Old Mar 29, 2014, 10:32 PM
United States, CA, Signal Hill
Joined Aug 2009
Help!
Turnigy AE 45A Brushless ESC gov mode
how do i turn off gov mode on this esc ?
Turnigy AE 45A Brushless ESC gov mode problem blinking red light (1 min 11 sec)
wc_wickedclown is offline Find More Posts by wc_wickedclown
Old Mar 30, 2014, 01:42 PM
Joined Aug 2009
thank you
PlanetaCrema10
Hey wc, first calibrate your throttle range if you haven't yet. Switch ON tx, throttle high, connect battery, wait for the regular 123 tone meaning batt supply is good, then you will here two beeps which mean highest point, move to low stick, you will here some beeps you are done with calibration.
Now to get into program mode switch ON tx put stick to high position, connect battery, you will here 123 tone meaning batt supply is good, in 2 seconds you will here the two beeps you heard on throttle calibration, in 5 seconds you will here a 56712 tone meaning you are in throttle calibration.
For governor you have to wait for the LONG Beep and two short beeps sound. That will be the 7th sequence. Remember, LONG Beep and two short beeps. When you here this move your throttle stick to low position. You are now in governor mode. When you here 1 short beep, which will be the first one, move your stick up again to select it. This is the OFF for governor mode.
Heres the manual
http://www.hobbyking.com/hobbyking/s...45.pdf
Sold NIP, Turnigy AE-45A brushless esc with SBEC 5-6V/4A Ranchhand Aircraft - Electric - Power Systems (FS/W) 2 Feb 10, 2013 07:15 AM
Sold (4) Turnigy AE-45A esc's sgomes Aircraft - Electric - Power Systems (FS/W) 3 Jan 15, 2012 08:45 AM
Sold 45 Amp Brushless ESC Turnigy AE-45A for $17.50 shipped DrAGen Aircraft - Electric - Power Systems (FS/W) 2 Sep 06, 2011 04:51 PM
Sold NIB - Turnigy AE-45A esc $25, conus sgomes Aircraft - Electric - Power Systems (FS/W) 0 Aug 05, 2011 11:13 PM
Sold NIB - (3) Turnigy AE-45A esc's $25, conus sgomes Aircraft - Electric - Power Systems (FS/W) 2 May 26, 2011 09:50 AM
