Old Mar 01, 2013, 08:16 PM
STANG KILLA SS's Avatar
Killeen TX
Joined Dec 2006
Question
does a larger motor provide more "power"
im pretty good when it comes to motors, but this is one thing ive never been sure about, or had the chance to test myself.
lets say you have two identical motors and setups. same battery, prop, and kv etc. but you have two different size motors. #1 is the right size for the plane (length, diameter, weight, kv etc and prop) but you want a hair more power. does an identical motor #2(same kv) of a slightly larger size (length, diameter, and weight) give you a little more "power" weither its low end grunt, or top end thrust, or both?
(in this theotical test, the batteries, and esc have no problem keeping up with the motor or prop draw, props are identical on both. and changeing voltage, kv, or props is not a variable)
givin all else equal, will the larger sized motor produce more "power"
STANG KILLA SS is offline Find More Posts by STANG KILLA SS
Old Mar 01, 2013, 08:18 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Nope but higher efficiency will.
Evan D is offline Find More Posts by Evan D
Old Mar 01, 2013, 08:19 PM
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
P=IV
So to provide more power it must draw more amps.
More amp=bigger prop/higher kv/??
Other than that I have no idea how to answer.
Teddy Ong is offline Find More Posts by Teddy Ong
Old Mar 01, 2013, 08:31 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Actually P=IV x efficiency
Old Mar 01, 2013, 08:37 PM
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
The bigger motor if made with the same quality parts should be able handle a higher kV with the same prop or a bigger prop, which in turn would get you more power.
bryansifsof44 is offline Find More Posts by bryansifsof44
Latest blog entry: Weights for planes
Old Mar 01, 2013, 09:38 PM
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I called the boss on this one.i knew the answer but wasnt sure how to explain it.. Is why he is the boss..
If the quality is exactly the same the larger motor will produce more power (more rpm) and at a slight bit drop in amps.
What most people read are the input watts and is a good gauge to see if you have enough power for the plane, but it's the output watts (Work) (rpm) that count.
A larger motor of the same exact Kv which does not usually ever happen will have a higher efficiency using the same prop and voltage as the smaller motor.
The difference all depends on how loaded down the smaller motor is. If it is running say 65% then it's loaded down as much as it can handle and let’s say the larger motor runs 75% efficient with the same prop. If so you will see around a 5% jump in performance and 5% drop in watts or there about. Not sure exactly what the split would be, but you would notice a little difference in performance and most notably a drop in motor temp. Heat is a loss so in essence you are trading the heat for more power when you go to a more efficient set up.
The logical thing to do is when stepping up from say a 5oz motor to a 6oz motor is to step up the Kv by 10% or so unless the performance is good and you just need a cooler running motor. Each motor is different so it's best to just stick with what the motor manufacturer says is ok for prop and volt combinations.
So the up side is you gain more power and lower heat, but the down side is you add weight which may or may not affect the performance drastically, but will affect to some degree.
Best thing to do is stick with what the plane manufacturer says to use as for weight and Kv. That being said not all motors are created equal
Ken Young
Manta1 is offline Find More Posts by Manta1
Old Mar 01, 2013, 09:58 PM
Joined Jan 2009
Trouble is, larger motors generally have lower Kv, and vice versa. Higher Kv motors are more efficient than lower Kv because they use fewer windings and therefore larger wire sizes. It gets complicated...
rafe_b is offline Find More Posts by rafe_b
Old Mar 01, 2013, 10:12 PM
Joined Oct 2011
That is because they are usually spinning bigger props at higher voltage... Higher voltage and lower kV motors are more efficient as a system getting power from the battery to the prop, IME. However, Ken with motrolfly would be able to wind motors big or small to your kV needs. He wound me a motor to 216kV for my 71" slick to run on 12s, while others are using the same motor on 6,8,10s.
Old Mar 02, 2013, 01:00 AM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
A larger motor provides the potential for more power, but not necessarily more power in itself. Also, just because a motor is larger doesn't mean it is more efficient. Motor efficiency is dependent upon no load current and winding resistance, and each motor has a current level that will give maximum efficiency. Running the motor at a higher or lower current will decrease efficiency.
So you can easily have the case where the smaller motor and the larger motor both have the same maximum efficiency, just at a different current level. If the smaller motor is running at its max efficiency current and that current level happens to be below the max efficiency current level of the larger motor, then power will actually decrease with the larger motor running the same prop, battery and having the same Kv.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Mar 02, 2013, 01:17 AM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
The original criteria spec'd identical Kv values, so that's what we have to work with regardless of what the market gives us. It's all just theoretical at this stage; the practical side is unimportant.
As for higher-Kv motors being more efficient, this isn't really specifically true. Motors with higher Kv values can handle more current since the lower phase resistance results in less copper losses for a given current flow (I^2(R)), but then you're working with totally different prop ranges due to the Kv shift. By adjusting voltage to leave the prop unchanged, everything actually ends up fudging out pretty much the same. For example, doubling Kv and halving voltage will result in double the current, the same power, and the same RPMs for a given prop and motor chassis (assuming optimal copper fill).
There's no free lunch... UNLESS you want to toss after-motor gearing into the mix, in which case there actually is free lunch if you use a motor with a high Kv value and gear it down to a useful level. Since a given motor with twice the Kv can take twice current (and so 2x the power for a given voltage), it's effectively got twice the power-to-weight ratio as a lower-Kv wind of itself. A 2:1 gearbox with that motor will mean you have twice the power available to the prop with only a little extra weight.
As for the original question, the practical answer is no. A slightly larger motor won't give you any appreciable increase in actual performance. There's a long story there and I am pressed for time
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Mar 02, 2013, 02:01 AM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
As stated above, the simple answer is 'no' there should be no significant difference if all else is identical. To increase power you either need to spin the prop faster (higher Kv) or fit a larger prop. If the motor was larger and had the same Kv then it should be able to handle more amps than the smaller motor, so you have the option to use a larger prop.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Mar 02, 2013, 03:25 AM
rcmaverick's Avatar
Australia, NSW, Sydney
Joined Mar 2012
My 0.02c on this:
The larger and slower the prop the more efficient it is.
If I want to increase the output of a 2000 KV motor by 2 times I only have to increase the KV (rpm per volt) to about 1.25 times.
But look at what happens on the other side (electrical):
Since your cell voltage is the same say 11.1v the input current has to increase by 2 times and a bit more as this results in a higher current and higher I^2RT loss (4 Times) for the original windings. To keep the current low we can increase the cells from 3 cell to 6 cells or double the voltage but the battery pack gets inefficient.
On the propeller side with a smaller prop and a higher rpm we have a less efficient propulsion system.
To get the most efficiency manufacturers use thicker windings (larger motor), Low KV and Larger Prop.
rcmaverick is offline Find More Posts by rcmaverick
Old Mar 02, 2013, 07:32 AM
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
The motors are NOT identical if they are not approximately the same weight and Kv, so the question is really relating only to the weight or mass.
Motors do not produce power. Motors convert the potential, stored, energy of the battery into kinetic energy, the ‘work’ of spinning a prop, in this instance, and also an unwanted by-product of radiant energy, heat.
Three Examples:
The only relevant difference in the three example motors is the mass.
Derkum D-Power AL50-05, generic 5052-512, 278g/9.8 oz.
Turnigy 5055A-400, generic 5055-512, 310g/10.9 oz.
Hacker A50-12S, generic 4954-507, 370g/13 oz.
At 14.8v into the ESC the 278g Derkum turns an APC 14x7E at 6580 RPM. Pout is 269.7W. Vnet is 6580 RPM / 512Kv or 12.85V and Inet is 20.99 amps for a power system efficiency of 269.7W (Pout)/340.1W (Pin) or 79.3%.
For the almost 1 oz. heavier Turnigy, with everything else the same, the RPM is 6172. Pout is 217.1W. Vnet is 6172 RPM / 512Kv or 12.05V and Inet is 18.01 amps for a power system efficiency of 217.1W (Pout)/297.3W (Pin) or 73%.
The Hacker, the heaviest motor, with all other variables the same, turns the same APC 14x7E at 6871 RPM. Pout is 312W. Vnet is 6871 RPM / 507Kv or 13.55V and Inet is 23.02 amps for a power system efficiency of 312W (Pout)/373.6W (Pin) or 83.5%.
All of the math is based on Drive Calculator (http://www.drivecalc.de) data and WILL vary from actual measured data at the user’s elevation AMSL (above mean sea level) and ambient temperature.
The general trend is that the heavier motor with the same Kv will usually supply ‘more power’ to the same prop with all other variables being equal, as shown by a comparison of the Derkum and Turnigy to the Hacker. Remember that 'more power' may also mean shorter flight time.
The comparison of the Derkum to the Turnigy demonstrates that this is not ALWAYS true, but it is the general trend.
Ken Myers is online now Find More Posts by Ken Myers
Last edited by Ken Myers; Mar 02, 2013 at 09:53 AM. Reason: Edited Turnigy motor name - see first post on next page
Old Mar 02, 2013, 07:42 AM
Aberdeen
Joined Mar 2006
One thing to bear in mind when comparing different motors is that two motors with the same claimed kv do not necassarily have the same Kv in reality. there are numeropus methods of measuring Kv and there is a fair variation in the results. many manufacturers also round the Kv up or down to arrive at a round number.
Winding resistance also plays a part in how many watts a motor will pull and generally for the same kv a larger motor will have more copper cross section area so will have less resistance and will probably then pull a few more watts.
But in simple practical terms if you want to increase power simply putting in a larger heavier motor with the same Kv, and changing nothing else, is not the way to go.
Old Mar 02, 2013, 07:46 AM
Aberdeen
Joined Mar 2006
But isn't the Turnigy L5055A-400 a 400Kv motor (clue in the name )
Hardly any wonder then that it spins the prop slower and draws less amps.
Discussion Dell server power supply won't provide more than 16amps? davekra Batteries and Chargers 11 Nov 13, 2013 11:11 AM
Discussion Does your club provide gear to locate lost planes? Berkie Electric Plane Talk 28 Mar 02, 2013 07:52 AM
Sold Power package (motor, ESC, gyro, and more) maoromir Aircraft - Electric - Helis (FS/W) 1 Jan 26, 2013 07:48 AM
Sold Power package (motor, esc, gyro...more). maoromir Aircraft - Electric - Helis (FS/W) 1 Jan 13, 2013 03:23 PM
Discussion Which motor has more power? Want2B3D Engines 6 Jan 05, 2013 09:24 PM
