Old Jul 29, 2014, 07:39 PM
United States, MI, Utica
Joined Jan 2014
Help!
Monitor wont get full signal
For some reason I cannot seem to get my monitor to get full signal. The only signal I get when I have the Rx hooked into the monitor and everything is powered up is a flickering one. It isn't a clean signal. I can see that it is receiving signal its just flickering lines going from top to bottom. I am using a 10 inch lumenier monitor with the ImmersionRC Uno5800 v2, powered by a 1100 3S battery. The camera is 600TVL 5V camera that came in the Predator V2 package, which also included their battery connector with filter. I am using the monitor as a secondary visual, while primarily using my FatShark Predators V2 goggles. When the system is powered up using the FatSharks, the signal and visual is great through the FatSharks. I have tried running the the the A/V from the FatSharks to the monitor. Same problem. Poor visual on the monitor. So one thing I have tried is switching out the camera. I also have a 12V camera which I had to use a 5V to 12V step up to power the camera. This setup made the monitor work with the Uno5800 receiver as well as trying it plugged in to the FatShark goggles. Does anyone know why the camera would make the difference in signal to the monitor? Problem is I want to use the 5V FatShark camera because it is being used in my Blackout Mini H Quad, and the 12V camera won't fit into that rig. Is there anyway to get the monitor to work using the 5V camera?
bkay223 is offline Find More Posts by bkay223
Old Jul 30, 2014, 05:46 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
1. Turn off power. Flip your 600TVL CMOS Fatshark camera over so you are looking at the back side.
2. Remove the jumper that is near the PAL / NTSC text.
3. Done. Turn on power and fly.
- Thomas
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
For Sale Samsung 22" LED Monitors 1920x1080P Full HD bovick Non R/C Items (FS/W) 7 Mar 17, 2014 11:57 PM
Discussion Powerlab 6 wont get to full power. rizky_p FMA Direct 14 Feb 08, 2014 01:36 PM
For Sale $60 9" FPV Monitor - NO BLUE SCREEN WITH WEAK SIGNAL! AlchemistAerials FPV Equipment (FS/W) 9 Jan 11, 2014 09:33 AM
Discussion Solo pro 328 wont get airborne oliver D Micro Helis 1 Sep 25, 2013 05:42 PM
Help! DX8 range issue, used to get 2,500ft and had full signal. Now 200ft away and flatline jasper7821 FPV Talk 11 Feb 13, 2013 05:23 PM
