Old Feb 27, 2015, 02:25 AM
Joined Feb 2015
EDF Jet fan data
Hello All,
I am new to the field of EDF jets and am currently working on a new aerodynamic design using SolidWorks and Flow SImulation for aerodynamics testing. For my computer model, I can enter data for a fan that I would like to use for the thrust of my models, and I'm wondering if there are any good brand EDF manufacturers who provide a lot of technical data on their fans? Specifically, I'm looking for a curve that plots the volumetric flow rate of air vs. pressure difference created by the fan. With this information, I can create a model of the fan for simulation purposes. Would anyone have any recommendations for the best manufacturers to contact for such information?
Any help/tips greatly appreciated.
Thank you!
Jason O
Jdo300 is offline Find More Posts by Jdo300
Old Feb 27, 2015, 02:49 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Fans don't really make much pressure.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Feb 27, 2015, 03:11 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
The information your seeking, has not, nor probably ever will be made public. There are so many different fans, diameters, blade counts,and pitches you've got quite a project ahead of you.
In general, no body real cares about that- Some buy there fans for the sound, or quality, -price, and a number of other reasons.
But if you want a good fan to work with, and who has posted about as much info as you will find - Is the Jetfan by E-Jets.. Rainer has done more extensive testing to date, than any one else . And posted results.
His 90mm fan, is one of the most popular.
Amps, Watts, and thrust are generally what most are concerned with.. FYI-- his tests are made with an intake ring and open exhaust ( no thrust tube)
See his results here:--http://www.rcgroups.com/forums/thumbgallery.php?t=1504718&do=threadgallery
start at about 1/2 page down-- results from his V2 version. That's about as much info as you'll find on any fan.--Have fun.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 28, 2015, 01:38 AM
United Kingdom, England, Southampton
Joined Oct 2013
Originally Posted by Jdo300 View Post
Hello All,
Thank you!
Jason O
AIR SALLY and CoolerByTheLake are both correct. And they know what they are talking about.
And unless you are going to try and beat the current experienced and good manufacturers (which is very unlikely as you had to ask where to find data) your 'computer modeling' is completely pointless anyway.
Why pointless? Because if you want to build and fly EDF toy planes just turn off your computer, buy a fan, and do it.
Also. When you exclude the 'rubbish' fans there is very little performance difference between fans. Matching the correct motor and number of cells used to the fan you have chosen is far more important than the finer points of fan design.
HOWEVER, you might follow the Richard Sharman and Klaus Scharnhorst links from here -
http://www.southamptonmac.org.uk/edf_discussion_36.html
Dr Richard Sharman in particular has access to computers likely a thousand times more powerful than yours and knows how to work them. He flies cheap foamy EDFs and fits the fans provided
Mark Powell is offline Find More Posts by Mark Powell
For Sale Nitroplanes Fan Trainer EDF jet parts ncflyer79 Aircraft - Electric - Jets (FS/W) 0 Jan 26, 2015 09:38 PM
Sold edf motor- fan - esc sale 70 mm to 127 mm units stumax- shubler- jet fan -wemo yf22raptor Aircraft - Electric - Jets (FS/W) 11 Aug 04, 2014 05:45 PM
Sold NIB GWS J10 75mm EDF jet with fan unit, functional canard! xzd Aircraft - Electric - Jets (FS/W) 1 Dec 28, 2013 02:10 PM
Sold 64mm EDF RC Jet Electronics: Fan,Motor,5xServos,ESC,Rx - $40 xrichierichx Aircraft - Electric - Power Systems (FS/W) 0 Sep 18, 2013 10:20 AM
Link Compilation of Electric Ducted Fan (EDF) and motor data from RCGroups and other Scarey Electric Ducted Fan Jet Talk 11 Apr 09, 2009 06:56 PM
