Old Jan 19, 2013, 10:50 AM
United Kingdom, England, Cambridge
Joined Aug 2012
Prop spacer / sleeve question.
Fitting my props for the first time, I have 2216 Tiger Motors And 10" Graupner props. Quadcopters UK supplied me with some Graupner spacers.
I tried pushing the spacer on and it was far too difficult, so I screwed it on, it's stopped at the end of the thread and will not move at all.
My question is..
Is it supposed to stop there or somehow push to the bottom? I have ot got bionic hands and fingers to screw it or push it any further down.
Edit:
My Answer is..
I feel a bit stupid now! But for anyone else wondering in the future yes they push all the way down, find something to push it down against that won't move and it works.
Jmm_jammy is offline Find More Posts by Jmm_jammy
Old Jan 19, 2013, 12:06 PM
Joined Aug 2012
On the same topic, has anyone had to file down a the shaft? As my spacer seems taller than the blade itself so when tightening the top nut it's sitting on the spacer not prop
Old Jan 19, 2013, 07:04 PM
DesJardins's Avatar
United States, AZ
Joined Oct 2012
Hmmmm, I use the aluminum spacers from Quadrocopter and they slide on without hanging up.
I would make sure you have the correct version as there is a 5mm-8mm & 6mm-8mm...etc
If they are correct I would take them back off and use a little bearing oil to see if that gets them down on the shaft. Also I wouldn't cut the thread section of the prop adapters
DesJardins is offline Find More Posts by DesJardins
Old Jan 19, 2013, 07:15 PM
Mortimer's Avatar
Joined Apr 2010
Where are coming from your adapters ?
They're not genuine Graupner as below.
These slide easily on the shaft and in the prop.
Mortimer is offline Find More Posts by Mortimer
Old Jan 25, 2013, 01:01 PM
Joined Aug 2012
They come from quadcopters uk, in graupner packaging
Old Jan 25, 2013, 01:32 PM
Joined Aug 2012
Whether they are offical or not I can say they are utter boll***s and should not be supplied by any retailer! My props were perfectly balanced, these were placed in and the balancing is so far out its unbelievable.
So I've had to sand more, add more glue and wait for it to dry, hours of work!
Really wish quadcopters uk told me they were sh*t and give an option to pay for metal ones!.
Rant over.
Edit: official Graupner spacers are actually plastic, metal ones are made by third party company's.
If anyone can tell me where to get metal spacers in the UK it would be much appreciated.
Discussion Graupner E-props for HT-FPV spacer question? Tharr62 Multirotor Talk 8 Feb 13, 2014 07:18 PM
Sold 12/24 volt starter with handle and a sleeve pincher tamalito Boats (FS/W) 1 Jan 21, 2013 07:16 PM
Question DJI F450 Build Questions ( T motors, Lipo's , Props ) Lenny7118 Multirotor Talk 7 Jan 19, 2013 07:40 AM
Question Glue spacer rings in APC props? rhodesengr Electric Plane Talk 23 Jan 17, 2013 02:16 AM
Outrunner Prop Spacer?? rmorhan Power Systems 0 Nov 12, 2005 11:39 PM
