Old May 07, 2012, 02:55 PM
Joined Mar 2007
DX7 and DX5 buddy box ?
I have a DX7 and a DX5. I want to teach my GF to fly and was wondering about the buddy cord issue. Will the two radios work together? And do I have to bind both radios to the RX or just the DX7?
fireplug1111 is online now Find More Posts by fireplug1111
Old May 07, 2012, 03:53 PM
Staffs, UK
Joined Nov 2003
Assuming you mean a DX5e then yes they will work together provided you use the correct buddy cord and not just some old audio lead you have lying around .
The master TX (used by the instructor) is the only one that is bound to the RX.
Steve
slipstick is online now Find More Posts by slipstick
Old May 15, 2012, 02:49 PM
Joined Apr 2009
DX7s and DX5 buddy box stops working
I am experiencing the buddy box function going dead if the master radio [DX7s] is switched off then back on with the buddy box cord connected. If I pull the cable out of the master when I turn it off, then re-insert it when I power up to fly, it always works. I am trying to find out my DX7s is defective or they are all that way. Also , the trainer function is in the SYSTEM menu, the manual shows it in the FUNCTION menu.
Another hitch, the jack on the back of the DX5 is very tight, be sure the cord is plugged in all the way. We missed this because it felt like it was in when it was not.
BOBHEND is offline Find More Posts by BOBHEND
Old May 15, 2012, 02:59 PM
59 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
It's impossible to have a 2.4 receiver bound to two transmitters. That's what 2.4 is all about! In the buddy box situation, only the master transmitter is transmitting and the receiver is bound to it.
The student transmitter must be turned OFF. Plugging in the cable turns on just the encoder section, so that when the trainer switch is pushed on the master TX it transfers control to the encoder of the student's transmitter.
By the way, it's best to use a proper trainer cable, rather than trying to use an audio cable. Mono audio cables sometimes work but quite often they don't fit properly, which can cause all sorts of problems. JR/Spektrum trainer cables can be had for under $10 (Expert brand from Horizon, for example).
Daedalus66 is online now Find More Posts by Daedalus66
Sold Futaba 4YF Trainer Box (Buddy Box) randyoo1214 Aircraft - General - Radio Equipment (FS/W) 2 Mar 08, 2012 07:44 PM
Sold Hitec Optic 6 in mint condition in orig. box with a buddy box cable rino Aircraft - General - Radio Equipment (FS/W) 2 Feb 13, 2012 05:30 PM
Discussion which training cable to purchase for Aurora and spektrum DX7 for buddy box ? rcfun2005 Hitec/Multiplex USA 1 Dec 19, 2011 01:33 PM
Discussion DIY Wireless Buddy box for Dx7 mrexcel Radios 3 Sep 26, 2011 09:04 PM
Sold RTF Trainer package with Buddy box and Flight box. flyinjrc74 Aircraft - Fuel - Airplanes (FS/W) 1 Sep 20, 2011 12:50 PM
