Old Apr 19, 2008, 01:22 PM
nyc, ny
Joined Apr 2004
repairing a servo hs-81 hitec
Hi,
After a bad crash with my easystar last week the elevetor servo "broke".
What it does is that half a circle turns easily as if there is nothing inside.
I got a new one this week and today after a crash the same thing hapened
with the same servo.
I opened it but seemed complicated to fix it. Is there any guide or something
explaining how the work and potentially a fixing guide for novice users?
The servo is the hitec hs-81
Thanks and sorry for the bad english.
mutron is offline Find More Posts by mutron
Old Apr 19, 2008, 01:33 PM
Joined Nov 2005
http://findarticles.com/p/articles/m..._n8892199/pg_1
IPFlyer is offline Find More Posts by IPFlyer
Old Apr 19, 2008, 01:40 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The usual damage to a servo is some of the teeth stripped from a gear. You can buy replacement gear sets, just do a search on 'gear set hs-81'.
You can buy a metal geared hs-81 which is much stronger.
Alternately, stop crashing
eflightray is online now Find More Posts by eflightray
Old Apr 19, 2008, 02:32 PM
Letchworth, Great Britain (UK)
Joined Jul 2004
Replacing the gearset on an HS-81 servo is simple provided you're methodical and note which gear goes where when you're disassembling them.
The metal-gear set can be installed as a replacement for the original plastic gears if you wish. I've done this with most of my HS-81s after I found how fragile the plastic gears are.
abenn is offline Find More Posts by abenn
Old Apr 19, 2008, 07:49 PM
nyc, ny
Joined Apr 2004
Thanks!
I just disassembled the servo and found the gear with the missing teeth!
I will try to find now replacement gears.
Thanks!
Old Apr 19, 2008, 09:26 PM
Sayers1's Avatar
Indianola Iowa
Originally Posted by mutron
Thanks!
Thanks!
Hi Mutron
These people got all sorts of gears ;http://www.servocity.com/html/hitec_nylon_gearsets.html
Happy Flights & Soft Landings
Sayers 1 ( Jerry )
Sayers1 is offline Find More Posts by Sayers1
Discussion EasyGlider, Rudder/Elevator Servo, HS-81? Butch777 Foamies (Kits) 3 Jul 11, 2007 05:00 AM
FS Hitec servo HS-81 FlyTime Aircraft - General - Radio Equipment (FS/W) 0 Nov 15, 2004 10:32 AM
WTB: Hitec HS-81 Servo's gromitvt10 Aircraft - Fuel - Airplanes (FS/W) 1 Aug 22, 2002 05:10 PM
Hitec HS-81 servo problem, But total success with Ken Hill's "Polly Pusher" dingo1000 Foamies (Kits) 1 Aug 09, 2002 10:50 PM
One Hitec HS-81 Sub Micro Servo New in Box!!! karl446 Aircraft - Electric - Airplanes (FS/W) 2 Oct 21, 2001 09:48 PM
