Old Feb 05, 2015, 04:42 PM
AMA member since May 2013
Supreme Balloon's Avatar
United States, CA, Petaluma
Joined May 2013
Post a picture of your ship, that may help diagnose.
Are you sure your flight modes are setup correctly? Not accidentally flying in manual mode?
While the NAZA is forgiving on a few things, like GPS offset measurements, it isn't forgiving if you either mount the controller off the CG and/or do not use the supplied double sided tape (or something similar) to secure it. No velco, no housings, no rubber bands etc.
Supreme Balloon is offline Find More Posts by Supreme Balloon
Old Feb 06, 2015, 03:59 AM
Sweden, Stockholm County, Stockholm
Joined Sep 2013
Hi
Props are spinning in the right direction
GOG OK (no tipping if I hold the quad between two oposite motors)
Controlled GPS mode in the app before flight.
Checked in flight that I hadnt switched to ATTI or Manual
Naza taped on the CG of the frame as advised by the frame manufacturer
I can see one possible point of failure and it is the battery. My hypothesis just now is that I might have had a voltage drop, not enough to let the quad fall down like a stone, but enough to reduce lift so much that it would crash like a bullet, in diagonal, flying on the momentum of the speed it had (with just enough power to keep the props to turn) and in the direction of its movement.
The battery had 3.8 V per cells after 30mn, which mean that they must have been around 3.5 - 3.6V under load, maybe even less than that. I usually have a buzzer but not this time.
fanch72 is offline Find More Posts by fanch72
Old Feb 06, 2015, 05:59 AM
Relax, have a Cub
mewert's Avatar
College Place, WA.
Joined Apr 2004
Try flying it with a fresh full charge on the battery. Do you have the cell count set right in the assistant screen? 3s or 4s?
mewert is offline Find More Posts by mewert
Old Feb 06, 2015, 12:41 PM
SirEdward
blimppilot@ph's Avatar
Philippines, NCR, Pateros
Joined Apr 2004
blimppilot@ph is offline Find More Posts by blimppilot@ph
Old Feb 07, 2015, 08:24 AM
Germany
Joined Sep 2011
Originally Posted by fanch72 View Post
Hi
I can see one possible point of failure and it is the battery. .........
Before time I have such crash too.
I disassembled and assembled the FY680 again and I have not found any problems.
Later I found, that one of the battery, which I used for the crash flight have a bad cell.
The battery work without any problems, no external damages.
But I found, that wen this cell reach 3.8-3.9 volts, the voltage drop immediately and this caused my crash.
Krasimir
kmihalkov is offline Find More Posts by kmihalkov
Old Feb 07, 2015, 03:32 PM
Joined Sep 2013
Krasimir
this is what I think happened. The crashing pattern was really weird.
Anyway, I'll keep you posted when I get my new props
Old Feb 08, 2015, 09:56 AM
Joined Aug 2011
What's the best firmware for the original Naza-M with GPS?
I haven't flown it very much in the last two years, so it probably has the 2.01 or 2.02 firmware - the one where it ocassionally drifts away for the first one or two minutes, but i've got used to this.
In the meantime, i've been reading about the different problems with the 3.10 firmware and afterwards ( i think this was 2013) , so i haven't updated it at that time.
Now i've checekd DJI's website and saw that there is a 4.00 firmware. Does this solve the problems, or should i stay with the old firmware?
Thanks.
paul_e88 is offline Find More Posts by paul_e88
Old Feb 08, 2015, 10:07 AM
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
4.02 has been around for almost 16 months and is fine.
Bill Glover is offline Find More Posts by Bill Glover
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 05:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 05:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 09:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 02:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 06:01 PM
