.
jofro is offline Find More Posts by jofro
Old Jan 20, 2011, 06:08 AM
Da' Cajun
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Wow! nice lookin' bird.
I've scratch built a couple jets and nothing cause me more sleepless nights than the CG question.
After doing all the CG calcs out there's nothing like the tried & true foam glider. Cut out a to scale glider and start throwing it around in the backyard.
I usually start balancing the glider tail heavy, toss it up in a steep climb and watch how it reacts to the stall.
If it floats too much or does the falling leaf stall = bad.
I look for a definite nose drop and steep glide with little pull out in the after stall glide (really rough on the nose). Transfer that CG spot, as a % of the root, to the model and it's worked every time.
It will be slightly nose heavy and as you fly the model more and more you can creep the CG back to suit your flying style.
Julian
Boogie_ is offline Find More Posts by Boogie_
Build Log My new scratch built rc edf jet: the Falcon 70 (w/ build and maiden flight video) j3tman Scratchbuilt EDFs 13 Jun 22, 2011 10:19 AM
Discussion Help trying to mix ailerons with elevons on a exceed rc 2.4ghz tx for a EDF Jet Leeadamaa Electric Ducted Fan Jet Talk 1 Jan 30, 2011 05:10 PM
Discussion Help trying to mix ailerons with elevons on a exceed rc 2.4ghz tx for a EDF Jet Leeadamaa Power Systems 3 Jan 01, 2011 03:00 PM
For Sale Need help with sale or trade for heli with my brand new just built gp reactor neweramarketin Aircraft - Fuel - Airplanes (FS/W) 6 Sep 30, 2010 07:26 PM
