Old May 15, 2008, 05:44 PM
Joined Oct 2007
motor tp 2408-21 as to pass another wire?
hello friends, my motor suffered an accident and broke some copper wires in the rolling and would like to know if somebody has a drawing showing as to rewind (motor tp 2408-21). thanks
RODRIGOrio is offline Find More Posts by RODRIGOrio
Old May 15, 2008, 07:07 PM
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
original 2408-21 is 21Turns delta.
manuel v is offline Find More Posts by manuel v
Old May 15, 2008, 08:07 PM
Joined Oct 2007
thanks manuel! this drawing that you placed here only serves for delta? by chance you it would have the project of (star) and which thickness of the wire use to roll? it would like that it was a good push.
it also needed to know how many returns I I go to have that it gives?
very thank for its attention.
Old May 15, 2008, 08:18 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
near Nijmegen, Netherlands
Joined Feb 2001
We need to know the number of statorpoles (teeth) and number of magnets as well. That will determine winding diagram to use.
Ron van Sommeren is online now Find More Posts by Ron van Sommeren
Old May 15, 2008, 11:08 PM
manuel v's Avatar
Joined Aug 2004
RODRIGOrio.
First is Star and second is Delta.
14T Star, 24awg is good for GWS 9x5 3s.
http://www.rcgroups.com/forums/showthread.php?t=698640
Manuel V.
Old May 16, 2008, 11:16 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
A 13 turn Star (WYE) connection with 24 AWG wire will give almost exactly the same kv as the original, but it will produce more output power and will run a little cooler.
IBCrazy is offline Find More Posts by IBCrazy
Old May 19, 2008, 07:59 AM
Joined Oct 2007
It forgives me for the delay!
hello, (motor TP 2408-21) has (9 statorpoles) and (12 magnets). which would be the best drawing so that I can base me and rewind the motor ? I have weave 31 AWG, how many returns will have that he gives?
somebody could show to some figure (drawing) please to me of as to rewind?
it would be star the best easy option and but to rewind?
how I can rewind so that it gives more push?
thanks !!
RODRIGOrio
Old May 19, 2008, 11:52 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Go with Manuel's suggestion and wind as a 14 turn WYE (Star). Use 4 strands of your 31 AWG wire.
Old May 19, 2008, 12:26 PM
Joined Jan 2007
In the first photo, it looks like only one wire is broken. If so, is there any reason why you shouldn't splice a repair piece in, twisting the joined ends and soldering, to complete the repair? I've done this before to resurrect a failed motor in my kitchen range hood.
Ron? Any comments?
Or, do you really want to try rewinding the motor, instead of repairing it?
In either case, see Ron's tips on tests you should perform before connecting the motor to your ESC.
Cheers,
Bill Segraves
segraves is offline Find More Posts by segraves
Old May 19, 2008, 03:07 PM
Joined Oct 2007
Originally Posted by segraves
In the first phot, it looks like only one wire is broken. If so, is there any reason why you shouldn't splice a repair piece in, twisting the joined ends and soldering, to complete the repair? I've done this before to resurrect a failed motor in my kitchen range hood.
Ron? Any comments?
Cheers,
Bill Segraves
in the case it had 5 broken wires!
Old Dec 21, 2008, 08:19 AM
I'm overcoming gravity!
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Hi, I am getting ready to rewind one of these motors and just had a question. You are suggesting only 13 turns of 24awg to replace 21 turns of the original 31awg? Is this because of the wye termination instead of the delta? I am looking to duplicate the original performance if not enhance it slightly with a bit more thrust for my Superfly. Thanks
Murman is online now Find More Posts by Murman
Old Dec 21, 2008, 10:40 AM
Homer_Simpson's Avatar
Joined May 2008
Wye will give more torque but less power! Wye is easier on ESC to sense motor speed. If it's for a slow flying plane when you need a big(er) prop will less pitch speed it's ok. For fast flying wing go delta, as thick as possible single wire and reduce turn count by 1 or 2 to get higher RPM.
Balancing bell also helps. Check and relube bearings - dirt will kill the really fast - they are low quality.
Regards
Homer
Homer_Simpson is offline Find More Posts by Homer_Simpson
Old Dec 21, 2008, 10:49 AM
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
The main reason for using larger (better) wire is the crappy 31g wire BREAKS. That's only one of the problems with that motor.
Larger wire had lower resistance and cools better. If you wind as suggest you won't get a big power increase, maybe 10-15% if lucky but in a small motor that can be a noticeable improvement.
flydiver is offline Find More Posts by flydiver
Old Dec 21, 2008, 12:30 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
A 13 turn Wye is equal to a 21 turn Delta. Also 4 strands of 31 is almost equal in resistance to a single strand of 24 AWG.
I would recommend a single strand of 24 AWG since you are newer motor builder. I have wound these motors with a single strand of 22AWG (which yields 65% lower internal resistance). However, this requres a third layer on the stator poles and is very difficult to wind.
As Homer said, WYE is easier on the motor controller in every case I have seen. Besides, WYE requires less turns and therefore it takes less time to wind and you don't lose count so easily.
-Alex
Old Dec 21, 2008, 02:24 PM
Murman's Avatar
Joined Jul 2008
Thanks guys, 13 turns of 24awg is what I will go with. I ordered the wire this morning from GoBrushless.com and got 3 different colors of the "newbie" wire. I can't wait to start winding.
Question Tp 2408-21 haroldpo6 Hot Online Deals 10 May 19, 2008 04:55 AM
Discussion More Efficient/Cheap Replacements for TP 2408-21, 2409-12, and 2409-18? critterhunter Power Systems 3 Jun 27, 2007 04:34 PM
Question TP 2408-21 triangle motor mounting??? TheDonski Power Systems 4 Jun 04, 2007 08:12 PM
Found TowerPro Outrunner Brushless Motor 2408-21 W/ Red Back Cover gromitvt10 Aircraft - Electric - Power Systems (FS/W) 2 Feb 01, 2006 05:04 PM
For Sale Brand New: TowerPro 2408-21 Brushless Motor with Firewall Mount ildo Aircraft - Electric - Power Systems (FS/W) 2 Nov 28, 2005 10:03 AM
