Old Dec 17, 2014, 12:10 AM
You can call me Pat
United States, FL, Tampa
Joined Dec 2013
Ah, that's cool. Those shims even have the proper radius to follow the profile of the grip.
Speaking of grips, the HK tail grips are machined a little tight, the thrust bearings don't want to drop into place without heavy persuasion.
Taking the head apart now, the caged thrust ball bearings were inserted backwards on both sides. And the feathering shaft bolts were installed with red loctite. I'm heating up the 80w soldering iron right now to get one of them out.
And one blade grip on the head would barely turn. Need to figure that out.
pdooley is online now Find More Posts by pdooley
Old Dec 17, 2014, 03:45 AM
Endolf's Avatar
United Kingdom, England
Joined Nov 2012
Another ebay special. You made the right call by stripping and rebuilding it though
Endolf
Endolf is offline Find More Posts by Endolf
Old Dec 17, 2014, 04:06 PM
You can call me Pat
Joined Dec 2013
Finished the rotor head. There was so much loctite on one FS bolt that the washer fused to the bottom of the bolt head. I also discovered double stacked shims on the radial bearings on both sides. This may have caused my binding problem. There was also a little wavy washer loose inside the rotor hub, not sure where it lodged but it's out now. Greased the dry thrust bearings and reassembled.
I must admit the bearings in the head are a lot better than the tail. In fact the head is very smooth now with the above mentioned fixes.
extra shims and the rogue mini wavy washer:
Old Dec 18, 2014, 01:40 AM
Atomic Skull's Avatar
Joined Dec 2011
The V2 Align tail grips (triple bearing) and KDS Innova tail grips are like that too. Use a heat gun on the grip first and it will drop right in. The outer washer doesn't need this just the inner one. The outer washer is about 0.1mm smaller in diameter in order to rotate freely without touching the side of the grip while the inner washer has a slightly larger hole in the center and will rotate with the grip while not touching the spindle.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Dec 18, 2014, 12:04 PM
You can call me Pat
Joined Dec 2013
good info, thanks.
So the inner washer of the thrust bearing assembly rotates with the grip while the outer washer(hopefully) stays fixed with the bolt head.
Actually that inner thrust washer being tight in the grip is a benefit since the grips only have one radial bearing for support.
Old Dec 18, 2014, 01:12 PM
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
Originally Posted by Atomic Skull View Post
KDS Innova tail grips are like that too. .
Mine were and are still fine on my KDS550 V2. Silky smooth and an all round very well behaved tail.
Paul 1968 is offline Find More Posts by Paul 1968
Old Dec 18, 2014, 09:53 PM
Joined Dec 2011
good info, thanks.
Yes that is exactly right.
Most thrust bearings have one washer with a larger hole and outside diameter and one with a smaller hole and outside diameter but there are exceptions. The thrust bearings that came with my RJX Xtreme 600's tail grips have the same outside diameter on both washers, though the inner one still has the larger hole. The plastic tail grips are molded so that the outer thrust washer doesn't touch the side of the grip. I discovered this when I tried to use a spare set of RJX thrust bearings in a set of KDS tail grips and got a nasty wag caused the the grips binding under load.
Yes they work fine, that side of the thrust bearing is supposed to rotate with the grip. A heat gun will simplify installation of the lower thrust washer.
Old Dec 21, 2014, 01:46 AM
Joined Sep 2013
You must have got a good kit. I didnt get thrust bearings in my Tail grips, only 3 radial bearings. But Im going to upgrade to the helioption tail grips.
Yip I had the same problem on my kit every is loctited in red locktite and have to heat the crap out of them to get them out.
Diggiz is offline Find More Posts by Diggiz
Old Dec 21, 2014, 01:48 AM
Joined Sep 2013
Oh Pdooley, what size blades you guna run? I got which were supposed to be Tarot 3g 550 but were actually 565mm and Im running a 17T with a turnigy mototr and struggle to get enuf headspeed.
Old Dec 21, 2014, 10:31 AM
You can call me Pat
Joined Dec 2013
the kit came with some nice 520 Align blades, but I thought I may try some cheaper HK 550 GF blades if I can get them to balance.
Sold <<<SOLD>>> T-Rex 450 Pro HK Clone with da Blingggg $170 Mahu Aircraft - Electric - Helis (FS/W) 0 Apr 30, 2012 12:50 PM
For Sale perfect new tuned HK Pro GT TT /Trex 450 GT V3TT wupgrades & lipo 3D ready flys perf! blueindian Aircraft - Electric - Helis (FS/W) 0 Sep 12, 2011 02:00 AM
For Sale Hk 450 pro plus>>>>> my loss your gain lectroglide Aircraft - Electric - Helis (FS/W) 8 Apr 24, 2011 03:47 PM
For Sale Enclosed Trailer << $550.00>> obo huddle Aircraft - General - Miscellaneous (FS/W) 0 Aug 05, 2009 11:35 AM
For Sale JR 10X <<NeW>> $550 Shipped blueprints Aircraft - General - Radio Equipment (FS/W) 3 Jan 16, 2006 12:24 AM
