Old Dec 06, 2012, 06:05 AM
ETS....Energy retention system
timbuck's Avatar
gold coast australia
Joined Aug 2008
Gismo 36 edf ?????
Hi guys.
Tell me if I'm in the wrong place.. I'm building a new sloper/ds wing.
http://www.rcgroups.com/forums/showthread.php?t=1781085
I'm interested in making a EDF version also. I've had EDF's in the past , but now hooked on DSing and don't really know what's out there.
I do a lot of composite, and I'm looking for a POD type set up. I guess 50 or 70mm. ???
Info.
The tail plug into a 100mm by 30mm slot in the top surface of the wing , so mounting is not a problem. Also im planing on making a twin tail set up , basically a bottom mount/bracket with tails attached , and EDF pod in the centre.
Any help or push in the right direction would be cool..
Tim
timbuck is offline Find More Posts by timbuck
Latest blog entry: Gizmo 36 pics
Old Dec 08, 2012, 06:10 AM
timbuck's Avatar
Joined Aug 2008
...bump..
No idea's... I guess , low drag , agile , full carbon , hollow molded , planes might not be fast enough.
50mm will be good. I've got a few haoye 51mm EDF's , I guess that a start just to see how it goes , and balances etc.
Tim
Old Dec 08, 2012, 11:09 AM
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
I stuck a 50mm EDF with pod on top of an old DCU Striker sloper and it works great. It doesn't have loads of power, but once it gets going, it flies nicely. I glued a large dowel inside the fuse to connect the bottom to the top and drilled a hole through it for mounting the fan pod. The pod has a t-nut in its bottom and a long bolt holds it on. This way the plane can go back to pure glider or a larger fan could be fitted. To be honest, I wasn't sure if the little 50mm unit was going to be enough poop!
I like your Gizmo. Looks neat! It depends on what kind of flying you want to do with it. In my case I didn't want to add a bunch of weight so it's only using a 3s 1320 battery pack. Do you just want to keep it up on the slope when the wind quits, or would you fly it on the flat?
The 64mm fans are flying on 3 and 4s 2200 packs and go pretty well, generally with inexpensive little outrunners. For big power or greater efficiency, 70mm gets you up to the next level of motor sizes with 28mm motors. Most use Mega, ARC or Neu inrunners.
I'll keep an eye on your other thread. Fly well Gizmo!
Steve C is offline Find More Posts by Steve C
Old Dec 08, 2012, 01:15 PM
timbuck's Avatar
Joined Aug 2008
Thanks steve.
Just for flying on the no wind days.. I'd like to set it up for for Around 100mph.
Which I don't think will be hard , for this slippery little sucker.
The BIG restriction I have is room for Batt. I think I can get a 1000mah 4s or a larger 3s.
I have 21mm thinkness around the nose section , I could run 2 smaller batt on angle , kind of V .
This is the reason I'd like to find some kind of pod ( already manufactured ) so I don't have to make them my self.
With my central fin , i guess twin 40mm or 50mm would be good.
Air frame weight should be around 250g...
Tim
Old Dec 09, 2012, 04:57 AM
Life begins at transition
Australia, VIC, Sale
Joined May 2007
250g you could get away with a 30mm!
Wemo microfan (55mm) would be a good start. Not the cheapest, but should perform
Odysis is offline Find More Posts by Odysis
Discussion Anyone ever use the ARC 36-65-1 or 36-75-1 motors with prop? mikes68charger High Performance 0 Apr 16, 2012 08:53 AM
Discussion Free plan: Gismoe - C gas free flight Nationals winner from February 1948 Model Airpl planeman Vintage & Old-Timer Designs 11 Jun 19, 2010 12:32 PM
For Sale Medusa 36-60-1300 and 36-80-1100 V2; great for 90mm EDFs Aero Ace Ace Aircraft - Electric - Power Systems (FS/W) 3 Jun 08, 2009 06:30 PM
Does a Kontronik 600-36 have any EDF applications? nadt770 Electric Ducted Fan Jet Talk 10 Aug 06, 2004 01:29 AM
71:36 EDF flight time? Oh please let it be true. watersharer Electric Ducted Fan Jet Talk 15 Aug 05, 2001 07:48 PM
