Old Dec 18, 2013, 10:08 AM
aproi001's Avatar
Joined Oct 2013
Servo's spektrum a 5030 mini digital
Hello,
Can I use this servo's for the E-flite Beaver??
Thanks.
Grz,
Ronald
The Netherlands.
aproi001 is online now Find More Posts by aproi001
Old Dec 23, 2013, 05:52 AM
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Hi Ronald,
I think those servos would be fine. If you are planning on installing floats, i would suggest that you install a stronger servo for the rudder. That said, the recommended JR MN48 servos are only $8USD more expensive than the 5030's, so they might be worth the investment.
Best of luck to you,
Josh
jgalexander is offline Find More Posts by jgalexander
Old Dec 29, 2013, 03:07 AM
aproi001's Avatar
Joined Oct 2013
Originally Posted by jgalexander View Post
Hi Ronald,
Josh
Thanks allot Josh I not use floats.
Old Dec 29, 2013, 03:16 AM
aproi001's Avatar
Joined Oct 2013
Broken elevator
Hello,
I received my beaver but with a broken elevator can I solder this??
Old Dec 29, 2013, 10:03 AM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Wow that a bummer. I wouldn't just solder it as is.
If you could make a sleeve with a tab to grab the horn, Then I would.
Just have Horizon replace it.
TripleW is online now Find More Posts by TripleW
Old Jan 06, 2014, 01:14 PM
aproi001's Avatar
Joined Oct 2013
beaver aileron differential??
Hi Guy's,
Dit you use aileron differential for this plane and how much??
Thanks allot and sorry for my englisch.
Ronald.
The Netherlands.
Old Jan 06, 2014, 03:20 PM
rgthd007 on YouTube
Oatmeal Savage's Avatar
Canada, BC, Langley
Joined Mar 2010
Originally Posted by aproi001 View Post
Hi Guy's,
Ronald.
The Netherlands.
I use 50% Aileron differential and it made a big difference!
Cheers!
Oatmeal Savage is offline Find More Posts by Oatmeal Savage
Old Jan 10, 2014, 03:01 AM
aproi001's Avatar
Joined Oct 2013
Cheers!
Thanks allot!!
Old Jan 15, 2014, 09:25 AM
aproi001's Avatar
Joined Oct 2013
Beaver rudder problem
Hi Guy's,
I have a problem with my rudder cant get the rudder tho the right not more than 22mm and to the left 35 mm?? Can anyone solve this problem??
I think the tailwheel is the problem!!
Ronald.
The Netherlands.
Old Jan 15, 2014, 11:32 AM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
What Transmitter are you using?
What servo are you using?
Is the servo centered when the Rudder is centered?
Is the arm on the rudder set properly?
Old Jan 15, 2014, 01:23 PM
aproi001's Avatar
Joined Oct 2013
hi,
I use a futaba T8FG servo spektrum 5030 midi airplane servo.3.6 kg.
And yes everiting is centerd.
But the problem is the right side rudder the left side is oke 35 mm and right only 22 mm.
Old Jan 15, 2014, 02:28 PM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Sorry for all the questions, Just trying to see where you are at. Sometimes the most obvious things get over looked.
If you watch the servo while operating the rudder does the servo arm travel the same distance in each direction?
I don't know Futaba very well.
Do you have a servo travel adjust or Maybe a programmable Dual Rate function on your TX?
W
Old Feb 24, 2014, 10:29 AM
Up, Up & hopefully away!!
flboy286's Avatar
United States, FL, Volusia County
Joined May 2013
Where have you all installed the on/off switch from the 60A ESC?
Thanks ~ John
flboy286 is offline Find More Posts by flboy286
Old Feb 24, 2014, 12:05 PM
flboy286's Avatar
Joined May 2013
Thanks ~ John
Disregard
I mounted it on the side of the fuse.
New Product NEW Pulse XT 25e ARF by E-flite! P-51C Sport Planes 2919 Jul 14, 2014 11:12 AM
Wanted Eflite DHC-2 Beaver 25e ARF dizzane Aircraft - Electric - Airplanes (FS/W) 3 Jul 02, 2008 10:36 PM
Wanted Looking for a DHC-2 Beaver 25e ARF jlintvet Aircraft - Electric - Airplanes (FS/W) 1 Jun 08, 2008 06:40 PM
Sold E-flite DHC-2 Beaver 25e ARF (80% Complete) LOCAL PICK UP ONLY CGReload Aircraft - Electric - Airplanes (FS/W) 1 Apr 17, 2008 06:19 PM
For Sale Whoa!! E-flite DHC-2 Beaver!!!! 25e Hoangsta Aircraft - Electric - Airplanes (FS/W) 13 Mar 18, 2008 06:57 PM
