Old Nov 10, 2013, 06:11 PM
Crashing at 8600ft
balthazar420's Avatar
United States, CO, Conifer
Joined Sep 2009
Build Log
Jupiter free flight balsa model conversion (Now with video of maiden flight crash)
I downloaded a set of plans for this Free Flight model. I wanted to test out some new (to me) build techniques. The result is a razor straight fuselage and wing.
I purchased a piece of galvanized steel and some magnets from Home Depot. I never liked using pins as with my ham fisted approach, I would always break things. This way IMHO is much cleaner and easier.
I will finish this model with an Aerolite covering, PZ Mini Vapor brick and the motor/GB/Prop from my "retired" Flyzone Albatross.
I learned what I needed to learn with this experiment, so this one has been placed in line behind several other projects which are entries into the MMBC and the BBCC3 contests. I will finish this gem before spring next year, I promise! LOL!
EDIT: Here is a video of the second flight. Again, the GB fell off. I need to figure out a good way to attach the motor to the airframe.
Jupitor maiden flight ar6400 PZ UM p-51 Gearbox RC Free flight conversion (0 min 31 sec)
balthazar420 is offline Find More Posts by balthazar420
Old Nov 10, 2013, 07:54 PM
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
I really like the building board approach. There is a magnetic commercial unit out there but at a crazy price tag. Home Depot - my kind of supply spot!
I like doing my alignments over a ruled grid. Maybe you could print one out and spray glue it to the metal building surface. Whoops! I have to go now - I just remembered something I need to get for one of the wife's chores from Home Depot.
gklein is online now Find More Posts by gklein
Old Nov 11, 2013, 10:37 AM
Crashing at 8600ft
Joined Sep 2009
I know, I looked at that one online, and I couldn't believe how much they were asking for it. The galvanized steel is 24" x 36" and was only $9 at HD. I purchased 32 magnets that cost around $6, also at HD, so I'm into it for 15 bucks? You can't beat that!
Old Nov 11, 2013, 06:55 PM
skumgummi dave
Gresham, OR.
Joined Mar 2004
balthazar:
What are the dimensions of the magnets?
Dave-
foamdave is offline Find More Posts by foamdave
Old Nov 12, 2013, 11:29 PM
Crashing at 8600ft
Joined Sep 2009
They are 1" by 1/4' by 1/4" they come in packs of 8!
Old Dec 31, 2013, 05:57 PM
Crashing at 8600ft
Joined Sep 2009
This little model got some attention lately. I installed the FlyZone motor and gearbox from my Albatross. The landing gear are mostly finished. I will add a tail wheel later. I added a conventional vertical stabilizer. The plans call for a twin tail, but this will make the control surfaces much easier. I will still have the two side vertical pieces on the ends of the elevator. Maybe I can have 2 tail wheels, one on each.
Old Dec 31, 2013, 06:44 PM
skumgummi dave
Gresham, OR.
Joined Mar 2004
balthazar420
Your Jupiter is coming along nicely. I followed your advice on the magnets and galvanized steel. I now have a new magnetic building board.
Many thanks;
Dave-
Old Dec 31, 2013, 09:52 PM
Crashing at 8600ft
Joined Sep 2009
Oh cool! Glad to hear it! I couldn't believe how much they wanted for a metal builders table online!
Old Jan 01, 2014, 09:11 PM
skumgummi dave
Gresham, OR.
Joined Mar 2004
Yes, saving money that way frees up more resources for other hobby goodies.
Old Jan 03, 2014, 09:20 AM
Beijing, China
Joined Nov 2006
Your Jupiter is looking good.
For a magnetic building board, has anyone tried a white board? It seems like a fairly glue resistant surface, and they all seem to have steel behind them.
reylf_gnijieB is offline Find More Posts by reylf_gnijieB
Old Jan 03, 2014, 10:23 AM
Crashing at 8600ft
Joined Sep 2009
That would be neat if it worked. You could write notes and measurements on the board and then easily wipe them off. I wonder how the steel would handle dry erase markers? It might just wipe off. I will try it.
Old Jan 04, 2014, 04:24 PM
Crashing at 8600ft
Joined Sep 2009
I have decided to finish the Jupiter in Aerolite (solite) transparent yellow and blue. I like the scheme on the picture below. Hopefully I can get it right! Speaking of that, does anyone have a picture of this model finished? I would love to see how she looks finished!
Here is a link to the plan download...http://www.rcgroups.com/forums/showthread.php?t=1250043 Many thanks to Planeman for posting this plan!
Old Jan 04, 2014, 11:48 PM
Crashing at 8600ft
Joined Sep 2009
The wing loading will be very light. I am planning on a 21 gram (.74 oz) AUW (hopefully lower ) and the wing area is a little over 49 inches², so the wing cube loading will be at or under 3.6! That is what I want, a lazy, slow flyer! With the brick, she comes in at 18.6 grams. The only thing left is the covering, CF control rods and geometry, control horns and various other small details. I am considering covering only one side of the wing and elevator to save weight. Hopefully I will have some more updates soon!
Old Jan 08, 2014, 12:42 AM
Crashing at 8600ft
Joined Sep 2009
I changed my mind and decided to go with a tissue covering. I have some orange tissue and white. As you can see, I did the wing in orange. I might use the white tissue on the fuselage. Then I can call her the Cream-Cicle. It looks alright for a first time. The wing warped a little, but I guess you can't expect such a light structure to not flex. I will add some struts to hold the leading edge in place.
EDIT: A little time above the steam coming from the tea kettle fixed that warping straight away!
Old Jan 09, 2014, 01:58 PM
Crashing at 8600ft
Joined Sep 2009
Wow, the tissue is actually pretty heavy! The Jupiter has gained a considerable amount of weight. I just threw all of the white tissue onto the scale, so the AUW should be less than 30.8 grams, I hope! That is kind of a shock to see how much weight was gained! YIKES! It looks like I will have to revise my wing loading goals.
I changed the wheels to a pair of Guillows red plastics. They are .9 grams each. The other wheels were 1.2 grams each. I may go with depron disks or something else.
The wing was too flimsy and broke several times right at the root. i added a 1/32 sheet brace to cover the whole area emcompassed by the middle rib and the rib on either side. For only 1 gram of extra weight, the wing has gained much needed strength. This new rigidity also allowed for correction of warping caused by the tissue shrinkage.
Once again, I have used a plastic bread bag tie to make some control horns. I like the fact that you can just heat up the end of your metal z-bend and poke it through (melt it through) to get the perfect sized hole! No slop on this end!
Hopefully I can finish the rudder and elevator controls tonight and get the fuse covered. That's pretty much all I have left on this kool kat!
Off Site New in Sealed Box Carl Goldberg Ranger 30 Control Line or Free Flight Model Kit badbill Aircraft - Fuel - Airplanes (FS/W) 1 Nov 24, 2014 12:30 PM
Discussion Free plan for the "Jupiter" rubber model by Comet planeman Free Flight 7 Mar 15, 2014 05:06 PM
Sold Walston Free Flight Model Retrieval system Ian Easton Aircraft - General - Miscellaneous (FS/W) 1 Apr 11, 2013 09:07 PM
Download FREE FLIGHT MODEL PLANS (More than 1000 drawings) lekovic64 Free Flight 19 Mar 16, 2013 12:59 AM
Discussion Conver a balsa stick 40 plus FireChief4302 Glow to Electric Conversions 6 Aug 25, 2012 02:41 AM
