Old Oct 01, 2012, 06:33 AM
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
Fibreglassing Q's?
im going to fibreglass this flyfly model what weight glass should i use? i want something tough as ill be doing grass launches from the bungee also where can i buy the cloth and epoxy resin from?
cheers
gazza2003au is offline Find More Posts by gazza2003au
Old Oct 01, 2012, 06:44 AM
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Bias boating.
Teamsherman is online now Find More Posts by Teamsherman
Old Oct 01, 2012, 06:49 AM
Sydney, Australia
Joined Jul 2003
they only have one cloth i take it 6oz is correct weight? ill go there tomorrow
Old Oct 01, 2012, 09:43 AM
twang's Avatar
Australia, QLD, King Scrub
Joined Jun 2005
6oz per sq ??. Might be heavy, for sheeting 1/2 or 3/4 oz woven cloth would be mush lighter
twang is offline Find More Posts by twang
Old Oct 01, 2012, 01:49 PM
excelpoint's Avatar
Melbourne
Joined May 2004
Most of your hobby shops carry glass and resin. I would think 1/2 or 3/4oz would be enough.
excelpoint is offline Find More Posts by excelpoint
Old Oct 01, 2012, 02:46 PM
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
Gaz
I haven't needed any for a long time but I found these guys the best for cloth quality and price.
https://www.petenplanes.com.au/fiber...ns/cat_22.html
GPT is offline Find More Posts by GPT
Old Oct 01, 2012, 05:24 PM
Joined Nov 2004
If only looking protecting the foam you should use a very light balanced cloth.
AUSELECTRIC is offline Find More Posts by AUSELECTRIC
Old Oct 01, 2012, 05:29 PM
Member #1
Joined Aug 2011
I thought Bias would have some smaller stuff for minor repairs. Oh well.
Old Oct 01, 2012, 06:13 PM
gizzo don't tweet
gizzo's Avatar
Adelaide, Australia
OMG you used punctuation marks whats going on
gizzo is online now Find More Posts by gizzo
Old Oct 01, 2012, 08:53 PM
Sydney, Australia
Joined Jul 2003
thanks guys i will order some of that cloth and i found a web site from pldaniels about using a cabolts water based polyurethane instead of the epoxy i think ill give this a try done a search on google and found this one by wattyl http://www.wattyl.com.au/Estapol/Pages/home.aspx
Old Oct 01, 2012, 10:50 PM
Sydney, Australia
Joined Jul 2003
my order just arrived from hobby king and i picked up some polyurethane im not sure if its the right one it is water based so i will give it a test also last week i chucked some fibreglass cloth in my hobby king basket that to arrived today but its not what i can use on this model it weighs 159g 1x.5m
Old Oct 02, 2012, 09:30 AM
twang's Avatar
Joined Jun 2005
Poly over glass works really well. Easy to apply, light and won't poison you. The drawback is it doesn't give a hard shell like epoxy. It does make a great paint base which I would recommend as some of the single pack water based poly from Cabots and Wattyl are interior finishes, so don't like the sun.
Old Oct 02, 2012, 09:48 AM
Sydney, Australia
Joined Jul 2003
yeah your right twang its not like a hard shell but the fibreglass has gone pretty stiff i tested it on some scrap EPS foam i also went thru a few boxes of .... i have all rc gear and found two small bags of fibreglass from hobby king i ordered over a year ago the bags say 18grams but this stuff is so light and soft i wont be using it actually feels as weak as a tissue the other stuff i took a pic of is great stuff but feels heavy and doubling that weight once wet i dont think my model will fly so based on the 18g and 318g stuff i have here to feel i bought some 90g stuff from ebay
Old Oct 02, 2012, 07:36 PM
Sydney, Australia
Joined Aug 2003
The cabots works well, its pretty much the same finish as the wattyl. I wouldn't waste money buying another can when you have the cabots already. Make sure you put the cloth on a 45 degree angle to the wing. This adds way more torsional strength. Being water based, you can do more than one coat of the cabots without adding much weight. It will fill the weave for a better finish. If you're keen you can even add some talc for a really smooth finnish.
Komet is offline Find More Posts by Komet
Old Oct 02, 2012, 07:39 PM
lesterpk's Avatar
Australia, WA, Perth
Joined Oct 2003
Whatever cloth you use you must make sure its balanced, the same number of fibres in warp and weft of the weave. If you dont there is a good chance changes in heat will warp the model or flying surfaces.
lesterpk is offline Find More Posts by lesterpk
Question Whats up with the 'Q' and 'S' on the Tx Sculptor Beginner Training Area (Heli-Electric) 9 Mar 30, 2012 03:41 PM
Discussion SETUP Q's FOR 'SCALE STYLE' FLYING HeliGriff Scale Helicopters 11 Feb 28, 2012 09:29 PM
Discussion SETUP Q's FOR 'SCALE STYLE' FLYING HeliGriff Large Electric Helis 0 Feb 23, 2012 03:13 PM
Discussion The F.A.Q.s, ma'am, just the F.A.Q.s! Mode One AMA (Academy of Model Aeronautics) 12 Jan 20, 2010 07:23 AM
EP Concept tailrotor q's and DIY rotor q's Scott Coombe Electric Heli Talk 2 May 25, 2003 10:25 PM
