Old Feb 18, 2013, 08:13 PM
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Absolutely! Let's see it.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Feb 18, 2013, 11:57 PM
plcline67's Avatar
United States, WV, Montcalm
Joined Sep 2007
Originally Posted by Barn-E-Stormer View Post
What about your last one? I can repair it or send you some new parts if needed.
I still have it, just thinking about getting another one.
plcline67 is offline Find More Posts by plcline67
Old Feb 19, 2013, 06:49 AM
United States, VA, Blacksburg
Joined Jun 2010
SF1 Built by Barn, Jon and Dave
2011-11-19 Lee Ulinger Model SF1 RC Electric Airplane Flight Testing (12 min 51 sec)
david.merc is offline Find More Posts by david.merc
Old Feb 19, 2013, 09:41 AM
Dark Yet??
Joined Dec 2009
Now we need a night video.
Old Feb 19, 2013, 12:17 PM
Dark Yet??
Joined Dec 2009
With all the bottom strips in place and the strips for the "fuse tubes" in place it's time to put the SFGs on. Next the LED strip on the leading edge of the wing will be installed.
Old Feb 19, 2013, 12:38 PM
Dark Yet??
Joined Dec 2009
I put the 6mm strip from Hobby Partz on the leading edge of the wing and each SFG. The strip on the SFG is 20mm from the wing. Mounted low like this the strip shines over the wing surface, adding to visibility.
Plan out your strips before gluing them down. Tin the pads in the locations necessary for the interconnect wiring. When possible, solder wires to the strip before sticking it on. I usually put on some "starter" wires.
Old Feb 19, 2013, 12:41 PM
Dark Yet??
Joined Dec 2009
The elevator top will have a simple "V" on it. To cross a hinge line with LED strip, just put a small kink in at the hinge line to allow movement.
Old Feb 19, 2013, 01:55 PM
Dark Yet??
Joined Dec 2009
Now with all the strip installed it's time to interconnect all those strips.
A note on daisy chaining connections. Sometimes it is easier to make up some wires before hand to daisy chain connections.
  • Strip two wires a bit long
  • Twist together
  • Tin with solder
  • Trim down to pad size
Old Feb 19, 2013, 05:40 PM
Dark Yet??
Joined Dec 2009
With all the strips interconnected I braid the feed wires to make a cable, tie all the ends together and solder to a balance tap connector. I cut all the middle pins out of the connector for safety.
Old Feb 19, 2013, 05:45 PM
Dark Yet??
Joined Dec 2009
Mount all the servos.
Note on control horns: I have used the plywood or phenolic horns that come with the kits in the past. This type of horn is flat, and just pushes down into a slit and is glued. They break out easily and cause "Secondary crases" when the horn becomes loosened in a mishap and then later comes loose in flight.
These pin type horns from Hobby King used with an extra gusset on each side of the surface are excellent and never come loose.
Old Feb 19, 2013, 05:49 PM
Dark Yet??
Joined Dec 2009
Here we go.....
Old Feb 21, 2013, 09:55 AM
Dark Yet??
Joined Dec 2009
A bright glowing motor box.
The top "LED Tubes" shine thru the bottom so much I won't use any on the bottom of the next one. The colors mix and make a nice orange glow on the bottom.
Old Feb 21, 2013, 10:36 AM
Which one is aileron again?
USA, VA, Blacksburg
Joined Apr 2006
Maybe install red on one corner and blue on the opposite so the other corners appear purple?
prototype3a is offline Find More Posts by prototype3a
Old Feb 21, 2013, 11:44 AM
Dark Yet??
Joined Dec 2009
I will mock up some lights on a piece of Depron and see what that looks like.
Old Feb 27, 2013, 07:43 PM
Dark Yet??
Joined Dec 2009
Twins!
The bottoms are slightly different. I still think the "V" is the best.
LED strip mounted low on the SFG is the way to go. Really lights up the wing.
Sold 36" Wingspan RTF Night Flyer - $115 LPU Only gabrielisrael Aircraft - Electric - Airplanes (FS/W) 1 Feb 13, 2013 06:36 PM
Sold 3d Park Flyer Foamy. rhampton Aircraft - Electric - Airplanes (FS/W) 3 Feb 13, 2013 05:52 AM
Sold 3d park flyer foamy rhampton Aircraft - Electric - Airplanes (FS/W) 0 Feb 11, 2013 08:14 PM
Discussion Scratchbuilt floatie night and or indoor flyers BrownEyedFool Foamies (Scratchbuilt) 9 Feb 05, 2013 07:39 AM
Sold 36" Wingspan RTF Night Flyer - $115 LPU Only gabrielisrael Aircraft - Electric - Airplanes (FS/W) 2 Jan 23, 2013 01:13 PM
